Wall Covering Prep Paper? - Wallpaper - Contractor Talk
Old 06-07-2018, 02:37 AM   #1
VinylHanger's Avatar
Rewards Points: 11,722
Not sure what it's called. I was looking online about skim coating my paneling in the kitchen and ran across a post about a Wall covering that shrinks when it dries and smooths out over the gaps in the paneling.
Is this a thing? Can you just paint it after, or skim coat it? The paneling is over t&g 1x, so it is pretty solid. I can tack the piss out if it if needed.
VinylHanger is online now
Old 06-07-2018, 07:09 AM   #2
rrk's Avatar
Rewards Points: 3,506
Re: Wall Covering Prep Paper?
On a job where it wa used, looked a lot like a smoother fibafuse. Worked very well, they just painted right over it. Called it wall liner i think.
rrk is online now
Old 06-07-2018, 08:12 AM   #3
avenge's Avatar
Rewards Points: 158
That used to be a canvas liner not sure if there's something new today.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
hdavis (06-07-2018)
Old 06-07-2018, 09:10 AM   #4
hdavis's Avatar
Rewards Points: 2,542
Haven't heard of a new one that shrinks when it dries. Originally canvas was used on plaster wall, then canvassing paper. Now there are 3' wide rolls of fine fiberglass mesh. None of that seems to be exactly what you're talking about.
hdavis is online now
Old 06-07-2018, 10:07 AM   #5
I'm basically looking for a lazy way to cover the fugly paneling in my kitchen. I could hang sheetrock, but don't want to if I can avoid it.
Old 06-07-2018, 10:14 AM   #6
That seems to be it. Lots of options, now I just need to find a quality version. It looks to be similar to the old wall coverings in old houses. The canvas type would actually fit well with our house.
Old 06-07-2018, 10:46 AM   #7
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,910
I believe It is called Wonder Cover, it is a liner paper. You hang it horizontal across the paneling gaps.
The process recommended it to primer the panelling with oil primer to block any possible staining. Then prime with wallpaper primer and ready to hang. The wall liner seams can be filled with spackle if needed, the liner paper has a primer finish on it so it is ready for paint. I will see if I can dig out a product code if you need it.
Ohio painter is online now
The Following 3 Users Say Thank You to Ohio painter For This Useful Post:
Gumshoe (10-30-2018), hdavis (06-07-2018), VinylHanger (06-07-2018)
New doorway opening. Covering gap from old wall? Spencer Flooring 15 02-07-2015 04:48 PM
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 10:56 PM
drywall and wall paper country_huck Drywall 23 09-10-2011 08:50 PM
Painting over ancient wall paper [email protected] Painting & Finish Work 5 01-15-2011 02:33 PM
why primer is bubbling up over wall paper Zeebo Painting & Finish Work 2 07-10-2005 09:11 PM
