SW Prewallcovering Primer To Be Discontinued - Wallpaper - Contractor Talk
Old 11-06-2012, 10:39 PM   #1
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,910
I was told today at Sherwin Williams that the Prewallcovering primer is to be discontinued, they say the multipurpose latex primer will replace it.
I just don't buy it, I can not see that the multipurpose latex primer will adequately size the wall surface suitable for wallpaper.
What other types of primer / sizing are others using for a one step / coat preparation for wallpaper?
Thanks Martin.
Ohio painter is offline
Old 11-06-2012, 10:52 PM   #2
Robinson_Cnst's Avatar
Trade: general contractor
Rewards Points: 109
Re: SW Prewallcovering Primer To Be Discontinued
They tried to tell me that MPP is the same as DTM Bonding Primer also. Must be the cure all.
Try Roman 909.
Robinson_Cnst is offline
Old 11-07-2012, 12:32 AM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
I use Gardz almost exclusively for a pre-wallcovering primer.
ProWallGuy is offline
The Following 2 Users Say Thank You to ProWallGuy For This Useful Post:
Big Shoe (11-07-2012), salmangeri (05-12-2013)
Old 11-07-2012, 09:50 PM   #4
Thanks guys. I will have to drive 45 miles to my next closest supplier but I usually get up that way often enough it shouldn't be a problem.
Most likely SW can get the Roman 909 for me but I not sure that I want them to.
Martin.
Old 11-08-2012, 08:14 PM   #5
kozmo's Avatar
Trade: commercial/residential wall cover/wall paper hanger/remover
i like R-35
kozmo is offline
Old 12-09-2012, 02:34 PM   #6
ProWallGuy's Avatar
Roman's 909 sucks. I've used it a few times recently and found no benefits of using it whatsoever.
Old 01-17-2013, 08:38 PM   #7
zorikos's Avatar
Trade: Painter
Rewards Points: 22
Roman pro-997 ultra prime
zorikos is offline
Old 05-12-2013, 08:51 PM   #8
salmangeri's Avatar
Trade: Painting and wallpaper contractor
Have been using Gardz for years with great results....also great for damaged drywall.....only problem I see is the odor.....but not have found a product that performs as well and while the odor doesn't bother us as we use masks....it is not good to use on certain jobs....case in point.we were doing a rewallpaper in a JC Penny photography studio during the day and the smell was bothering the customers on the main sales floor...
salmangeri is offline
Latex Primer over Poly Urethane?? DemRem Painting & Finish Work 32 08-19-2012 03:32 PM
B I N primer delamb harness Painting & Finish Work 17 11-04-2011 07:25 PM
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 08:39 PM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 06:39 AM
Primer questions rebar17 Painting & Finish Work 14 10-25-2007 08:51 PM
