Stucco On Wallpaper... The Best Solution For Residential Buildings. - Wallpaper - Contractor Talk
Old 06-12-2012, 12:20 AM   #1
aulona's Avatar
Trade: Painter
I dont know if you guys have heard/tried this way but i was amazed when i first saw stucco sprayed on top of wallpaper.
I have a few apartment building contracts. The management wanted to replace the old wallpaper but they were surprised when they found out 30% of the walls had mold. We had to replace the drywall and they did not have the budget to do so.
They were pushing me to find another solution which i knew it would have been short term and a waste of money.
I remembered i had visited another building 2 years ago and they had some type of stucco on their hallway walls. It was actually designed to look like marble colors.
Went back and asked if they could give me the number of the contractor who did it.
I hired him on the spot.
He would use normal stucco spraying machine rented from home depot and mix the powder with paint not water. Three colors would do the trick. You could use flat oil or Semigloss oil.
He didnt ever remove the wallpaper. I was a master in spraying though.
Walls can not be scratched or marked anymore, it looks uniform and very cost and time effective.
HAVE YOU EVER HEARD OF THIS BEFORE?
aulona is offline
Old 06-12-2012, 12:26 AM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: Stucco On Wallpaper... The Best Solution For Residential Buildings.
its past my bed time good night ayall.
sunkist is offline
Old 06-12-2012, 03:15 AM   #3
RareRenovations's Avatar
Trade: General Carpentry
Rewards Points: 75
Encapsulating mold forcing it to grow farther back behind the walls in an apartment building where tenants, entitled to a safe environment, are led to believe that all is well. There is no sign of mold until it gets sucked up into an HVAC return and deposited in the apartment of a tenant with a severe allergy to mold spores. Very cost and time effective.
RareRenovations is offline
Old 06-12-2012, 10:23 AM   #4
aulona's Avatar
Trade: Painter
Yep. The office knows about it. I have no liability issues in this case. Walls are drywall covered by wallpaper. Hard to tell where mold is growing, unless you remove the wallpaper.
aulona is offline
Old 06-12-2012, 12:48 PM   #5
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
Stucco on wallpaper? Sounds like a hack job to me.
ProWallGuy is offline
Old 06-12-2012, 10:05 PM   #6
aulona's Avatar
Trade: Painter
Health wise Drywall is not a good solution either but industry promotes it because of low cost. In my opinion stucco is a good solution on damaged surfaces that will require more money to be replaces with drywall.
aulona is offline
Old 06-12-2012, 10:19 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,018
Nothing that just covers mold instead of properly removing it is a good solution.
Tinstaafl is online now
Old 06-14-2012, 11:46 AM   #8
ProWallGuy's Avatar
IMO most hack jobs are borne out of not having enough money to do something right.
Old 06-17-2012, 08:04 AM   #9
Frankawitz's Avatar
Rewards Points: 1,196
Boy the right thing to do is let people know, How any trades person could lower themselfs says a lot of what type of person they are
I would post in Facebook or some Public Forum and name the Apartments I would call Health Dept, A Contractor or tradesmen who can just cover up Mold and be fine with it says we have some who don't need to be working in the Trades
Frankawitz is offline
Old 07-22-2012, 08:41 AM   #10
artiospainting's Avatar
Trade: painting and cleaning
Rewards Points: 250
It will be interesting. To see if its discoverd were the fingers pont. The plaster pulling off the wallpaper. exsposing the mold. blaming the contractor is posable.Apartment manigment always looks for the cheepist way out. tenits look for excuse they were victamized. Dont get looped in to cheep apartment manigment.Theres slow and theres steping backwerds. Thats way back.
artiospainting is offline
Old 07-23-2012, 02:30 PM   #11
kozmo's Avatar
Trade: commercial/residential wall cover/wall paper hanger/remover
wow sounds like a mess to me, should have removed the wall cover and addressed the mold, now the stuff is locked in eating the building from the inside out. very bad building management! the cost in the long run are gonna be tremendous, and whomever is in this building on a daily basis is probably sick and don't know why........very bad decision, these are the things which keep putting negative stigma's on general construction and those who do it
kozmo is offline
Gutter Hangers in Stucco Wall go_hercules Construction 8 05-23-2012 12:37 AM
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 10:22 AM
Why Haven't These Buildings Toppled? Tim Garrison PE Framing 99 11-10-2009 09:25 AM
New stucco meeting up with old MichaelNY Masonry 3 11-13-2008 07:25 AM
