Steamer Or DIF - Wallpaper - Contractor Talk
Steamer Or DIF
Old 01-02-2015, 02:16 PM   #1
straightedgellc's Avatar
Trade: painting
Rewards Points: 224
Steamer Or DIF
I have been using the gel DIF for removing wallpaper. It works good but it is messy...Has anybody had any good luck with a steamer?
Straight Edge Painting LLC
House painting Jacksonville FL
straightedgellc is offline
Old 01-02-2015, 02:17 PM   #2
Trade: painting
Rewards Points: 224
Re: Steamer Or DIF
And I mean an industrial steamer not just a little home version! lol
Old 01-02-2015, 06:20 PM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: Steamer Or DIF
i have a earlex steamer for wall paper removal and love it, can not remember the last time i used diff
sunkist is offline
Old 01-02-2015, 07:24 PM   #4
Lugnut1968's Avatar
Trade: Painting and Finish Carpentry
Rewards Points: 460
Re: Steamer Or DIF
For me it comes down to simplicity and time. I can take someone who is not skilled they can remove the paper easily and rather quickly with the DIF Gel by Zinsser.. put a steamer in their hands and they move at a snails pace. So I prefer the Gel over the steamer any day. Sure, it's a little messier than a steamer but I am putting down plastic/builders paper either way so the mess is manageable.
Lugnut1968 is offline
Old 01-03-2015, 06:12 AM   #5
Trade: painting
Rewards Points: 224
Re: Steamer Or DIF
Thanks for the information guys. I heard wallpaper is making a comeback so at least this will be more job security in 10-20 years when it needs to come off again! lol
Old 01-03-2015, 08:31 PM   #6
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 3,106
Re: Steamer Or DIF
I feel a steamer is the last resort. Strip the paper off in two layers if possible, first remove the facing dry and then use diff on the backing.
I know I am hanging more paper each year, bring it on.
Ohio painter is offline
Old 01-04-2015, 09:26 AM   #7
Trade: painting
Rewards Points: 224
Re: Steamer Or DIF
Just don't use Super Glue when hanging that paper, I swear some people do!
Old 01-04-2015, 12:23 PM   #8
avenge's Avatar
Rewards Points: 364
Re: Steamer Or DIF
I've used regular DIF for as long as I can remember. I hate steamers. It used to be painters painted paperhangers papered. Paperhangers hated priming, so many times the walls weren't primed.
I've seen a few used contact adhesive on corners and edges.
avenge is offline
Old 01-05-2015, 07:16 AM   #9
Trade: painting
Rewards Points: 224
Re: Steamer Or DIF
Yeah aren't you supposed use that stuff called size on the walls. Not sure if I spelt it right
Old 02-01-2015, 12:10 PM   #10
Soon become PRO..
rimce44's Avatar
Trade: Painter and Decorator
Rewards Points: 18
Re: Steamer Or DIF
I use steamer as last resort. Always try and strip layer by layer. Wet it where functional and not use anything but water where I can.
rimce44 is offline
Old 02-01-2015, 12:22 PM   #11
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 354
Re: Steamer Or DIF
I don't do a lot but when I do I use a steamer and it works great. Even the cheap ones like the wagner from the depot work pretty good. I used to use dif but haven't touched it since I bought a steamer.
platinumLLC is offline
Old 02-01-2015, 12:24 PM   #12
Creter's Avatar
Rewards Points: 1,966
Re: Steamer Or DIF
Hot water in a pump sprayer and metal putty knife is all we ever use.
Wet Drywall Sponge the glue residue off.
Prime wall with this after repairing nail holes etc.
Creter is offline
Old 02-01-2015, 03:17 PM   #13
Lugnut1968's Avatar
Rewards Points: 460
Re: Steamer Or DIF
Have used a good bit of that SW primer... then I found this and use it when I do not use the Zinsser Cover Stain. Ya use that PrimeCoat2 by Zinsser and I bet ya won't use the SW brand again.
I have had some issues with the SW brand Primer bonding well when I have it tinted grey for red walls etc. Never had that issue with the Zinsser though. Have even had some of the salesguys tells me the SW brand is not supposed to be tinted anyway... dunno which ones to believe on that....
When you can think of yesterday without regret, and of tomorrow without fear, you are on the path to success.
Matthew 7: 13&14? The straight and narrow path might be wider if more people used it.
What tile project are you working on? HS345 Tiling 4098 09-27-2020 06:27 PM
Looking for a Steamer Pinkape404 Pest Control 1 12-03-2014 04:38 PM
Old Steamer thorroofer Pressure Washing 2 08-18-2009 01:13 PM
Commercial Grade Wallpaper Steamer Tom Rohland Wallpaper 3 01-06-2006 04:17 AM
Wallpaper steamer? Humble Abode Painting & Finish Work 4 07-08-2005 10:57 PM
