Primer For Wallpaper - Wallpaper - Contractor Talk
Old 01-16-2018, 02:20 PM   #1
dnj300's Avatar
Trade: painting/paper hanging
Rewards Points: 14
Hello.. Im doing a commercial vinyl job. Previous wallpaper isn't being removed(against my advice) so I need recommendations for best primer to apply to the old wallpapered walls. Would 2 coats of r35 be good enough? Previous wallpaper is in good shape.
Thanks in advance.
dnj300 is offline
Old 01-16-2018, 03:13 PM   #2
avenge's Avatar
Rewards Points: 302
Re: Primer For Wallpaper
Need to know type of existing paper. If it's vinyl over vinyl, VOV adhesive no priming needed.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
overanalyze (01-17-2018)
Old 01-16-2018, 03:16 PM   #3
dnj300's Avatar
Rewards Points: 14
Some rooms vinyl some not. Hanging 54inch with vov seems like it'd be a pain in the ass, no?
dnj300 is offline
Old 01-16-2018, 11:30 PM   #4
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,976
I am not a commercial paper hanger, residential only. I would be thinking twice on hanging over old paper, i have done it and never been satisfied. Never ever again! I know you said you advised them not to. The problem i see becomes "i said not to but went ahead and done it anyway". But got to feed the family.
To be honest is putting primer over the old paper really going to make a difference? Does the new paper have to be pasted and allowed to book? some commercials do and some don't as i understand it, if not then VOV direct to the wall may be an option.
I think hanging over vinyl will be a pain in the a$$ as only vov will stick to it.
I know Roman will say do not dilute vov.
Good luck on this one, have good contract language addressing no warranty.
Ohio painter is offline
Old 01-17-2018, 08:10 AM   #5
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
You have to figure out the best way to do the job. If they don't want to to it your way then leave it alone and let someone else absorb their problems.
RangoWA is offline
Old 01-17-2018, 08:18 AM   #6
dnj300's Avatar
Rewards Points: 14
I agree in principle, do it right or not at all. Would prefer the walls be stripped, prepped properly, and then I hang paper. I have told the gc that is the right way to go but he is trying to save time and money.. I'm willing to hang over the old paper, just looking for advice on primer I should use to ensure the new paper doesn't pull the old stuff off.
dnj300 is offline
Old 01-17-2018, 08:40 AM   #7
RangoWA's Avatar
Trade: General
I understand. You are willing to help the GC save a buck and are willing to eat it if it goes wrong. I never accept work like that, one time will hurt. I run my business, nobody else.
It's always risky to do new work over old work without doing the proper prep work. Wallpaper fails at some point, when the bottom layer fails, and covering it might facilitate it, then the top layer is going with it.
RangoWA is offline
Old 01-17-2018, 08:57 AM   #8
dnj300's Avatar
Rewards Points: 14
I hear ya.. Hate to walk away from a big job and potentially good contact for future business. If I can find a way to do it without a major problem Id like to. I have been clear that I'm not responsible if there is a failure of the underlying paper. I'm not doing the prep on the walls, they are. I'm just hanging the paper. I do see your point tho.
dnj300 is offline
Old 01-17-2018, 09:23 AM   #9
RangoWA's Avatar
Trade: General
I'm not doing the prep on the walls, they are. I'm just hanging the paper.k
You really should exclude yourself from any potential liability in the contract. He said/he said probably won't cover it.
RangoWA is offline
Old 01-17-2018, 10:12 PM   #10
To prevent the new paste from loosening up the old paper I would suggest priming over the old paper with SW Shellac primer. But then that may prevent the paste from gripping. This is one of those situations where you solve one problem and create another.
Old 01-17-2018, 11:00 PM   #11
avenge's Avatar
Rewards Points: 302
Priming is prep, so if you're not taking responsibility for failure of the underlying wallpaper, well you kind of are seeing that you're choosing the primer and applying it.
avenge is offline
Old 01-18-2018, 07:07 AM   #12
dnj300's Avatar
Rewards Points: 14
Convinced gc to remove existing wallpaper, so no worries. Appreciate the input though.
dnj300 is offline
The Following 2 Users Say Thank You to dnj300 For This Useful Post:
Easy Gibson (05-29-2018), r a s (01-18-2018)
Old 01-18-2018, 07:15 AM   #13
RangoWA's Avatar
Trade: General
Good move. At least he listens.
RangoWA is offline
Old 01-18-2018, 01:18 PM   #14
That's good. Roman 977 would now be my primer of choice, but I know you are not asking.
Old 01-18-2018, 03:27 PM   #15
dnj300's Avatar
Rewards Points: 14
Thanks. You prefer that over r35?
dnj300 is offline
Old 01-18-2018, 11:07 PM   #16
Yes I prefer it over R35, I think the 977 grips the paper better once seams are matched and I am smoothing out the paper, maybe it is my imagination. Commercial has to be a different kettle of fish than residential though.
Old 01-19-2018, 09:14 AM   #17
dnj300's Avatar
Rewards Points: 14
I've always used r35 for residential.. Maybe I'll give 977 a try.
dnj300 is offline
The Following User Says Thank You to dnj300 For This Useful Post:
Ohio painter (01-19-2018)
What exactly is the Difference between Drywall Primer and All Purpose Primer? RMDailey Painting & Finish Work 14 01-20-2017 08:02 AM
oil primer under Proclassic Ohio painter Painting & Finish Work 1 10-11-2013 08:45 AM
Best Waterbased Primer - Sanding - TBFGhost Painting & Finish Work 5 04-01-2013 08:19 PM
A Shiba Inu Primer hdavis Off Topic (Non Trade) 7 12-20-2012 07:37 PM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 06:39 AM
