Paper Removal - Wallpaper - Contractor Talk
Paper Removal
Old 01-11-2012, 05:56 PM   #1
boman47k's Avatar
Rewards Points: 2,006
Paper Removal
Any reason this steamer cannot be used for paper removal? Maybe attach a different end to place on the wall.
boman47k is offline
Old 01-11-2012, 05:57 PM   #2
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Re: Paper Removal
It would take forever. You usually can only remove as wide an area as your steamer at one time.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 01-11-2012, 08:50 PM   #3
boman47k's Avatar
Re: Paper Removal
Thats why I mentioned a different end for it.
I have never tried steam for paper removal. I am not sure of the learning curve. I do know not to get close to anything you do not want damaged by the steam. I removed a tiny bit of finish from a 1903 Murphy bed (mine) by having this thing a few inches from the bottom of it.
A boxed end would eliminate some of that I think.
Then again, maybe I should stick to the pump sprayer and scrapers.
Thanks.
boman47k is offline
Old 01-11-2012, 10:14 PM   #4
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Re: Paper Removal
I'd be interested to find out what kind of results you get.
tedanderson is offline
Old 01-12-2012, 06:42 AM   #5
faithstep's Avatar
Trade: Commercial painter
Re: Paper Removal
My company has done a ton a wallpaper removal - nursing homes. Do yourself a favor and buy a product DIF. It is an enzyme that loosens the paste. Get a bug sprayer and get the water as hot as you possibly can. Spray the crap out of it and give the product time to work. I spray it again right before I'm ready to get top coat off. Then try to peel the top layer off in one solid sheet. A backing will be left. Spray again. The backing using falls right off. Some of the tougher jobs I have sprayed as many as 10 times. Buy DIF at SW.
Steamers will take you forever.
faithstep is offline
The Following User Says Thank You to faithstep For This Useful Post:
Ohio painter (02-15-2016)
Old 01-12-2012, 09:08 AM   #6
Robinson_Cnst's Avatar
Trade: general contractor
Rewards Points: 109
Re: Paper Removal
He is 100% correct. That is the only way to strip it. I have done miles upon miles of paper removal. Just let the striper do the work we say.
Robinson_Cnst is offline
Old 01-12-2012, 09:29 AM   #7
Hair Splitter
Trade: General
Re: Paper Removal
So you guys are saying that spraying a wall 10 times to get the paper off is faster and easier than plugging in a steamer, waiting all of 5 minutes and pulling paper down right away?
With a steamer you get not only the paper, but the backing off at the same time. My steamer is about 12" wide, so I can take down a ceiling to floor strip, 12" wide, in about 2 minutes.
We just stripped a large laundry room (12x8) in about 2 hours. All we had to do was scrape off some loose garbage and start our wall prep.
Old 01-12-2012, 09:32 AM   #8
boman47k's Avatar
Re: Paper Removal
I have removed paper in the past. I always used the bug/garden sprayer. That being said, I am not sure I could ever tell if Dif gave any advantage over plain water.
boman47k is offline
Old 01-12-2012, 09:37 AM   #9
boman47k's Avatar
Re: Paper Removal
Thanks. Don't know why there is no thanks button at the bottom of your reply. Everyone else has one on my screen.
Anyway, got a pic of your steamer? Is it similar to the one I have?
Is using a steamer neater than using a sprayer?
I would be interested in getting or making and end for mine that would cover more area and experiment with it until I could remove paper and not damage the wall.
Mine came out of a clothing store.
boman47k is offline
Old 01-12-2012, 09:44 AM   #10
boman47k's Avatar
Re: Paper Removal
Do you perforate the paper at all? I always did. Actually, I will cut it with my utility knife. This tends to make for a lot of smaller pieces. And no, for the most part, I do not cut the drywall, paneling, etc.
boman47k is offline
Old 01-12-2012, 12:40 PM   #11
Hair Splitter
Trade: General
Re: Paper Removal
I have an older B&D model, probably 20 years old. Heats up real fast. I have purchased one recently and it took 15 minutes to warm up and didn't do nearly as good a job.
I will try and post a pic of it and find the model number for you.
As far as scoring the paper, you have to be careful, it can cause more harm than good to the drywall underneath. Another reason I prefer steam.
Old 01-13-2012, 09:55 PM   #12
faithstep's Avatar
Re: Paper Removal
No. They are just trying to sell a tool that makes it more difficult. You want to get the paper off in one piece or as big of pices you can. Those scorers just make it more time consuming as you have LOTS pieces to get off. There is no fun in removing wallpaper and every job is different. Trust a steamer is too slow. Use the heck out of the DIF and it will work. If it a difficult job use more DIF. I feel for you.
Old 01-14-2012, 11:38 AM   #13
Hair Splitter
Trade: General
Re: Paper Removal
He is right, if you don't have a good steamer and know how to use it. Much slower than DIF. If you do know how to use it, much faster and cheaper. You never have to waste your money on DIF! A steamer pays for it self after a few jobs.
Old 02-15-2016, 04:50 PM   #14
Wild Blue's Avatar
Rewards Points: 12
Re: Paper Removal
Did you score the wallpaper with a paper tiger "before" you applied DIF to the outside of the wallpaper?
Wild Blue is offline
Old 02-15-2016, 05:48 PM   #15
avenge's Avatar
Rewards Points: 304
Re: Paper Removal
Ya he scored it 4 years ago, he's still working on it.
avenge is offline
Old 02-17-2016, 03:08 AM   #16
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
Re: Paper Removal
http://www.safeandsimple.com/
chris n is offline
wall paper removal over hardwood floors citteee Wallpaper 4 04-10-2009 09:26 PM
wall paper removal Spice Wallpaper 7 08-20-2008 11:24 PM
Removal of paper border a nightmare davidanbess Painting & Finish Work 13 02-23-2008 07:17 PM
Sheet rock down to brown paper backing, botched wallpaper removal? atv71 Drywall 33 09-07-2007 11:38 AM
commercial wall paper removal rservices Wallpaper 1 06-28-2006 08:58 PM
