Oil Primer Or Water Based No Peel - Wallpaper - Contractor Talk
Old 07-26-2018, 11:21 AM   #1
mctwentytwo's Avatar
Trade: carpenter
have wallpaper took forever to get down last time layer upon layers upon layer 1 owner from
1966 so im
down to final
layer its on there good would damage wall, before i skim
coat am i better using oil
based primer
or the peel
stop
water based, have heard mixed reviews
mctwentytwo is offline
Old 07-26-2018, 01:05 PM   #2
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,220
Re: Oil Primer Or Water Based No Peel
Zinzer gardz
Idothat is offline
Old 07-26-2018, 01:49 PM   #3
Trade: carpenter
that cant be better than peel stop see no difference??
Old 07-26-2018, 01:56 PM   #4
Idothat's Avatar
Not familiar with peel stop. If it's designed for the application,I'm sure it's fine. I usually use a fast dry oil primer in situations like that because I probably already have some on the truck. But , everything needs to be good and dry
Idothat is offline
Old 07-26-2018, 01:58 PM   #5
Trade: carpenter
but hardz is water based
Old 07-26-2018, 02:04 PM   #6
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 4
Get some oil based like Cover Stain to seal it up and get it ready to float/texture before painting. Peel Stop is designed to glue down peeling paint issues.
dsconstructs is offline
The Following User Says Thank You to dsconstructs For This Useful Post:
Idothat (07-26-2018)
Old 07-26-2018, 02:37 PM   #7
Idothat's Avatar
Yeah gardz is water based but it is designed to seal torn paper on drywall
Idothat is offline
Old 07-26-2018, 02:46 PM   #8
Idothat's Avatar
I will say an oil stain killing primer ,cover stain,etc.., is less likely to blister any loose or torn paper and will seal any glue residue
Idothat is offline
Old 07-26-2018, 02:59 PM   #9
Idothat's Avatar
Wait a minute here, are you saying that you don't plan on removing the final layer of wall paper. If so , I would definitely use an oil based stain killer to prevent the old paper from blistering.
Otherwise any thing that will seal up the glue residue will work
Idothat is offline
Old 07-26-2018, 04:37 PM   #10
Trade: carpenter
yeah im
not
gonna
remove the last layer of wallpaper so im def thinking cover stain
Water Based Stain philcav7 Painting & Finish Work 4 04-23-2017 06:25 PM
Oil based vs.latex primer for exterior Kempfe Painting & Finish Work 10 07-02-2015 10:16 AM
Water based poly over latex? GODZILLANINJA Painting & Finish Work 8 08-23-2014 07:13 AM
Ice and Water Shield over XPS Lakesidex General Discussion 8 08-15-2012 11:17 PM
B.Moores fresh start water based primer painterofeveryt Painting & Finish Work 9 12-17-2007 10:55 AM
