Need Advise On Removing Wallpaper - Wallpaper - Contractor Talk
Old 08-28-2014, 07:59 PM   #1
tonyc56's Avatar
Trade: Window Treatments
Rewards Points: 3,884
I've tried using DIF with little success. I'm going to try a steamer next. If the steamer doesn't work what other options are there.
tonyc56 is offline
Old 08-28-2014, 08:27 PM   #2
dan-the-man's Avatar
Trade: Apprentice Plumber
Rewards Points: 195
Re: Need Advise On Removing Wallpaper
Warm water and white vinegar, piranha wallpaper remover, those are the only two that I have used. They make a tool that scores the paper, you may find some luck in that first then use a product. If its vinyl based wall paper good luck that is so hard to get off.
dan-the-man is offline
Old 08-28-2014, 08:30 PM   #3
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
I'm gonna try wallpaper remover in a sprayer. SW says their paint guys swear by it. Leave it on the surface for 30mins and keep surface damp.
I'm picking up the festool wallpaper tool for a job I have coming up.
www.bcconstructionllc.com
BCConstruction is offline
Old 08-28-2014, 09:04 PM   #4
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 342
FIL is a paint contractor. That's how he does it and now we do as well. Just a pump garden sprayer and keep it wet for a while. We have the little hand held scoring tools. My bro texted me a photo of the Festool one last time he was stripping wall paper cause it takes so long with the small things.
Let us know how that Festool one works out for you cause we strip paper quite a bit around here.
Xtrememtnbiker is offline
Old 08-28-2014, 09:11 PM   #5
jb4211's Avatar
Rewards Points: 2,306
I bought a Wagner streamer from HD: $50
Worked great. Best money I ever spent.
I didn't actually do the removing, my helper did. But it was super easy. He used the steamer and a 6" taping knife.
Jon
jb4211 is offline
Old 08-28-2014, 09:35 PM   #6
SouthonBeach's Avatar
Rewards Points: 1,165
Haven't found a wallpaper yet that wouldn't strip with steam. I know some of the strippers out there work faster, but when over half the time I need to strip it off they never prepped it right in the first place and the steam will work. The most miserable is wallpaper directly to bare Sheetrock.
SouthonBeach is offline
Old 08-28-2014, 09:43 PM   #7
tjbnwi's Avatar
Rewards Points: 4,738
Downy fabric softener.
My sister has the Festool scorer, it's the only thing that went through the multiple layers of paper. It can be set to score to a precise depth. Trying to convince her to send it to me now that she is finished with it.
tjbnwi is online now
Old 08-28-2014, 09:45 PM   #8
Rewards Points: 195
I second the sprayer, works very well. Like BCC said keep the chemical on the walls to let it cook them glue off.
Old 08-28-2014, 11:05 PM   #9
VinylHanger's Avatar
Rewards Points: 13,476
I like the steamer myself. However, if you have wood floors or bare trim, you need to watch the water.
VinylHanger is offline
Old 01-14-2016, 07:00 AM   #10
Wrenched's Avatar
Rewards Points: 22
Believe it or not I had a remodel job one time where the wallpaper had to be peeled off a little at a time. Nothing I tried worked. It had been on there so long it was almost a part of the wall. Then the glue had to be sanded off. What a mess.
Wrenched is offline
Old 01-14-2016, 07:11 AM   #11
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
If you can close the room off, fire up a steamer, open the petcock, and let er buck for awhile. I've stripped more paper than I want to admit that way. Just find an old carpet scrap to set the steamer on.
mnld is offline
Old 01-14-2016, 12:44 PM   #12
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,976
We strip plenty of paper. Standard procedure for me is as follows:
Try to strip face layer from the backing, done dry and if reasonable progress is made then continue.
If progress is too slow then we score the paper and apply remover - usually DIF. Keep it wet, usually wet every 10 - 15 min for as long as we need to. Be patient and let DIF work.
Now try to scrape off the face layer.
Once face layer is off soak backing with DIF and strip the backing.
Then soak walls again and use a scouring pad to remove glue.
Wipe down walls until clean and not slick.
Stubborn paper will get use of a 4" razor knife, causes a bit more damage but repairable.
Never had to resort to a steamer. I would think they are too slow.
Stripping paper can be real work.
Ohio painter is offline
The Following 2 Users Say Thank You to Ohio painter For This Useful Post:
overanalyze (08-03-2016), Sleepinggiant (01-20-2017)
Old 01-14-2016, 03:53 PM   #13
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
I remember back in 09 i was doing a floor and there was a painter in there after me with two helpers. They stripped, prepped, and painted the whole house interior for 1600.00. The guy said he didnt want to do remodel work because you always had to buy another tool and it was too expensive. Whiskey tango foxtrot.
Metro M & L is offline
Old 01-21-2016, 10:01 PM   #14
Bearpau's Avatar
Trade: Retail / commercial
Rewards Points: 26
Thumbs up
I know this is an old thread but fabric softener works good
Bearpau is offline
Old 01-21-2016, 10:35 PM   #15
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
We use vinegar, fabric softener and hot water
Anderson is offline
Old 01-22-2016, 07:10 PM   #16
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
I own a EARLEX steamer its the only way to go
sunkist is offline
Old 02-14-2016, 09:37 AM   #17
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
http://www.safeandsimple.com/
It's the ONLY way to go
chris n is offline
Old 05-25-2016, 10:47 AM   #18
CRTR's Avatar
Trade: Painter
Rewards Points: 42
We have always used a steamer and a 4 inch putty knife. if you don't have a steamer then warm water and lots of it.
CRTR is offline
Old 05-25-2016, 09:22 PM   #19
It's been two years since he asked, I would imagine he has figured it out by now.
The Following User Says Thank You to Ohio painter For This Useful Post:
chris n (06-04-2016)
Old 08-01-2016, 04:58 AM   #20
Big Shoe's Avatar
Rewards Points: 2,122
I'm dealing with some tough paste right now. No access to hot water. Going to use microwave to heat it up today. Thought about bringing my camp stove too.
At least the walls were sized for once paper falls right off.
Did one room last week. Glue took two soakings with water to remove. Going to try piranha or dif today plus hot water.
Also the thought entered my mind to try my PC sander/vac with 80 grit.
Mid 80's glue.
Expect the Unexpected
Big Shoe is offline
Removing painted over wallpaper Rustbucket Wallpaper 12 01-18-2014 09:08 PM
Ornamental Plaster (Removing Paint) Jason Whipple Painting & Finish Work 4 09-23-2012 07:55 PM
Easily removing Wallpaper !!!!!YUCK!!!!! PaintedLady Specialty Coatings 13 04-19-2011 05:32 PM
