Laser For Wallpaper - Wallpaper - Contractor Talk
Laser For Wallpaper
Old 02-20-2016, 08:17 PM   #1
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,958
Laser For Wallpaper
How many of you are using lasers for hanging wallpaper?
I must be old school, I mark a plumb line for hanging first strip, hang the first strip with the pattern how far I want the key feature from the ceiling.
I then mark a new plumb line for turning each corner.
I seem to be reading more about the use of lasers for wallpaper, nothing wrong with it but I am not picking up on any advantage.
I also read of them being used to mark out a horizontal line around the room. The way I see it, if the first strip is plumb and you match the pattern perfect every time why do you need a horizontal reference line.
I can see it as an advantage for those papers where the pattern does not run off the edge of the paper so you have no reference to match up each strip. But that is not the examples given for their use.
What am I missing? Maybe someone will convince me I need to be using them.
Ohio painter is offline
Old 02-20-2016, 08:18 PM   #2
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 15,166
Re: Laser For Wallpaper
They still make wallpaper?
A&E Exteriors is online now
The Following User Says Thank You to A&E Exteriors For This Useful Post:
m1911 (02-20-2016)
Old 02-20-2016, 10:45 PM   #3
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Yes, thanks to these "interior decorators."
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
A&E Exteriors (02-20-2016)
Old 02-20-2016, 11:13 PM   #4
haha oh yea I hang a fair bit.
The Following User Says Thank You to Ohio painter For This Useful Post:
Old 02-20-2016, 11:15 PM   #5
I hate stripping it.
Old 02-20-2016, 11:18 PM   #6
m1911's Avatar
m1911 is offline
Old 02-20-2016, 11:41 PM   #7
avenge's Avatar
Rewards Points: 298
I don't see a need for a laser just for wallpaper. Would I use mine? Maybe.
Wallpaper is making a slow comeback in this area but I haven't hung any in about 10 years, hardly anyone stocks it....thank you.
avenge is offline
Old 02-21-2016, 08:51 AM   #8
I am hanging more each year, but still it only makes up a small portion of the interior work we do.
I would be happy just hanging paper but no way there is that kind of demand.
I haven't hung border in years, 10 years ago border was going up on almost every paint job.
Old 02-21-2016, 09:49 AM   #9
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,753
You say you just draw a plumb line. Well, you need a level and a pencil to do that. Levels are big. A PLS laser is pretty small. Turn it on and there's your line. It'll fit in a small pouch. Need another line, click, point, there it is.
Might be spendy to have it for this purpose. But if you can use it for other tasks then you might as well use it for wall papering.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 02-22-2016, 02:54 AM   #10
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
I'm with you, I had a laser and never used it.
chris n is offline
Old 02-22-2016, 05:02 AM   #11
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,496
I use a Bosch laser for it. We hang custom graphics murals a few times a year. Easy to keep moving the line or tweak it a bit.
overanalyze is offline
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
chris n (02-26-2016), Ohio painter (02-27-2016)
Old 02-27-2016, 02:57 PM   #12
Always Learning
This was this week at an install. Had approx 900 sq. Ft. of paper to hang. I don't even bring a regular level with me anymore. This is a Bosch GLL2-50. Only complaint is the line width is a bit thick for my liking but I just choose one side of the line to follow.
Old 02-27-2016, 03:29 PM   #13
VinylHanger's Avatar
Rewards Points: 12,984
A small Bosch is only around 100 bucks. Well worth just to have in the tool bag.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 02-27-2016, 06:51 PM   #14
Overanalyse, I see that level sits on the floor, does it center itself or level itself, am I saying that right? Also how far away will it project a decent line? I can appreciate using one side of the line.
I am so unfamiliar with these that I expected the laser to be mounted on a tripod.
Let's say I wanted a plumb line 20" from a door jamb, if I am across the room trying to get a laser line onto a pencil mark is it a exercise of frustration? I can see me moving the laser line left and right of the pencil mark and never get it where I want it.
I have seen lasers that a mounted to the wall with pins, those clearly wouldn't work for papering.
Old 02-27-2016, 07:13 PM   #15
Always Learning
It projects easily 35' or more. This was a narrow hallway so the floor worked best. I just kept moving it for each tile we hung. I make the seems look good but still like a guide when installing digital prints.
It is self leveling. You can mount it to a tripod as well. The thread matches common camera tripods. Also there is a very strong magnet on the back of the base so I will stick it to a metal door jamb or even metal corner bead sometimes.
Also you can use a FastCap third hand pole and stick it to that with the magnet.
Fine tuning isn't terrible but to move the line a tiny amount does take a little playing with.
That said I wouldn't hang paper without one now. I only install digital prints so maybe installing regular residential paper would be different. Everything I hang is heavy duty commercial grade fabric backed vinyl. I am pasting the wall not pasting and booking the paper.
Old 02-27-2016, 08:25 PM   #16
Always Learning
Another thing for me is a lot of our walls we paper are 9' or even some as high as 35' tall. At that height a 4 or 6 foot level just isn't practical.
This wall @ FL was approx. 16' high. The laser on tripod was perfect.
In real high walls we will laser the wall and pencil line the top and bottom and then snap a line. This way we don't have to worry about scaffold or the lift being in the way.
Ohio painter (02-27-2016), r a s (02-27-2016)
Old 02-27-2016, 09:07 PM   #17
Last week I was hanging 12' walls built in 1875, I was thinking a laser might have been easier.
Thanks.
Old 02-27-2016, 09:44 PM   #18
I finesse it by just touching it with my finger and rolling my fingertip. Once you get used to it, you can make tiny adjustments.
Ohio painter (02-28-2016)
Laser levels FinishingEdge Tools & Equipment 15 05-26-2013 11:45 PM
Dependable Laser erhelm83 Tools & Equipment 11 04-17-2013 07:24 PM
I need a laser mechine to cut black rock ranil General Discussion 3 11-19-2012 09:17 PM
Laser repair? Warren Tools & Equipment 12 03-19-2012 08:12 PM
