Dried Paste Removal - Wallpaper - Contractor Talk
Dried Paste Removal
Old 10-31-2016, 06:27 AM   #1
MattDixon's Avatar
Rewards Points: 2
Dried Paste Removal
Hi all,
Here is my problem the 3 story medical office building that I run was built 3 months ago and the paste is all over the walls on all 3 floors. the wall covering company used ROMAN PRO 555. clean up instruction says maybe hard to remove dried paste blahahha..
I've tried hot water and Dawn soap, and goof off, I'm concerned that ill take the shine off the walls if I get to aggressive. Any ideas ill work a small spot till I get is figured out..
MattDixon is offline
Old 10-31-2016, 06:58 AM   #2
MikeFL's Avatar
Trade: Engineer
Rewards Points: 200
Re: Dried Paste Removal
Assuming you're talking about wallpaper paste, have the hanger come back. You probably have to go through the GC to make that happen.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
MikeFL is offline
Old 11-01-2016, 08:24 PM   #3
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 3,106
I agree Mike, if the paste on the finished wallpaper surface then get the hanger back there to correct it.
Ohio painter is offline
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
Exterior Rough Sawn Poplar - Kiln Dried vs Air Dried artinall Windows, Siding and Doors 9 06-14-2012 08:41 PM
coating removal bassinhunter Pool Construction & Enclosures 0 03-10-2012 12:28 PM
removal of dried mastic on shower pan bernie Tiling 2 10-30-2010 09:41 AM
Dried roller cover removal? steve-in-kville Painting & Finish Work 17 04-12-2007 07:26 AM
