Bubbles - Wallpaper - Contractor Talk
Bubbles
Old 05-21-2014, 09:16 AM   #1
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
Bubbles
Hey guys,
So I had a wallpaper crew install some very expensive wallpaper in two bathrooms for me. About 2 days later a few bubbles appeared. I was thinking of slicing with a razor then injecting glue with the sering. Its been about a month now since it was first installed any suggestion?
Pbpaints is offline
Old 05-21-2014, 09:29 AM   #2
jb4211's Avatar
Rewards Points: 2,306
Re: Bubbles
Just one suggestion: call the installer and explain your issue.
Jon
jb4211 is offline
Old 05-21-2014, 08:18 PM   #3
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
Re: Bubbles
Thanks man I called him this afternoon, waiting for a call back.
Pbpaints is offline
Old 05-23-2014, 06:02 PM   #4
avenge's Avatar
Rewards Points: 298
Re: Bubbles
If it was prepasted and he didn't use paste then there may not have been enough paste on it or he didn't let it soak long enough. The paper bubbled when it dried because there's no glue to hold it.
I always pasted my wallpaper even when prepasted.
avenge is offline
Old 05-24-2014, 09:17 AM   #5
Skyvorima's Avatar
Trade: Residential Remodeling
Rewards Points: 635
Re: Bubbles
Originally Posted by Pbpaints View Post
Hey guys,
The bubbles could be from too much paste, surface contaminates, not enough paste or the shower could have been used prematurely and the steam lifted the paste before it could properly cure. The installer should correct this at no charge with a smile.
If the guy is a pita there are a couple of ways to correct it yourself but it depends on what kind of paper. Some papers should be moistened so corrections do not tear but some will wrinkle on intricate patterns if too much moisture is applied.
Find the smallest needle possible to release the pressure. There should be some paper left over so worst case scenario you can do a double cut and hide the lines with seam sealer. Use traditional blades and one cut per blade. May seem extreme but with expensive paper tossing a few blades out to ensure a seamless repair is golden.
Skyvorima is offline
Bubbles in refinished hardwood floor, smelling BS from my sub Ethos Flooring 60 02-20-2014 12:03 PM
Engineered air bubbles please help flooring question handyflooring Flooring 0 08-09-2012 06:29 AM
Bubbles RPtile Flooring 2 06-11-2011 09:37 PM
Bubbles in texture over painted surface uselessknowledg Drywall 2 02-26-2011 07:27 PM
Bubbles when taping over paint raven2006 Drywall 30 12-23-2007 04:39 PM
