Will Replacing A Glass Window Pane Solve The Issue Of Fogging Windows - Remodeling - Contractor Talk
Old 12-04-2014, 07:53 PM   #1
tonyc56's Avatar
Trade: Window Treatments
Rewards Points: 3,884
I was informed no need to replace my fogged up windows. All I would need is just to replace the glass panes and that would eliminate any future fogging. However, I do not understand once the window seal has failed how would a new glass pane resolve the fogging issue. I'm not a window expert but doesn't fogging indicate that the window desiccant has failed.
tonyc56 is offline
Old 12-04-2014, 07:58 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,554
Re: Will Replacing A Glass Window Pane Solve The Issue Of Fogging Windows
The glass in newer windows are replaceable. You would order an entire new insulated assembly.
overanalyze is online now
Old 12-04-2014, 08:04 PM   #3
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
I wouldn't do it. Your asking for trouble.
If the glass guys doing the work don't measure exactly right it will affect the way the window opens and closes. tight, loose, seal, etc.
I've repair broken windows this way, but sometimes they come back too tight or too loose.
Trying to do several windows would surely cause you several headaches.
Save yourself the trouble.
Order exact fit (custom ordered) replacement windows - way better way, imo
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 12-04-2014, 08:11 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,858
Huh?
Take the insulated glass part (just the glass part) to any glass shop they will make you the same size glass part.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
overanalyze (12-04-2014), thom (12-04-2014)
Old 12-04-2014, 08:16 PM   #5
CCCo.'s Avatar
Originally Posted by WarnerConstInc. View Post
Huh?
Any glass shop ... hah I don't hardly think soo ... they better be GOOD at what they do or you'll likely have trouble.
I had one done here at home and I couldn't hardly get the damn thing snapped in, and when I did. NO way in hell it would slide up.
Have a SIL that had a sliding glass window redone ... same company mind you (their local here) It never worked right again.
Sorry ... Been there done that ... Just asking for a PITA project.
Just replace them ... you get what you pay for!
CCCo. is offline
Old 12-04-2014, 08:32 PM   #6
I like Green things
Apparently my local glass shop owns a tape measure since they have done about 30 for me. Average glass panel in a double hung was about 45 bucks with argon and low e.
Warner Mill Works
Facebook
YouTube
thom (12-04-2014), TLC Remodeling (12-07-2014)
Old 12-04-2014, 08:36 PM   #7
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I've never had a problem with replacing the glass either. Just did 5 the other day, they all fit perfect. I dropped the sashes off, and picked them up a week later to install.
jlsconstruction is offline
Old 12-04-2014, 08:37 PM   #8
CCCo.'s Avatar
It would be my bet that they are just good at what they do. So they make it easy on you.
Doesn't take much to oversize one apparently. Doesn't seem to be much tolerance for error in my neck of the woods.
CCCo. is offline
Old 12-04-2014, 08:38 PM   #9
Thom
thom's Avatar
Rewards Points: 4,748
Making the correct size replacement glazing panel is no more difficult than making the correct size the first time. Really, this is pretty basic stuff. If a glass company can't handle something this simple they really aren't a glass company.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
The Following 3 Users Say Thank You to thom For This Useful Post:
66 Shelby (12-07-2014), overanalyze (12-04-2014), TimNJ (12-04-2014)
Old 12-04-2014, 08:42 PM   #10
hdavis's Avatar
Rewards Points: 2,186
It must vary by location - I can get them built to 0.01" all day around here.
hdavis is online now
Old 12-04-2014, 08:43 PM   #11
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i think even i could make them
Tom Struble is offline
Old 12-04-2014, 08:43 PM   #12
CCCo.'s Avatar
I never said you can't do - but I have had bad luck myself.
CCCo. is offline
Old 12-04-2014, 08:44 PM   #13
Always Learning
Hell I order them from my siding, roofing, window supplier and they are right on. CCCo you need to find a different source.
Old 12-04-2014, 08:47 PM   #14
CCCo.'s Avatar
I'd agree that I won't use them again.
Hell they even order them from someone else - but obviously can't measure.
I've met alot of idiots in the trades who couldn't measure, nothing new, live and learn, and move on.
CCCo. is offline
Old 12-04-2014, 09:27 PM   #15
VinylHanger's Avatar
Rewards Points: 13,478
Most small shop don't make them, but like me, they order them from a supplier/manufacturer. Overall size and thickness are the secret formula.
I am not sure how your glass guy could make them too big. If they fit in the frame, they are the right size, at the worst they are too small, but that doesn't effect the frame. If you are talking about aluminum frames and single pane glass, it still is nearly impossible to get them too big and still get the frame to screw together. Maybe it just wasn't square.
VinylHanger is online now
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacing exterior window Sill jradziew Carpentry 5 11-19-2009 06:53 PM
Glass block window bekind General Discussion 24 09-26-2009 08:03 PM
Replace Basement Window w/ Glass Block firemike General Discussion 7 08-19-2009 08:18 AM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 08:40 AM
