What Kind Of Window? - Remodeling - Contractor Talk
Old 03-29-2019, 08:56 AM   #1
Jmsmith716's Avatar
Trade: Home improvement
I want to give a quote on replacing a few windows. Only thing is how do I tell the difference between a replacement or nail gun window? Do I need to remove the siding to expose a fin if it’s there? I just don’t know if I need to quote for a replacement or a new construction window.
Jmsmith716 is offline
Old 03-29-2019, 09:30 AM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,560
Re: What Kind Of Window?
What type of window are in there now? Vinyl - wood ? That will determine what direction you can go. The siding does not have to be removed to install a window with a nail fin. Can be cut back and a trim board installed. Removing the siding can be a can of worms depending on siding type. Vinyl siding just remove , can properly flash that way. Retro fit windows are ok if done right , personally I prefer complete replacements. If it has vinyls now check and see if it has been screwed in place through the side of the window and capped on the outside.
Kind of sounds like you need to find someone that has a little more window experience to look at that things and help you out a bit for a while.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
SmallTownGuy (03-29-2019)
Old 03-29-2019, 09:40 AM   #3
Jmsmith716's Avatar
Right now there’s a vinyl double hung window in place. Home was built in 96’ which led me to believe it was a fun type window. I’ve put in a lot of replacement windows, just never had to replace any in a newer ish home. Thanks for the advice, if it is a new construction window I think I’ll just expose the siding and do it the right way.
Old 03-29-2019, 09:48 AM   #4
Randy Bush's Avatar
Originally Posted by Jmsmith716 View Post
Right now thereís a vinyl double hung window in place. Home was built in 96í which led me to believe it was a fun type window. Iíve put in a lot of replacement windows, just never had to replace any in a newer ish home. Thanks for the advice, if it is a new construction window I think Iíll just expose the siding and do it the right way.
When it is all said and done that will look the best. What type on siding is on it now?
Old 03-29-2019, 10:02 AM   #5
Lettusbee's Avatar
Rewards Points: 1,498
Finehomebuilding.com has a lot of good articles about this.
Jlconline as well
Sent from my SM-N960U using Tapatalk
Lettusbee is online now
Old 03-29-2019, 10:28 AM   #6
Jmsmith716's Avatar
They have vinyl siding on now. J channel right to the window.
Old 03-29-2019, 12:58 PM   #7
Randy Bush's Avatar
Pull the siding around them . Piece of cake. That way you can insure they are correctly flashed. Old ones broken or wore out?
Old 03-29-2019, 01:16 PM   #8
Jmsmith716's Avatar
Thanks for the help!
90 yr old window replacement? coworx Windows, Siding and Doors 3 04-26-2013 09:36 PM
First time ZackyBundles Drywall Picture Post 155 02-07-2013 08:11 PM
spraying stain on unfinished alder window frames girlspaint2 Painting & Finish Work 19 02-02-2013 10:45 PM
New construction Window bow/warp. Help typer0186 Windows, Siding and Doors 7 06-14-2012 09:38 AM
Basement window trim - best practice? FCCOH Construction 6 01-31-2011 11:32 PM
