Truss System And Removing Walls - Remodeling - Contractor Talk
Old 03-10-2019, 07:14 PM   #1
landonm11's Avatar
Trade: TRR Handyman
Rewards Points: 20
Hello all,
I purchased a home that was built in 76. It has what i believe to be a King truss system roof. Pics below. I plan on removing some walls and adding some walls lol. here are the pics of the floor plan it has now and what it will look like after the remodel.
Truss system and removing walls-old-snip.jpg   Truss system and removing walls-new-snip.jpg
landonm11 is offline
Old 03-10-2019, 07:19 PM   #2
landonm11's Avatar
Trade: TRR Handyman
Rewards Points: 20
Re: Truss System And Removing Walls
Here are the pics of the trusses.
Truss system and removing walls-53595892_1982510415391247_4154313834384850944_n.jpg   Truss system and removing walls-53830248_629694494138359_2128479384082841600_n.jpg   Truss system and removing walls-53739964_627694764349117_1512322160322936832_n.jpg   Truss system and removing walls-53674791_1031410620383453_8007710796744228864_n.jpg
Old 03-10-2019, 07:19 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 1,826
did you have a question?
griz is online now
Old 03-10-2019, 07:28 PM   #4
landonm11's Avatar
Trade: TRR Handyman
Rewards Points: 20
HAHA yes. The wall that i intend to remove is in the middle of the truss system. Directly under the center king post and gusset plate where the bottom cord attach together.
since it is a truss system roof. is it true that you can remove any walls from the interior with out fear of roof sag or worse collapse?
Old 03-10-2019, 07:37 PM   #5
Fire up the BBQ
griz's Avatar
all depends if it is a two point or three point bearing system.
griz is online now
Old 03-10-2019, 07:44 PM   #6
landonm11's Avatar
Trade: TRR Handyman
Rewards Points: 20
Okay, I'm so I guess my next step is to consult a structural engineer for that answer? Or is there a way to know for sure, without spending the money on an engineer?
Old 03-10-2019, 07:54 PM   #7
Fire up the BBQ
griz's Avatar
is there any place the trusses clear span or there isn't a wall under the center?
griz is online now
Old 03-10-2019, 08:06 PM   #8
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,188
It looks like the center wall is in a different place where your new kitchen island is going to be. So it probably only bears on the outside walls. But an engineer is the safe bet. Plus, the interior walls could be shear walls.
Looking below is another way to help determine if they are bearing walls.
Golden view is offline
asevereid (03-11-2019)
Old 03-10-2019, 11:39 PM   #9
landonm11's Avatar
Trade: TRR Handyman
Rewards Points: 20
sorry for the late responses had to get the kids to bed.
yes in the converted two car garage. they span just over 20 feet.
yeah, def going to have it looked at. but you said looking below? do you mean basement? it does not have a basement. i see what youre saying about the wall lining up in a different spot than center.
Old 03-11-2019, 01:17 AM   #10
hdavis's Avatar
Rewards Points: 1,656
If you can find the manufacturer, they may be able to tell you.
hdavis is online now
Old 03-11-2019, 08:42 AM   #11
Designer/Contractor
Rio's Avatar
Rewards Points: 1,704
The area where the kitchen island is could be spanned with a beam, engineer is definitely the safe bet, or removing all the insulation and carefully visually confirming if the bottom chord is attached to the center wall or is clear and attached with clips.
Rio is offline
The Following User Says Thank You to Rio For This Useful Post:
hdavis (03-11-2019)
Old 03-11-2019, 08:59 AM   #12
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,234
What is the bottom chord of the truss?
What is the span of the truss?
Just looking thru a beer bottle, I don't see enough connecting truss elements to suggest those could span much of anything if the bottom chord is a 2x4.
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (03-11-2019)
Old 03-11-2019, 12:33 PM   #13
landonm11's Avatar
Trade: TRR Handyman
Rewards Points: 20
The bottom cord of the truss is 2x4. The span is just over 28 ft. I'll get some more pics of the bottom cord with the insulation peeled back.
Old 03-11-2019, 01:08 PM   #14
John the Builder
And they are on 24" centers?
You don't have to take a pic of the bottom chord. We've all seen 2x4s before.
Old 03-11-2019, 02:45 PM   #15
landonm11's Avatar
Trade: TRR Handyman
Rewards Points: 20
yep 2 foot centers.
Old 03-11-2019, 03:25 PM   #16
John the Builder
john5mt (03-11-2019)
Old 03-11-2019, 03:51 PM   #17
landonm11's Avatar
Trade: TRR Handyman
Rewards Points: 20
looks like i was mistaken... maybe i have Howe (K) trusses.
Old 03-11-2019, 04:28 PM   #18
hdavis's Avatar
Howe trusses with 20-24' clear span are dirt cheap. Last time I checked, clear span prices jumped around 28-30', so normally center supported would show up on longer spans.
That doesn't mean someone didn't install center supported, it just makes it less likely.
landonm11 (03-11-2019)
Old 03-11-2019, 06:18 PM   #19
Rooster Cogburn's Avatar
Trade: Master carpenter
Rewards Points: 264
You should be fine to move those walls wherever you want.
Where are you located?
Rooster Cogburn is offline
Old 03-11-2019, 06:32 PM   #20
Texas Wax's Avatar
Rewards Points: 1,608
Location/Roof Load can be a significant factor too. The three points I've worked with, mostly off center tho, have larger gang nails on the member connections at point load. And often 2x6 or dbl 2x4 vertical web member there too.
Chances are those are production run clear spans, standard truss jig. But the OP should still check for stamps marks and consult with the manufacture-engineer to make sure.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following 2 Users Say Thank You to Texas Wax For This Useful Post:
hdavis (03-11-2019), landonm11 (03-11-2019)
