Telescoping Grab Bars - Remodeling - Contractor Talk
Old 02-11-2015, 05:07 PM   #1
GettingBy's Avatar
Rewards Points: 6,486
so I only have to drill into the grout and adjust the bar to a 30 degree angle?
If necessary, if I miss the studs I'll put in a plywood block in back of the drywall even if I have to cut a hole in the outside wall siding & sheathing.
Or should I look for tile drilling bits and spare tile squares? I'm pretty gunshy drilling tile. Maybe use a proper bit with a router and very slowly make the holes?
GettingBy is offline
Old 02-14-2015, 05:24 PM   #2
paul100's Avatar
Rewards Points: 60
Re: Telescoping Grab Bars
You can use these to mount the bars without hitting studs. I used them on an old tile wall that was about 1.25 thick. You can hang on these bars all day long.
http://www.wingits.com//products.php?id=2
paul100 is offline
Old 02-14-2015, 07:24 PM   #3
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Yeah assuming the tile is properly installed and secure, they work fine, I've used similar anchors from Moen. I usually try and grab one stud if at all possible.
Drilling tile is usually fairly easy, unless it's really hard porcelain, in which case it just takes a little more effort and care.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 02-14-2015, 08:50 PM   #4
GettingBy's Avatar
Thanks, folks. . .at least now I have some options.
Old 02-14-2015, 10:09 PM   #5
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
they had some pretty fancy tile drilling bits on there videos. the ones I get are not very good
Anderson is offline
Old 02-14-2015, 10:18 PM   #6
m1911's Avatar
I used a diamond hole saw last time. It's easy to fracture tile with those large arrowhead tips.
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
GettingBy (02-15-2015)
Old 02-15-2015, 11:31 AM   #7
GettingBy's Avatar
I guess I should find the tile box and see if these things are porcelain. And a holesaw seems the way to go, I just have masonry bits.
Old 02-15-2015, 12:18 PM   #8
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,886
Whew. I have a shower door to install this week and I bought a 1/4" diamond hole saw instead of the arrow tip. Feeling reassured now.
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 02-15-2015, 01:05 PM   #9
paul100's Avatar
Rewards Points: 60
We just did a shower door on Friday and bought a Milwaukee 5/16 diamond bit. I was surprised how easily it drilled through porcelain tile.
paul100 is offline
Old 02-15-2015, 01:37 PM   #10
GettingBy's Avatar
With a flat bottom
http://www.milwaukeetool.com/accesso...ing/49-56-0503
how do you keep it from walking off your mark?
Old 02-15-2015, 07:29 PM   #11
paul100's Avatar
Rewards Points: 60
Originally Posted by GettingBy View Post
With a flat bottom
Yes that is the one but in 5/16". you start to by holding it at like a 45 degree angle. hold your hands tight as you can on the wall and drill. I kind of guided it with my finger resting on the bit and the wall. I also started it with the drill on low speed. make sure you keep the bit wet so it stays cool.
paul100 is offline
Old 02-15-2015, 07:49 PM   #12
m1911's Avatar
With a flat bottom
Put a couple layers of painters tape where you want to drill your hole, and start the bit slightly angled rather that 90 deg perpendicular to the wall.
If I don't have an assistant, I usually duct tape a small plastic water or soda bottle filled with water right above where I'm drilling the hole, and I have a tiny hole in the bottle so it slowly puts water on the bit.
m1911 is offline
Old 02-15-2015, 08:38 PM   #13
Renaissance Man
superseal's Avatar
Rewards Points: 5,838
You need a starter bit for accuracy you nimits
Is that even a word
supersealconstruction.com
superseal is online now
Old 02-15-2015, 08:40 PM   #14
m1911's Avatar
Is that even a word
I haven't needed a starter it.
The larger hole saws have a pilot bit.
m1911 is offline
Old 02-15-2015, 08:50 PM   #15
Renaissance Man
superseal's Avatar
I assumed no pilot,...carry on.
Old 02-15-2015, 08:53 PM   #16
m1911's Avatar
My old math teacher use to say never assume, because when you assume, you make an ass out of u and me...
m1911 is offline
superseal (02-15-2015)
Old 02-15-2015, 09:21 PM   #17
m1911's Avatar
These work good too if you have solid backing
http://www.toggler.com/products/snap...stallation.php
m1911 is offline
Old 02-15-2015, 09:30 PM   #18
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 54
When cutting with any of those diamond bits you use your fingers(thumb and pointer) as a guide. Be sure your fingers are and stay wet.
I can't compete with hacks.
donerightwyo is offline
Old 02-16-2015, 09:18 AM   #19
GettingBy's Avatar
Thanks, folks. . .
I'll look up ADA guidelines on placement and get on this one.
Old 02-16-2015, 06:27 PM   #20
Tom M's Avatar
Rewards Points: 7,276
I use zip toggles or wingits, a little painters tape and its good to go. You can easily achieve 200 psf of better.
Tom M is online now
Installing grab bars in fiberglass tub shelf guy Kitchens & Baths 26 09-22-2015 01:42 AM
Step Grab Bars Calidecks Decks & Fencing 14 12-18-2013 01:37 PM
Handicap grab Bars PCDBR General Discussion 8 08-09-2012 10:43 PM
Wood grab bars tcleve4911 General Discussion 1 08-07-2011 08:02 PM
