Tape Residue On Shower - Remodeling - Contractor Talk
Old 06-04-2013, 09:00 AM   #1
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
I'm wrapping up a remodel today that had a fiberglass shower. During construction I used a cellophane sticky tape to protect the shower and when I peeled it off it left residue. What's the best way to get rid of this residue. I thought about goof off?
Tylerwalker32 is offline
Old 06-04-2013, 09:06 AM   #2
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: Tape Residue On Shower
I'd be scared to use goof off on a shower. Try a citrus based cleaner. It is still early here so I can not think of any names to give you. Goo Gone maybe?
"Industry without art is brutality"
shanekw1 is offline
Old 06-04-2013, 09:08 AM   #3
bauler's Avatar
Trade: General and Electrical Contractor
Rewards Points: 75
Wd-40
bauler is offline
The Following User Says Thank You to bauler For This Useful Post:
hdavis (06-12-2013)
Old 06-04-2013, 09:16 AM   #4
Jack Of All Trades
nicktools561's Avatar
Trade: General Construction
Rewards Points: 75
Yeah anything oil base should be able to remove the stickiness. Like the other two said; Goo Gone or WD-40 will work just fine.. Personally I would use Goo Gone, but first I would start on a small spot to test for any discolorations. Then I'd continue on to the rest if all is well with the spot test. I hope this helps, good luck. Let us know if you need anything else!
nicktools561 is offline
Old 06-04-2013, 10:23 AM   #5
Retroloco-LJ's Avatar
Trade: Plumbing
Try some olive oil. Natural product that shouldn't stain - but I would definitely try a small area first to make sure.
____________________
Retroloco-LJ
http://fhfurr.com
Retroloco-LJ is offline
Old 06-04-2013, 04:27 PM   #6
I ended up using good off. I tired several products and that was the only one that truly worked.
The Following User Says Thank You to Tylerwalker32 For This Useful Post:
Old 06-04-2013, 04:29 PM   #7
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
what did you try that didn't work? just for point of information...
world llc is offline
Old 06-04-2013, 07:13 PM   #8
I used some sort of citrus based cleaner, I'll have to look at the name tomorrow. I also tried dawn dish detergent which did squat. I was a bit concerned about using goof off but it seemed to do no damage that I could see.
Old 06-04-2013, 07:20 PM   #9
rrk's Avatar
Rewards Points: 3,268
Don't hesitate to call the manufacturer, they know how to get rid of all sorts of marks, glue etc. Saves lots of time.
rrk is online now
The Following 2 Users Say Thank You to rrk For This Useful Post:
ArtisanRemod (06-04-2013)
Old 06-04-2013, 07:45 PM   #10
Well heck, wish I had thought about that. Would made to sense to do that.
Old 06-11-2013, 09:15 PM   #11
Fairly new guy
Foxit's Avatar
Rewards Points: 105
When I first got started in the trade I was doing a finish clean up and the plumber had drawn a center line for the faucet and spout. I tried for about 45 minutes and every solution and could not scrub the line off. Finally asked the Forman for advice, he walked over and took his pencil out and erased it. Don't know if it helped ,but just made me think about it.
Foxit is offline
The Following User Says Thank You to Foxit For This Useful Post:
shanekw1 (06-11-2013)
Old 06-11-2013, 09:22 PM   #12
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
That's a D'oh! moment if I've ever heard one.
shanekw1 is offline
Old 06-12-2013, 10:09 AM   #13
hdavis's Avatar
Rewards Points: 1,556
Originally Posted by bauler View Post
Wd-40
WD40 is pretty much a cleaning standard for this.
hdavis is offline
robert c1 (06-14-2013)
Old 06-17-2013, 02:49 AM   #14
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
WD-40 is great for lots of things. I used GOO GONE before on adhesive on fiberglass tub and it works well.
m1911 is offline
Old 06-17-2013, 04:53 AM   #15
Big Shoe's Avatar
Rewards Points: 2,066
You're lucky the goof off did not take the finish off. That is pretty strong stuff.
Goo Gone, WD-40, Citrus based, and oderless mineral spirits are my first go to's. After that it's the goof off, acetone , thinners.
Always test an inconspicuous spot first.
Just had to clean blue tape residue off a very expensive wood floor. (mineral spirits)When am I ever going to learn.
Expect the Unexpected
Big Shoe is offline
Old 06-18-2013, 01:33 AM   #16
CarpenterSFO's Avatar
Rewards Points: 2,044
Butter.
- Bob
CarpenterSFO is offline
Old 07-08-2013, 10:53 PM   #17
bauler's Avatar
Rewards Points: 75
Butter? Peanut butter? WD-40 works for me. Don't use it on a porous surface like bare wood, it will seal it. Good for colds, molds and sore whatevers.
bauler is offline
Old 07-09-2013, 12:09 AM   #18
VinylHanger's Avatar
Rewards Points: 11,526
The most important thing you learned is don't use cellophane tape.
VinylHanger is online now
Old 07-09-2013, 07:44 AM   #19
Some time you gotta learn, and well I learned the hard way, never again.
Old 07-19-2013, 04:54 PM   #20
ATHI's Avatar
On plastics I use napta fuel (camping fuel) on a cotton ball try a small area and go in a circular fashion until it evaporates changing the cotton balls frequently. To be Safe I always test it in a small inconspicious area first to make sure it doesn't discolour or de-delaminate the surface.
It works great on stickers and other things as well, if you don't have napta fuel (camping fuel) you can use lighter fluid it's the same thing but more expensive. Funny how they can put something in a smaller package and sell it as something else and charge 5 times the price for it.
ATHI is offline
Custom Steam Shower Dayton Ohio ohiohomedoctor Kitchens & Baths 13 12-27-2012 11:38 PM
Edge Tape KennMacMoragh Painting & Finish Work 9 04-23-2010 05:34 PM
Tiled Shower - Question blackte Tiling 2 10-19-2009 09:24 AM
Help. Self Adhesive paper tape problem. jstrand23 Drywall 1 11-28-2007 02:09 PM
