Steel Framing In Small Remodels - Remodeling - Contractor Talk
Old 06-12-2015, 09:45 PM   #1
CarpenterSFO's Avatar
Rewards Points: 2,044
A while back I decided to start using steel framing where it made sense in remodels in our typical single family home work - type 5, wood frame. So far, for non-bearing walls, soffits, half-walls, etc. We've had to use it before in our high-rise condo remodels, and I thought I'd give it a shot in other types of projects.
In addition to its other advantages, I've been finding that remodeling crew with light framing experience do a much better job framing with steel than with wood. A few things (fire stopping, running electrical and plumbing, etc.) have required some learning, but I've been happy with it, feel that I've been delivering good value, and customers don't have any opinion about it at all.
We've been using 20-gauge to 14-gauge, and the result is rock solid.
The materials cost a bit more, but I'm not having a problem with that. In many cases we'd be using LVL's or other materials more expensive than dimensioned lumber, anyway.
I realize that steel is mundane for many in new construction or large projects - they load my few studs in between the truckloads going out to big projects - but I'm wondering how many are doing this in single family remodels? Anything to share? Any comments?
- Bob
CarpenterSFO is offline
Old 06-12-2015, 10:27 PM   #2
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
Re: Steel Framing In Small Remodels
I'm interested as well. I've used steel on basement projects, but haven't done it other remodels. I honestly prefer working with steel since we do all the interior finishes as well. For me having straight/flat walls is easier to finish in all aspects. The higher cost of steel can be partially offset by improved finish quality and increased production on phases after framing.
philcav7 is offline
The Following User Says Thank You to philcav7 For This Useful Post:
CarpenterSFO (06-13-2015)
Old 06-12-2015, 10:28 PM   #3
aptpupil's Avatar
Rewards Points: 1,894
One of the contractors I learned from said she used it all the time in the Oakland hills and sold it on the fire stopping merits. Seemed to work well there for obvious reasons.
Nice that it doesn't shrink. No nail pops, need to crown the studs, etc.
aptpupil is offline
The Following User Says Thank You to aptpupil For This Useful Post:
Old 06-13-2015, 06:01 AM   #4
hdavis's Avatar
Rewards Points: 1,556
I'm using it. I can carry more studs by myself than wood studs. I don't have to select for straightness, and it never splits. No hole drilling for wiring.
The downside is I have to travel a ways to get the materials - too far away for small deliveries. I also have to make sure I have the right drywall screws with me - I still have buckets of the conventional ones.
hdavis is offline
Old 06-13-2015, 07:47 AM   #5
slowsol's Avatar
Rewards Points: 2,248
Pretty typical for us to use wood exterior bearing walls and light gauge interior walls on things like small offices, vet clinics, etc. I've used them on basement finishes. I actually like working with them more than wood.
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
Old 06-13-2015, 08:56 AM   #6
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 348
I started out working for a commercial steel stud and drywall company, mostly doing suspended ceilings but also got some framing experience with steel studs. I like them a lot for certain things. Things like soffits in basements are much easier to do with steel studs. I don't use them all the time but on certain jobs they are better to use over wood.
platinumLLC is offline
The Following 2 Users Say Thank You to platinumLLC For This Useful Post:
asevereid (06-13-2015), CarpenterSFO (06-13-2015)
Old 06-13-2015, 01:49 PM   #7
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
I did a complete townhouse complex in Napa with steel studs about 98,000 sq.ft. and then a 40,000 sq.ft. retirement home in Sonoma as well, all steel.
Once the guys get screws over nails, grinder over skilsaw, etc. it's pretty simple to work with.
Chris
Chris Johnson is offline
The Following 2 Users Say Thank You to Chris Johnson For This Useful Post:
CarpenterSFO (06-13-2015), hdavis (06-13-2015)
Old 06-13-2015, 05:35 PM   #8
slowsol's Avatar
Nice to be able to cut a stack at a time without muscling around too much.
-John
slowsol is offline
Old 06-13-2015, 06:10 PM   #9
mako1's Avatar
Rewards Points: 1,094
I've been considering using it more for the same reasons.Most of the remodels and additions we do have a considerable amount of drywall and it would be nice for a solid flat wall .
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
Old 06-13-2015, 06:17 PM   #10
You probably already know to find yourself a good commercial supplier, to get a heavier gauge than you will get from the big box stores. They also stock the fire stops, stiffeners, clips, and other useful pieces. Around here the big boxes only sell the studs, not the tracks, either.
- Bob
Old 06-13-2015, 06:27 PM   #11
mako1's Avatar
The BB strores around here don't even sell it.I have a good local lumberyard that supplies most of my material and does good quality at a good price.They will pretty much get me whatever I want the next day if they don't stock it.Lucky to have them in a small town.
When I was in Florida doing high rise condos that is all they used so I'm a bit familiar with it just never used it in residential but with the quality of wood these days and the pros with the metal framing .I think I'll try it and see what happens.
mako1 is offline
Old 06-13-2015, 08:06 PM   #12
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
If it's just going to be sheet rocked and maybe a few door's and some base molding then yea I'm using metal . If there's crown and cabinet's I'm back to wood .
Eaglei is offline
Old 06-13-2015, 08:13 PM   #13
I'm curious, why?
- Bob
Old 06-13-2015, 10:35 PM   #14
mako1's Avatar
I'm curious, why?
I'm also curious about that statement .you can get a lot truer wall from metal which would be great for cabinets imo.
mako1 is offline
Old 06-13-2015, 11:11 PM   #15
aptpupil's Avatar
I took it as a fastening issue.
aptpupil is offline
Eaglei (06-14-2015)
Old 06-14-2015, 07:55 AM   #16
hdavis's Avatar
That would have been my guess. I know some that like to put ply up on walls before rocking so cabinets can be fastened anywhere, even with wood framing...
hdavis is offline
Old 06-14-2015, 10:08 AM   #17
I'm a Mac
In California we always bought our fasteners for drywall, cabinets etc for steel from ORCO, which if I remember was bought out by WhiteCap.
Fasteners made by Grabber, use the LOX head...you will be impressed
Chris
The Following User Says Thank You to Chris Johnson For This Useful Post:
CarpenterSFO (06-14-2015)
Old 06-14-2015, 10:26 AM   #18
Eaglei's Avatar
I just find it annoying trying to fasten crown to metal framing . When you have a ceiling that's not straight and your fighting to push the crown in place I would like to grab my gun and shoot a few fasteners to hold it in place . When you need to use a screw gun to install crown that's unproductive and the time you saved by using metal was not worth it . I'm also not installing cabinet's to metal with out first putting up a few sheet's of plywood , but then you need to install sheet rock over it . I'm not concerned with wood not being straight , that's what shim's are for .
I'm also curious to know how some of you are installing crown with metal stud's .
Eaglei is offline
The Following User Says Thank You to Eaglei For This Useful Post:
CarpenterSFO (06-15-2015)
Old 06-14-2015, 04:10 PM   #19
slowsol's Avatar
Typically either wood blocking at the studs or a triangle ripped nailer behind the crown. Some guys just cross nail and glue it. We have a nail gun that works for baseboard in to 26-24 gauge.
-John
slowsol is offline
Old 06-14-2015, 04:22 PM   #20
I'm a Mac
ET&F makes a 'T' shaped nail and air gun designed for trim work into these studs
Chris
Eaglei (06-14-2015), Rio (06-14-2015)
Steel framing and architectural metal panels aaron_a Carpentry Picture Post 2 05-08-2014 08:46 PM
Best way to straighten anchor bolts for steel framing rufusjack Framing 27 11-14-2012 11:57 AM
Steel framing: fixing studs to track, overhead UpNorth Framing 1 06-06-2010 05:34 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
framing a door in a steel stud wall River Rat Dad Framing 5 10-21-2006 06:37 AM
