Replacing Fiberglass Pan From Above - Remodeling - Contractor Talk
Old 06-24-2015, 09:28 PM   #1
AustinDB's Avatar
Rewards Points: 1,742
is it possible to replace a fiberglass pan from above if the dimensions of the drain are identical? Client wants a shower without the built in seats and doesn't want the hassle of cleaning a tile pan.
after finding a couple of options online, what type of drains have you found to be of good fit and quality? Do the types with the expanding gasket fail in the future?
AustinDB is online now
Old 06-25-2015, 09:13 AM   #2
dsconstructs's Avatar
Trade: Remodel Contractor
Re: Replacing Fiberglass Pan From Above
If by "from above" you mean you don't have access to the p-trap from below, that's not a problem. The caulkless/compression drain flange like Oatey work great and I've never seen a failed gasket after having pulled many older ones.
Swanstone is my first choice. Kohler acrylic, Swan Veritek are my next in that order. The Veritek uses the wedge lock drain and also works just fine.
dsconstructs is offline
The Following 2 Users Say Thank You to dsconstructs For This Useful Post:
AustinDB (06-26-2015)
Installing grab bars in fiberglass tub shelf guy Kitchens & Baths 26 09-22-2015 01:42 AM
Replacing subfloors 1swatcop1 Framing 5 04-03-2013 09:27 PM
Replacing chemical injector small part? arc3822 Pressure Washing 0 04-01-2013 06:02 PM
Fiberglass Pickup Caps RonMiller Contractor Swap 0 01-29-2013 01:46 PM
