Plaster Or Joint Compound ? - Remodeling - Contractor Talk
Old 06-30-2019, 06:08 PM   #1
woodspike's Avatar
Rewards Points: 546
client has a closed in garage .
one walls is still original. its about 6 feet x 8 feet high .
is painted rough stucco .
they want it smooth
i`ve used both materials , but no really an expert at either .
definitely used joint compound much more , and can get things smooth.
i`ve used one- coat , but its been a while , and if i remember you can keep working it , and sponge it as it hards and get it smooth also
what you use? one-coat , or joint compound ?
woodspike is online now
Old 06-30-2019, 10:08 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,124
Re: Plaster Or Joint Compound ?
can you just sheet the area with, drywall, plywood, siding, etc?
seems like the labor savings would be worth it.
griz is online now
hdavis (07-01-2019)
Old 06-30-2019, 11:33 PM   #3
GC/carpenter
Calidecks's Avatar
Rewards Points: 17,706
Use 1.5" fur strips every 16 inches and scribe/shim them so the wall is flat then hang drywall on them.
Mike.
_______________
Calidecks is offline
Old 06-30-2019, 11:43 PM   #4
TheConstruct's Avatar
Rewards Points: 982
Can you remove the stucco and start fresh? 6x8 is a pretty small area to demo.
TheConstruct is online now
The Following User Says Thank You to TheConstruct For This Useful Post:
Calidecks (06-30-2019)
Old 07-01-2019, 07:34 AM   #5
woodspike's Avatar
Rewards Points: 546
no to all those
can`t fur it out , they don`t want me to bring it out that much
can`t remove the stucco, its a block wall.
i probably could tapcon drywall right to the stucco ,sounds weird , but i`ve done it before.
i might just give them no choice ( they`re pretty understanding if i tell the its the best way)
but then i might as well fur and drywall it !!
so i`m arguing to myself now !!
Old 07-01-2019, 07:40 AM   #6
tjbnwi's Avatar
Rewards Points: 3,440
Mortar 3/16 or 3/8 Kerdi board to the wall. Skim and paint.
tjbnwi is online now
Old 07-01-2019, 01:18 PM   #7
woodspike's Avatar
Rewards Points: 546
Just finished it.
Used construction adhesive and tapcons.
On my second coat.
Worked fine.
Old 07-01-2019, 01:20 PM   #8
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,495
Originally Posted by woodspike View Post
Just finished it.
On my second coat.
Worked fine.
With what board?
MarkJames is online now
Calidecks (07-01-2019)
Old 07-01-2019, 07:50 PM   #9
woodspike's Avatar
Rewards Points: 546
1/2 inch greenboard , on the stucco
used construction adhesive, and tapcons .
then 2 so-minute coats , and a 45 minute coat .
i`ll check it in the morning before i put the base molding on.
Old 07-05-2019, 06:18 PM   #10
Flip King
Gking707's Avatar
Trade: Remodel Contractor
Rewards Points: 38
This isnt below grade is it?
Gking707 is offline
Old Yesterday, 06:50 AM   #11
jeffmattero76's Avatar
Trade: Property Manager
Rewards Points: 76
The party wall (block wall between two row homes) in many of my rentals is plaster applied directly to the block. Many of these develop a hairline crack that follows the mortar joints of the block. I have tried repairing these multiple times, and the cracks always come back.
One of the drywall guys I use suggested using sheets of drywall that are attached to the existing wall with construction adhesive and 1 inch masonry nails. It works like a charm!!!
Sent from my SM-G530T using Tapatalk
jeffmattero76 is online now
The Following User Says Thank You to jeffmattero76 For This Useful Post:
hdavis (Yesterday)
Old Yesterday, 08:43 AM   #12
woodspike's Avatar
Rewards Points: 546
no , not below grade
miami garage .
it was a garage that was turned into a bedroom , and office
but for some reason one wall was never finished .
i have done it this way before ,
i`m not gonna say i have gone back , and checked ones i`ve done before
but it seems to work good
they didn`t want me to fur it out . i told them i would fur it out , and and electric on the wall , since they are gonna have it as an office , but they said no , they didn`t want to close it in that much.
hey , give them suggestions , but then do as your told .
Old Yesterday, 12:03 PM   #13
GC/carpenter
Calidecks's Avatar
You can use mesh tape on the mortar lines.
Mike.
_______________
Old Yesterday, 02:27 PM   #14
hdavis's Avatar
Rewards Points: 2,614
Without seeing it, I may have done smooth stucco over the top with SBC. In and out in an hour or less.
Most times, the best approach plays to your strengths, or at least avoids weaknesses.
hdavis is online now
