Metal Doors - Remodeling - Contractor Talk
Metal Doors
Old 02-22-2012, 10:23 AM   #1
Mike-'s Avatar
Trade: Renovation Specialist.
Metal Doors
I went out to see a job I bid on today, and all the interior doors were metal jamb. No nails are visible or even screws. It does not look like the standard steel doors I'm used to installing in multi family units. Anyone have any experience with such a door as this? For easy removal. The labourer said he spent 4 hours removing one door with his sawzall? Hmm.
Any thoughts or advice to make these 10 doors come out easy? Am I missing something.
Could be a nailed flange and boarded over the flange?
Mike- is offline
Old 02-22-2012, 10:26 AM   #2
Holy Crap!
ROVACON's Avatar
Trade: General Contracting-Renovations-Carpentry
Rewards Points: 296
Re: Metal Doors
Mike-
Sounds like a welded frame to me. They are installed during the framing process. The drywall slides into the frame and conceals the installation clips.
Brian
ROVACON is offline
The Following 2 Users Say Thank You to ROVACON For This Useful Post:
BC Carpenter (03-09-2012), SSC (02-23-2012)
Old 02-22-2012, 10:31 AM   #3
Mike-'s Avatar
Re: Metal Doors
Really? So in other words. Hire a labourer to do this?
Mike- is offline
Old 02-22-2012, 10:33 AM   #4
Holy Crap!
ROVACON's Avatar
Rewards Points: 296
Re: Metal Doors
Mike-
A good sawzall blade will do the trick if you cut around the perimeter. The biatch is getting the feet that are anchored into the slab out. They are usually shot pinned down, lead anchored or tapcon into the concrete.
But yes, hire a laborer
Brian
ROVACON is offline
Old 02-22-2012, 03:25 PM   #5
PRO
BrandConst's Avatar
Rewards Points: 1,004
Re: Metal Doors
Welded frame for sure.
BrandConst is offline
Old 02-22-2012, 03:50 PM   #6
Mike-'s Avatar
Re: Metal Doors
What was the thought process behind this method? It seems to be more work than anything else. Thanks for the help guys. 12 bucks and hour and a happy worker. Excellent. Lol
Mike- is offline
Old 02-22-2012, 04:27 PM   #7
TLHWindows's Avatar
Trade: Windows Doors Siding Hurricane Shutters
Rewards Points: 734
Re: Metal Doors
No screws to hide or break or take out. They are strapped to the wall frame. Pain in the arz to remove.
Cool, lets put some fabric over a window and let a hurricane throw some stuff at it. I'm sure it will protect you and your windows.
http://www.gulfbreezewindows.com
TLHWindows is offline
Old 02-22-2012, 05:48 PM   #8
Mike-'s Avatar
Re: Metal Doors
It went well. What a bitch to get the doors out. You are right about that. I sure as hell hope they have stopped manufacturing those doors and that the installation has ceased completely.
Mike- is offline
Old 02-22-2012, 06:04 PM   #9
detroit687's Avatar
Trade: carpenter
Re: Metal Doors
12 an hour x 4 hours for your laborer to remove one welded frame that make sense
detroit687 is offline
Old 02-22-2012, 06:06 PM   #10
detroit687's Avatar
Trade: carpenter
Re: Metal Doors
Lmao seriously yes welded frames are no more
Old 02-22-2012, 06:33 PM   #11
Bivens Construction
ebivremodel's Avatar
Trade: General Construction, Renovations, Remodeling
Rewards Points: 75
Re: Metal Doors
Commercial Job?
ebivremodel is offline
Old 02-22-2012, 06:43 PM   #12
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Metal Doors
We just got done hanging 33 doors on those frames. We hung the frames also. Yes........yes they do suck. We hate them!
CrpntrFrk is offline
Old 02-22-2012, 09:22 PM   #13
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
Re: Metal Doors
wow dont even get me started on hollow metal doors! been there done that. believe I feel your pain.
JWilliams is offline
The Following User Says Thank You to JWilliams For This Useful Post:
Mike- (02-22-2012)
Old 02-23-2012, 12:00 AM   #14
Mike-'s Avatar
Re: Metal Doors
Townhouse block in Vancouver. 1000 post club. Lol
Mike- is offline
Old 02-23-2012, 03:28 PM   #15
skillman's Avatar
Rewards Points: 1,968
Re: Metal Doors
We use welded frames or knock down frames all the time. When you install them you will pick up how easy there are to install or take out in demo in my opinion.
skillman is offline
Old 02-23-2012, 05:40 PM   #16
TRC
TRC's Avatar
Trade: Windows and Doors
Rewards Points: 87
Re: Metal Doors
sawzall and rip hammer, cut em out in 5mins flat....i'm not a laborer though...Although i do seem to labor very much.
TRC is offline
The Following User Says Thank You to TRC For This Useful Post:
Mike- (02-24-2012)
Old 02-23-2012, 06:50 PM   #17
Thom
thom's Avatar
Rewards Points: 4,748
Re: Metal Doors
Did a major truck stop remodel. The walls were all plastered cmu, 2#5/8 rebar in every other cavity horizontal and vertical, solid filled. The welded steel door frames were pinned to the block, pinned to the floor, and the hollow frame was filled with concrete.
thom is offline
Old 02-23-2012, 08:02 PM   #18
SSC's Avatar
Trade: Interior Remodeling Specialists
Re: Metal Doors
those doors suck to remove.
The Finest in Interior Renovations
SSC is offline
Old 02-23-2012, 08:30 PM   #19
Hmbldr's Avatar
Trade: Residential contractor
Rewards Points: 150
Re: Metal Doors
Great. So I just signed on for a TI that includes pulling half dozen of these doors out. Saving for reinstallation. Any good tips to make this go as smooth as possible? Thanks.
Hmbldr is offline
Old 02-23-2012, 08:49 PM   #20
Thom
thom's Avatar
Re: Metal Doors
Saving the frames will require removing the wall finish on the sides to find the attaching points for the hardware. These are clips that can be located in different positions. You will need to remove framing from one side at least and possibly part of the header. Saving the door frames is likely to be more expensive than replacing them.
Good luck.
thom is offline
Doors, doors, doors Tinstaafl Carpentry 32 03-05-2010 10:13 PM
Selling exterior doors......rant Tom M Windows, Siding and Doors 21 03-28-2009 09:02 PM
Metal Framing Help gambinos1983 Framing 7 04-06-2008 07:01 PM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 12:30 AM
