Load Bearing Or Functional - Remodeling - Contractor Talk
Old 09-11-2019, 04:03 PM   #1
mkemp590's Avatar
Trade: Design
A client would like some 4x4 posts removed from their first floor garage. The entire first floor was a garage for a plumbing operation and had a ton of shelving and storage space. The posts are against a wall in the row home with the adjoining homes wall on the other side. The 4x4s have inch holes for tubing to hold longer pipes and materials. The marks on the wall look like there was some shelving built around the bottom as well. It has since been remodeled and a ceiling and hvac put in. Most of the posts are loose and movable. They are bracketed into the concrete floor, but the ceiling is a little iffy... there are l brackets, but they do not have bolts and are not attached to the ceiling. They don’t make any sense as a load bearing component, but wanted an opinion from someone who has some solid understanding. Thanks for the input!
-Matt
mkemp590 is offline
Old 09-11-2019, 04:44 PM   #2
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 190
Re: Load Bearing Or Functional
I think you need to have someone look at it. I can't even imagine what you are talking about.
That will be $350.00, thanks.
Andy.
ScipioAfricanus is offline
The Following 5 Users Say Thank You to ScipioAfricanus For This Useful Post:
avenge (09-11-2019), CScalf (09-11-2019), greg24k (09-11-2019), griz (09-11-2019), Seven-Delta-FortyOne (09-11-2019)
Old 09-11-2019, 06:58 PM   #3
General Contractor
greg24k's Avatar
Rewards Points: 8,478
Wear a helmet and remove them... If nothing happens they functional, if you get whacked in the head they're load-bearing.
Let us know.
That will be Tree Fiddy!
greg24k is offline
The Following 4 Users Say Thank You to greg24k For This Useful Post:
avenge (09-11-2019), CScalf (09-11-2019), griz (09-11-2019), ScipioAfricanus (09-11-2019)
Old 09-11-2019, 07:32 PM   #4
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
Rewards Points: 748
Stick with me baby bird, I'll feed ya.
CALL A LOCAL CONTRACTOR
"Your problem does not constitute an emergency on my part"
CScalf is offline
Old 09-11-2019, 07:39 PM   #5
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,008
Isn't that what someone, say uh.. maybe a homeowner, would hire a designer for?
I dunno, just spit-ballin' here.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
CScalf (09-11-2019), greg24k (09-12-2019), ScipioAfricanus (09-11-2019)
Old 09-11-2019, 08:50 PM   #6
hdavis's Avatar
Rewards Points: 2,052
We'd be able to tell if you had a framing diagram for that portion if the existing.
If it's loose, it isn't structural anymore.
If the Sawzall binds cutting it, stop.
hdavis is online now
greg24k (09-12-2019), Irishslave (09-11-2019)
Old 09-11-2019, 09:35 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 622
assuming he knows how to correctly use a sawzall....
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
greg24k (09-12-2019), hdavis (09-11-2019)
Old 09-11-2019, 09:47 PM   #8
hdavis's Avatar
If he doesn't, he should still stop when it binds.
greg24k (09-12-2019), griz (09-11-2019)
Old 09-11-2019, 10:03 PM   #9
rselectric1's Avatar
Rewards Points: 878
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
rselectric1 is offline
The Following User Says Thank You to rselectric1 For This Useful Post:
griz (09-11-2019)
