Improvising Tips For Remodeling - Remodeling - Contractor Talk
Old 12-22-2013, 03:30 PM   #1
remedy1's Avatar
Trade: Home Renovation, Remodeling, and Repair
Due to the snow last week, we left our trailers parked and thought we had what we needed at a condo rehab we are doing. Anyway, we forgot hole saws to cut shower valve openings for the 1/2 hardibacker. Instead of going to get the hole saw, We improvised by driving a screw every 1/2" around a circle then just punching it out to get that perfect hole. Gave us a clean hole, no dust, and was quick. Anyone got other good improvising tips they have used?
remedy1 is offline
Old 12-22-2013, 07:05 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: Improvising Tips For Remodeling
Why drive a screw?. Why not drill small holes?.
sunkist is offline
Old 12-22-2013, 07:17 PM   #3
kambrooks's Avatar
Rewards Points: 572
Save drill bits perhaps, didn't have correct type of bit, less dust...
Just guesses
Kameron Brooks
www.iFixHomeImprovement.com
kambrooks is offline
Old 12-22-2013, 07:53 PM   #4
Remodeler
TAHomeRepairs's Avatar
Rewards Points: 574
I just use a keyhole saw.....
TAHomeRepairs is offline
The Following 2 Users Say Thank You to TAHomeRepairs For This Useful Post:
TiM Management (01-03-2014)
Old 12-23-2013, 06:27 AM   #5
remedy1's Avatar
Correct, didn't want to ruin drill bits. Did not have a keyhole saw with us.
remedy1 is offline
Old 12-23-2013, 07:03 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,776
Take a hammer and bust a hole in it, the tile will cover it... the hackers doing it all the time, it works and there is no mess, all the debris will fall behind the backer-board.
greg24k is offline
The Following 3 Users Say Thank You to greg24k For This Useful Post:
B.D.R. (01-04-2014), bob hutson (02-17-2014), TNTRenovate (12-23-2013)
Old 12-23-2013, 07:44 PM   #7
sunkist's Avatar
Rewards Points: 890
Great idea what size hammer do i use?. 23oz shower valve, 17oz tub spout
sunkist is offline
Old 12-23-2013, 07:47 PM   #8
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
You are not cutting through a half inch of hardibacker with a keyhole. Maybe durock, but not hardi. You'll dull the blade before you get half way through it. It won't even cut 1/4".
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
KermieB (12-27-2013)
Old 12-23-2013, 07:48 PM   #9
Hair Splitter
Trade: General
5lb sledge does the trick. About the right diameter.
greg24k (12-27-2013)
Old 12-27-2013, 08:48 AM   #10
GO Remodeling's Avatar
Rewards Points: 96
You're right. Durock yes. Hardi no.
Any hammer punched through hardi and a pair of pliers to nip opening.
GO Remodeling is offline
The Following 2 Users Say Thank You to GO Remodeling For This Useful Post:
TAHomeRepairs (12-27-2013), TNTRenovate (12-27-2013)
Old 12-27-2013, 09:54 AM   #11
Remodeler
Rewards Points: 574
True enough. I missed the Hardi part. I usually prefer durock so that's what I was thinking of.
Old 12-27-2013, 09:55 AM   #12
Remodeler
Rewards Points: 574
Originally Posted by olzo55
You're right. Durock yes. Hardi no. Any hammer punched through hardi and a pair of pliers to nip opening.
I too have used this method linesman or tile nips both work well!
Old 12-27-2013, 11:06 AM   #13
Hair Splitter
Trade: General
No reason in my mind to use hardi. I use Durock for walls and 1/4" backer for floors.
The Following 3 Users Say Thank You to TNTRenovate For This Useful Post:
charimon (12-30-2013), KermieB (12-27-2013), TiM Management (01-03-2014)
Old 12-27-2013, 11:15 PM   #14
disenchantedsub's Avatar
Trade: carpentry
Rewards Points: 14
How do you guys cut your hardy and durarock? My boss insists on the worm drive with diamond blade, I hate that because of the dust. I always use the score and snap method when I can. Jigsaw at low speed for cutouts
disenchantedsub is offline
Old 12-27-2013, 11:17 PM   #15
tyb525's Avatar
Trade: Remodeling and Carpentry
Diamond blade on grinder for cement board, old carbide circ saw blade for hardi.
I work for a GC, and I do woodworking as a hobby. I also cut most of my own lumber for that with a Woodmizer LT10 sawmill.
Dull tools cause accidents. Sharpen your tools before they get dull!
tyb525 is offline
Old 12-27-2013, 11:28 PM   #16
KermieB's Avatar
Trade: Remodeler, Kitchen and Bath
Rewards Points: 333
I wouldn't give you two cents for Hardi. Durock is so much easier to work with. For a couple of years, I used a Rotozip with a right angle attachment and a diamond blade, but now I have a Zip Saw by Rotozip with is basically the same thing, just smaller.
As for the dust, well the new Zip Saw has a dust cover with a small hose and an attachment for your ShopVac and it works reasonably well, but I don't use it unless I'm forced to cut indoors.
KermieB is offline
The Following User Says Thank You to KermieB For This Useful Post:
disenchantedsub (12-28-2013)
Old 12-28-2013, 07:15 AM   #17
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
For clean ,dust free cutting---use a little diamond bladed circular saw and press a wet sponge against the blade----
Harbor Freight has a 4" diamond saw for about $40---try it.
mikeswoods is offline
The Following 3 Users Say Thank You to mikeswoods For This Useful Post:
disenchantedsub (12-28-2013), Metro M & L (01-05-2014), Tom M (12-28-2013)
Old 12-28-2013, 09:23 AM   #18
D.S.I.'s Avatar
Trade: REMODELING
Rewards Points: 277
My fiber cement shears just get wide enough for Hardi backer, not sure on durock though.
D.S.I. is offline
The Following User Says Thank You to D.S.I. For This Useful Post:
98crewcab (01-05-2014)
Old 12-28-2013, 03:44 PM   #19
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Curiosity...... I've always had to cut hardi (both 1/2 and 1/4).
I've tried score/snap and can't do it (except maybe very small pieces.)
I use a carbide scorer.... is there some trick to it, as I'd like to avoid that dust/sand.....regardless of the evac system I use.
TIA
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
mikeswoods (12-28-2013)
Old 12-28-2013, 03:52 PM   #20
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
I use to cut durock/permabase/cement board with a regular 24 tooth carbide blade on a cordless circ saw. Here's the trick though. Wet the cement board with water so it soaks in before the cut. Almost no dust..
Now I just score the board with a regular utility blade and snap it. Just cut the front side. Back won't work..
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
The Following 3 Users Say Thank You to Rich D. For This Useful Post:
charimon (12-30-2013), MTN REMODEL LLC (12-28-2013)
Teak Tips? InterCounty Flooring 1 04-17-2013 10:38 PM
Framing Layout and Blueprint Reading - Seeking Advice and Tips for Beginners Workin Kid Framing 49 02-27-2013 12:54 PM
Starting a New Business, going to try postcard marketing. Any tips? Garage Doctor Marketing & Sales 95 02-19-2013 11:21 PM
Pressure Washing & Window Cleaning Tips Jas2012 New Member Introductions 13 08-14-2012 05:22 PM
