Importance Of Posts To Support Porch Beam - Remodeling - Contractor Talk
Old 10-09-2013, 03:57 PM   #1
Theological Carpenter
Uncle-chicken's Avatar
Trade: Finish Carpentery
Rewards Points: 101
There is a bit of disagreement on the importance of supporting this front porch. This is about a 25' span, and the beam looks to be 2x8 doubled up and clad with 1x material. I'm of the opinion that this porch needs to be jacked up and supported ASAP before it sags further. The other party thinks it's "just a matter of opinion" and that the sag doesn't need to be fixed. (FWIW, there were two posts on either side of the door that were removed at some point - why, we don't know.)
What say you? How bad is this? Am I just over reacting?
The venerable dead await me in my library to relieve me of the nonsense of the surviving mortals -- Samuel Davies
Uncle-chicken is offline
Old 10-09-2013, 04:30 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 452
Re: Importance Of Posts To Support Porch Beam
What will the bottom of your posts sit on? How much of a sag is there currently?
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
Uncle-chicken (10-09-2013)
Old 10-09-2013, 04:33 PM   #3
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
You can span 28' all day. Just not with 2x8.
jlsconstruction is offline
The Following 2 Users Say Thank You to jlsconstruction For This Useful Post:
EMINNYS (10-09-2013), Uncle-chicken (10-09-2013)
Old 10-09-2013, 04:37 PM   #4
Rewards Points: 101
The posts are sitting on a concrete pad. The sag is approximately 2 1/2" - 3".
Old 10-09-2013, 04:43 PM   #5
stacker of sticks
Rewards Points: 590
Im no engineer but cough cough lvl wink wink cough cough
Old 10-09-2013, 04:53 PM   #6
Geometrist
Warren's Avatar
Rewards Points: 452
I would add the posts in and try to crank it up some. You probably wont get all of it without doing damage somewhere.
Warren is offline
Old 10-09-2013, 06:00 PM   #7
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 504
I would surmise that it will keep slowing sagging until it reaches about 10" then stop for several years.
So ask the other guy how important that is.
Andy.
ScipioAfricanus is online now
Old 10-09-2013, 06:30 PM   #8
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
It used to have 4 columns because that's where the splices in the 2x8's are...Hope you don't get much snow there!
supersealconstruction.com
superseal is offline
The Following 3 Users Say Thank You to superseal For This Useful Post:
asevereid (10-09-2013), ChimneyHill (10-10-2013)
Old 10-09-2013, 07:01 PM   #9
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 526
By all means do it.
Just remember, when you do it, do it slow.
Take back an 1/8" a week for a half a year.
BlueRidgeGreen is offline
The Following 2 Users Say Thank You to BlueRidgeGreen For This Useful Post:
slowsol (10-12-2013), Uncle-chicken (10-09-2013)
Old 10-09-2013, 08:12 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,030
Yep. these things don't happen overnight.
Tinstaafl is online now
The Following 4 Users Say Thank You to Tinstaafl For This Useful Post:
BlueRidgeGreen (10-09-2013), greg24k (10-10-2013), Jeff G (10-09-2013), Uncle-chicken (10-10-2013)
Old 10-09-2013, 08:21 PM   #11
Rewards Points: 101
I'm Canadian, so that was the first thing I thought of. However, I'm living in Louisville - so no, we don't get much snow here.
Thanks for the confirmation guys. I knew it was important, just wanted to hear it from someone else.
Old 10-09-2013, 10:26 PM   #12
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
Sometimes, these types of things can be subjective, just one man's opinion vs another's concerning what's acceptable or not, or looks bad or not, at least enough to warrant doing something to fix it. It appears, however, there is a possibility for other loads to potentially impact this area, and in a very negative way (i.e., seismic, wind, snow, and perhaps an impact load from a haphazard roofer throwing down too much weight on it).
If it were my job, I would recommend a proper fix that might include some jacking, LVL's, or fitch plate, etc. As suggested, I seriously doubt you will get it looking good by jacking at the points where you propose to install (reinstall) posts, as the framing member may have too much set in it that would allow getting the line back to pretty.
Jeff G is offline
The Following User Says Thank You to Jeff G For This Useful Post:
Old 10-09-2013, 11:27 PM   #13
mbryan's Avatar
Trade: Ministry
Rewards Points: 568
Looks like they just installed the joists crown down. Just flip them and problem solved...
mbryan is offline
The Following User Says Thank You to mbryan For This Useful Post:
Old 10-10-2013, 03:29 AM   #14
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,386
If you don't get much snow it could last a long time before it snaps. Your friend kind of has a point that its a matter of opinion. But in my opinion it would look better straight with two more posts there than no posts and a huge sag. Probably anyone looking to buy the house would have that same opinion, especially as it sags more.
KennMacMoragh is offline
The Following User Says Thank You to KennMacMoragh For This Useful Post:
Old 10-10-2013, 06:35 AM   #15
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
Needs more support in my opinion, it's only gonna get worse.
Brian Peters is offline
Old 10-10-2013, 07:29 AM   #16
General Contractor
greg24k's Avatar
Rewards Points: 8,786
They removed the columns to open up the front. This columns are way oversizes for that size house and most likely they blocked front of the house. The house I just remodeled had the same situation.
This house is probably framed the same way, the ceiling area under the porch is just some 2x which nailed into the top of the plate and not part of the ceiling and into the beam which is sagging. If you try to jack this up slowly, you will get most of the sag out without doing any damage, just go slow and see if it goes... if it does without causing damage, level it and add additional support to break up the span.
greg24k is offline
Old 10-10-2013, 07:39 AM   #17
DavidC
DavidC's Avatar
Rewards Points: 2,006
If the other party happens to be the owner of the house and I am otherwise doing nothing connected to the area, then by all means, let him have his opinion and do what he wants. You advised, he considered, the decision is his.
OTOH, if my work comes anywhere near this area and I must be held accountable afterward there will be posts there. At the very least return it to original construction by replacing the missing posts. Even that seems like too long a span for 2x8's.
What is the "other party's" role in this?
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 10-10-2013, 07:44 AM   #18
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,852
His wife.
Old 10-10-2013, 04:12 PM   #19
Rewards Points: 101
Good Luck
The seller of the house - I'm buying it. I'm offering to fix it so long as he gives me a credit.
Old 10-10-2013, 04:14 PM   #20
Rewards Points: 101
My thought is to actually remove the two side posts and install four more proportional ones. Because I agree, they are way over built.
Deck and porch framed maleko Decks & Fencing 179 09-19-2012 09:16 PM
Custom screened porch Camp Ellis Maine Kent Whitten Carpentry Picture Post 24 07-11-2012 09:46 PM
Porch ceiling red_cedar Remodeling 24 02-15-2012 11:38 PM
Shoring Exterior Load Bearing Wall for Beam insertion larch General Discussion 4 01-27-2012 07:47 PM
How To - Finding New Posts Nathan Contractor Talk Tutorials - How To Use This Site 12 05-08-2008 11:59 PM
