Framing On The Flat - Remodeling - Contractor Talk
Framing On The Flat
Unread 09-10-2020, 09:37 AM   #1
rblakes1's Avatar
Rewards Points: 4,168
Framing On The Flat
Got called in to look at tiling tub walls,I don't know if anything that can go over 2x4s on the flat, do any of you?
2 short walls are framed regular, the 5' wall was done on the flat for who knows why (bigger tub maybe?)
Thought I had a pic, but I can't find it
-Rich
rblakes1 is offline
Unread 09-10-2020, 01:38 PM   #2
hdavis's Avatar
Rewards Points: 4,154
Re: Framing On The Flat
IMO, those walls move too easily. When I frame on the flat, I go 12" OC and they still move too easily.
hdavis is offline
Unread 09-10-2020, 02:38 PM   #3
ksc1's Avatar
Rewards Points: 208
I've been using the laminated studs for shower walls. I think they would work ok on the flat, they're definitely stiffer than a 2x3.
ksc1 is online now
Unread 09-10-2020, 08:33 PM   #4
rblakes1's Avatar
Yeah, there was a lot of flex in the wall and I told them there was no way I could tile it as is.
Pretty sure they just had a fiberglass surround before, they were looking to do something nicer
-Rich
rblakes1 is offline
Unread 09-10-2020, 10:25 PM   #5
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,808
1/8" or 1/4" x 1 1/2" steel on the side of each? Screwed ever 12" maybe? Just thinking outside the box if you're down to the studs anyways.
TheConstruct is offline
The Following 2 Users Say Thank You to TheConstruct For This Useful Post:
Dirtywhiteboy (09-10-2020), rblakes1 (09-11-2020)
Unread 09-10-2020, 11:35 PM   #6
Dirtywhiteboy's Avatar
Rewards Points: 6,534
A length of CS 14 down both sides will make em stiff
Dirtywhiteboy is offline
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
Calidecks (09-11-2020), rblakes1 (09-11-2020)
Unread Yesterday, 11:47 AM   #7
Ken360's Avatar
Rewards Points: 112
Just tack on a fee for remedial framing to bring it up to snuff.
Ken360 is offline
Unread Yesterday, 12:04 PM   #8
I'm guessing there isn't room to do that
Unread Yesterday, 12:42 PM   #9
Southbluff's Avatar
Rewards Points: 86
I just finish tiling a basement shower yesterday with the long wall having framing on the flat. 82" tall. No tub. Just a lot of tight blocking, all screwed. I felt confident about the install, but I will give the wall a push while holding a straight edge against it when I am back there Monday.
Sent from my SM-G960U using Tapatalk
Southbluff is online now
Unread Yesterday, 04:15 PM   #10
90%-er
onmywayup's Avatar
Rewards Points: 2,550
Two staggered layers of 1/2" Hardie tile backer board, glued and screwed, would absolutely stiffen that up, and give you your base for the tile. Can you spare an inch of space?
Ram some tapcons through the framing into the concrete first.
onmywayup is offline
Unread Yesterday, 05:59 PM   #11
rblakes1's Avatar
Thanks for the input all!
The fun of it is, the homeowner started this months ago. Tub is already in place, so I've got to work around that
I've got a couple ideas to maybe test out and see how it'll go. The cs14 made me think of angle iron. I usually use kerdi board, but maybe 5/8 xp in that wall with kerdi over it would be the better bet.
Might all become a moot point after I give them the price anyway
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
TheConstruct (Yesterday)
