Firring Out Brick Fireplace - Remodeling - Contractor Talk
Old 03-11-2019, 10:07 PM   #1
diplomat
Golden view's Avatar
Rewards Points: 714
Probably not an uncommon scenario, but something I've never dealt with. Not many brick fireplaces where I cut my teeth.
Have a typical looking brick fireplace in a basement. Has a gas insert. Bricks all the way up through 1st and 2nd floor and roof.
Clients want new tile, and power and low voltage above a mantel.
Where do I start? Can I just fir this out with wood? Or are there heat issues? How should I detail around the insert?
Golden view is offline
Old 03-11-2019, 10:13 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 680
Re: Firring Out Brick Fireplace
can you check with insert manufacturer for necessary clearances?
other than that you can likely fir it out.
what about lath & float or hardie type backer for the tile.
might solve the clearance issue around the insert.
griz is offline
The Following 3 Users Say Thank You to griz For This Useful Post:
Fouthgeneration (03-11-2019), Golden view (03-11-2019), pinwheel (03-12-2019)
Old 03-11-2019, 10:23 PM   #3
diplomat
Rewards Points: 714
I think it might be hard to find info. From a 90s remodel I think.
I could lath and float. Where does the wiring go though?
With hardie backer I still have wood firring that could be an issue with clearance, right?
Old 03-11-2019, 10:25 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 680
can't screw the backer to the brick?
groove a channel in the brick for you wires????
griz is offline
Old 03-11-2019, 10:29 PM   #5
diplomat
Rewards Points: 714
I suppose I can. Like I said, I'm out of my element. Split face type brick so I might have to do some grinding and float it anyway.
Old 03-11-2019, 10:43 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 680
just to err on the side of caution i would run the low voltage in conduit & add a spare, just because. steel wiremold if it can be concealed. (not sure)
sounds fairly simple & straight forward no matter which way you go.
griz is offline
Old 03-11-2019, 11:06 PM   #7
avenge's Avatar
Rewards Points: 130
I've used metal studs then Hardie.
avenge is offline
The Following 3 Users Say Thank You to avenge For This Useful Post:
Golden view (03-11-2019), Tom M (03-12-2019), Warren (03-12-2019)
Old 03-12-2019, 06:48 AM   #8
rrk's Avatar
Rewards Points: 3,484
Most inserts from the 80s & 90s that I have seen allowed wood framing around the unit with a 1" gap, if yours has brick you can just chip away for aa box location and wire trough
Somewhere on the unit is the manufacturer name, the 90s were not that long ago. I just did one last year from 89 and the installation manual was available
rrk is offline
Golden view (03-12-2019)
Old 03-12-2019, 09:58 AM   #9
Lettusbee's Avatar
Rewards Points: 1,228
I usually use hat channel to fir (fur?) out brick chimneys.
Sent from my SM-N960U using Tapatalk
Lettusbee is offline
The Following User Says Thank You to Lettusbee For This Useful Post:
Brick sidewalk edge restraints red_cedar Masonry 16 07-18-2012 06:28 PM
Slate Veneer Over Brick Fireplace plazaman Masonry 3 10-20-2009 08:39 PM
Historic Brick Fireplace Tommy C Masonry 11 10-04-2009 09:33 PM
Cultured Stone over Existing Brick Fireplace fakie99 Masonry 7 12-01-2008 06:10 PM
Tile over brick fireplace surround John Pride Tiling 7 03-04-2008 07:47 AM
