Fill In Sunken Living Room With Cement Or Wood Framing? - Remodeling - Contractor Talk
Old 03-03-2019, 11:48 AM   #1
woodspike's Avatar
Rewards Points: 726
yes i know how to with each
i know if it do wood , id have to adheise and screw all down for no squeaks,
i know if i use cement , i need to fill it in a bit , then use road mesh , and tie into existing
just not sure all the pro` and cons
its a nice home , with a real nice engineered flooring throughout , even inside this sunken area ( 14 ft x 15 ft, by 7 inches deep)
cement , i know is stronger,
but would be so much more labor intensive , and messier.and i`d have to make sure its perfectly level , and even, with the existing upper floor, so i can fill in with that engineered flooring .
wood seems to be faster easier , and neater ,
i don`t want it to sound hollow when we are done
long time ago we had to do this when i was a helper , and they filled in the spaces with some product to keep it for sounding hollow when you walked on it
or would double plywooding suffice, maybe putting rafters closer than every 16 inches too?
and suggestions?
woodspike is offline
The Following User Says Thank You to woodspike For This Useful Post:
Repede Emil (03-12-2019)
Old 03-03-2019, 11:55 AM   #2
VinylHanger's Avatar
Rewards Points: 11,720
Re: Fill In Sunken Living Room With Cement Or Wood Framing?
You could just build it like normal and then use structural spray foam under the joists.
Also, if it is built properly, it shouldn't squeak any more than a normal floor. I'd insulate it no matter what you do.
VinylHanger is offline
Old 03-03-2019, 12:35 PM   #3
Texas Wax's Avatar
Rewards Points: 2,000
and suggestions?
Run 2x6 joists (rafters?) 16" O.C. yes. These floors are so easy to make solid, by shimming every 3-4'. Use subfloor adhesive. Rip a 2x4 or piece of treated decking tapcon'd and glued down. Then regular shims, with glue and nail (screw) through joist. A row or two of solid bridging may help too. This with filling the bays with fiberglass batts will take you just about as close to concrete as can be done. They always sound and feel different, because it's not concrete.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
griz (03-03-2019)
Old 03-03-2019, 12:37 PM   #4
tjbnwi's Avatar
Rewards Points: 2,010
2x6 with joist hangers. Support as mentioned above. No way I’d use concrete.
Tom.
tjbnwi is online now
griz (03-03-2019)
Old 03-03-2019, 04:18 PM   #5
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
It is real hard to use a bull float indoors with walls, then end up with a nice transition, ask me how I know .
Still "Shakin" the tree boss
sunkist is online now
Old 03-03-2019, 05:41 PM   #6
90%-er
onmywayup's Avatar
Rewards Points: 2,254
Ledger board of 2x6 all around the peemiter, secured to studs with LedgerLok lags. 2x6 floor joists set into hangers. If the span is bigger than eight or ten feet, scrap pieces of treated 2x4 secured to the sides of the joists reaching down to touch the subfloor and provide mid-span support.
Done it dozens of times over the years. As long as the ceiling height can accommodate the higher floor, works perfectly. Slap a vapor barrier and insulation down before you hang the joists. Done.
onmywayup is offline
Old 03-03-2019, 05:43 PM   #7
woodspike's Avatar
Rewards Points: 726
thats the problem
and i`d have to either get a truck in or rent amixer , and mix it all myself
if i start all that , a good chance the city code enforcement will come along.
they just dont want it to sound hollow.
i`m thinking i`ll insulate , and double plywood it .
maye put rafters on 12 center
Old 03-04-2019, 09:24 AM   #8
Rooster Cogburn's Avatar
Trade: Master carpenter
Rewards Points: 332
rafters
Rooster Cogburn is offline
The Following 2 Users Say Thank You to Rooster Cogburn For This Useful Post:
cedarboarder (03-04-2019), finisher65 (03-04-2019)
Old 03-04-2019, 06:06 PM   #9
builditguy's Avatar
Rewards Points: 1,958
and suggestions?
What are you pouring over? Is the sunken area a concrete slab? or is it wood framing?
I assume it's concrete and you aren't going to pour over the wood framing. Not that it can't be done, but......
builditguy is offline
Old 03-04-2019, 09:50 PM   #10
woodspike's Avatar
Rewards Points: 726
Originally Posted by Rooster Cogburn View Post
rafters
ooohhhh shut uppppp
you know what i mean
yea it is concrete
i`m planning either way to put plastic down ( moisture barrier)
and use 2x6 "RAFTERS!!/JOISTS!/RUNNERS!!.
with side blocks tapcon`ed down .
insulate it
and glue and screw /4 inch plywood , then put engineered flooring to match existing ( client has plenty of the flooring . previous owner was a builder and left them extra.
they just don`t want it to be hollow sounding when you walk on it
Old 03-05-2019, 02:11 AM   #11
Texas Wax's Avatar
ooohhhh shut uppppp
Crews and companies I've worked, would have gotten laughed off the job for being, well (politely) an idiot. And if lucky viewed as an oceans (wet) behind the ears greenhorn.
This day and age it's just good know someone can differentiate between 2x4 and 2x6 even if they aren't 2", 4" and 6"
Old 03-05-2019, 07:08 AM   #12
woodspike's Avatar
Rewards Points: 726
ha!
all in fun.
wife always used to say " you guys are mean to each other"
no ..we`re honest . " hey ! fat bastard ! whats up?"
" alls fine dumb ass !. buying your jeans at the Gap i see !"
Cement or Foam to fill basement window cutout gaps seavlad Carpentry 5 12-14-2016 06:30 PM
Wood blocking with metal framing question dj90423 Commercial Construction 24 05-12-2016 02:20 PM
Personal Living Expenses Spencer Business 48 05-11-2013 04:32 PM
Best Roller for Wood Shelves ? We Fix Houses Painting & Finish Work 8 03-22-2013 06:01 PM
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 02:41 PM
