Enclosing Garage Doors - Remodeling - Contractor Talk
Old 10-24-2018, 03:35 PM   #1
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 102
Ok, this is something I’ve never dealt with before, so I need some direction.
We’re looking at a project (basement refinish). Complete gut and redo. The home originally had a two-car garage – under the first floor of the house (basement level). The previous homeowner had the garage portion finished along with the basement portion of the basement level – a real “wall of shame” type hack/homeowner project – no permits.
The two garage door openings were simply framed in, insulated, drywalled (interior) and sided (exterior). Currently, when it rains or snows, water comes in under the wall and saturates the baseboard and carpeting.
Do I need to put grade beams in where the doors were? Is there another way to handle this?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 10-24-2018, 03:39 PM   #2
The Sheriff
Jaws's Avatar
Rewards Points: 772
Re: Enclosing Garage Doors
Pics?
Driveway slanted toward the garage?
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 10-24-2018, 03:49 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 362
it would be best to saw cut the slab across the old opening, remove it, pour a footing & stem wall.
if the driveway should slope back towards the structure you will likely need to add a trench drain.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Jaws (10-24-2018), Seven-Delta-FortyOne (10-30-2018)
Old 10-24-2018, 03:51 PM   #4
Rewards Points: 102
Pics?
No pics yet, but even if I had them, it looks like a finished exterior/interior. The driveway slopes away – very, very little. Not enough.
Old 10-24-2018, 03:58 PM   #5
The Sheriff
Jaws's Avatar
Rewards Points: 772
May be able to skip the drain - but I'd definitely pour a small footing/stem wall in the openings AND flash it with coil that goes above the height of the stem walls and probably Grace in front of that
If I can find some pics I did one like 6 years ago that we kerfed the concrete and had the roofer bend the flashing to slip in the cut while he was installing standing seam for us there.
Worked well
Sent from my SM-N920V using Tapatalk
John
Jaws is online now
Old 10-24-2018, 04:07 PM   #6
Rewards Points: 102
The existing house sits on caissons. Due to our soils, we don’t have too many structures built on footings. I think I would need to saw cut the slab, excavate, place a void then pour a grade beam between the caissons (epoxy pinned to the existing caissons/grade beams). I’d need to get the sill plate 8” above the grade.
Old 10-24-2018, 04:18 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 362
sounds about right.
why can't you form a stem wall on top of the grade beam?
griz is offline
Old 10-24-2018, 04:23 PM   #8
Rewards Points: 102
sounds about right.
In thinking about it, we are probably talking about the same thing - just different terms.
In reality, I was hoping you guys had some type of miracle solution - not requiring digging. I hate digging - even when I don't have to do it
The Following 3 Users Say Thank You to DaVinciRemodel For This Useful Post:
Californiadecks (10-24-2018), griz (10-24-2018), Jaws (10-24-2018)
Old 10-24-2018, 04:28 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 362
no miracle solution i know of....
cut, dig & cuss.....
griz is offline
Old 10-24-2018, 07:26 PM   #10
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,390
Well, in my opinion, digging is not necessary.
Just pour a stem wall the same height that the existing stem walls are at, in the door opening. slope the earth away from the new stem wall of course. This will take care of most of the water that may try to migrate under the new stem wall pour.
Make sure the new stem wall in at least 6" high.
Your biggest problem, of course, will be making sure the new concrete is sealed well enough against the old.
I don't see the need for a new footing under the framed opening.
Andy.
ScipioAfricanus is online now
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
hdavis (10-26-2018), tgeb (10-26-2018)
Old 10-24-2018, 07:35 PM   #11
The Sheriff
Jaws's Avatar
Rewards Points: 772
Water will infiltrate the cold joint eventually is why id pour it
Andy.
John
Jaws is online now
The Following 5 Users Say Thank You to Jaws For This Useful Post:
griz (10-24-2018), mrcat (10-24-2018), Seven-Delta-FortyOne (10-30-2018), shanewreckd (10-24-2018), TheConstruct (10-25-2018)
Old 10-24-2018, 09:03 PM   #12
Safety Third
shanewreckd's Avatar
Trade: Concrete Cowboy
Rewards Points: 582
That's true, unless you saw cut a thin keyway, and Sika in a water stop. Just saying, there are ways.
shanewreckd is offline
The Following 3 Users Say Thank You to shanewreckd For This Useful Post:
asevereid (10-26-2018), rrk (10-27-2018), TheConstruct (10-24-2018)
Old 10-24-2018, 11:25 PM   #13
Fire up the BBQ
griz's Avatar
Rewards Points: 362
Andy.
will argue the keyway/sealant method to the death.....
it fails in freeze/thaw country if you do not provide a footing/stem wall system that eliminates the sealed/keyway/cold joint system.
water & ice are an incredible adversary....
may work in some parts of the country, but is not a bullet proof remedy.
griz is offline
The Following 3 Users Say Thank You to griz For This Useful Post:
Jaws (10-29-2018), shanewreckd (10-25-2018), TheConstruct (10-24-2018)
Old 10-25-2018, 06:45 PM   #14
Rewards Points: 102
So, I talked to my engineer about this today and he gave me a couple of options for handling the garage door opening (basically what we discussed above). But then he blew my mind when I described what I wanted to do about the slope in the concrete garage floor.
Let me set a quick stage here:
• The garage floor portion of the basement slopes by approx. 4-1/2” over 27’.
• The bottom riser on the stairs from the upper floor is 10-1/2” (all the other risers are 7-1/2”).
• The stairs land on the highest part of the concrete – back of the garage. So, I have 3” that I can raise the floor in the back and 7-1/2” in the front (nearest the garage doors).
• My plan was to install sleepers 6-1/2” in depth that tapered down to 2” to level the floor. This entire sleeper floor would then be shimmed (with plastic shims approx. ¼”) to the appropriate height (add ¾” subfloor to leave me with my first 7-1/2” riser). All of this over a 6-mil poly vapor barrier sheet. Note: this sleeper floor structure is not attached to anything – not attached to the slab, the foundation… nothing. It literally floats on and with the slab.
• I would leave the mechanicals (furnace, water heater and water purification system) sitting on the concrete in the unfinished utility closet (approx. 4’ x 10’).
• We would then use rigid foam between the sleepers to create an insulation barrier.
• All of the walls would need a 3” slip joint at the bottom plates (that is standard procedure here) to allow the slab/floor to rise/fall without affecting the structure above.
After I described this to him, he said “No”! I was dumbfounded. He reasoned that that was a hack job and he would not stamp it. I pushed him on his reasoning and he just said take it to the county, but there’s no way they will approve a sleepered floor either.
Am I missing something here? This seemed like the simple part of the project.
Old 10-25-2018, 08:12 PM   #15
Designer/Contractor
Rio's Avatar
Rewards Points: 146
Did he have any suggestions?
Rio is online now
Old 10-25-2018, 08:29 PM   #16
Eater of sins.
Just put down the poly-vinyl and then pour the floor.
Make life easy for yourself, it would be cheaper also.
Andy.
The Following 3 Users Say Thank You to ScipioAfricanus For This Useful Post:
Fouthgeneration (10-27-2018), Jaws (10-29-2018), Rio (10-26-2018)
Old 10-25-2018, 08:38 PM   #17
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,194
Make life easy for your self, it would be cheaper also.
Andy.
That's a pour over for sure.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 10-26-2018, 08:11 AM   #18
Designer/Contractor
Rio's Avatar
Rewards Points: 146
Andy.
That's a good idea but I wonder if at the 2" side it might not be thick enough as with the poly vapor barrier there won't be any connection between the new and old concrete, might feel a little loose?
Rio is online now
Old 10-26-2018, 08:26 AM   #19
Rewards Points: 102
Andy.
Never done anything like this before. Walk me through this. You have my attention.
Rio, it would be 3" using this method
Old 10-26-2018, 08:41 AM   #20
hdavis's Avatar
Rewards Points: 360
It will feel fine at 2".
hdavis is online now
laminating garage doors cooper5114 Windows, Siding and Doors 14 07-16-2018 04:15 PM
Garage Floor Epoxy We Fix Houses Painting & Finish Work 9 12-31-2012 11:37 AM
Fire Rating of garage walls, exterior siding Richard_N_S General Discussion 9 12-12-2012 09:58 PM
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 08:14 AM
