Dust-Free Remodeling - Page 11 - Remodeling - Contractor Talk
Old 07-11-2013, 08:25 AM   #201
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Dust-Free Remodeling
Originally Posted by Dirtywhiteboy View Post
Too Hot to Sleep
No AC?
www.bcconstructionllc.com
BCConstruction is offline
Old 09-08-2013, 05:36 AM   #202
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Originally Posted by Remodelor View Post
If anyone's interested, I found this cheap Zipwall alternative the other day
http://www.harborfreight.com/2-in-1-...bar-66172.html
Beware, the reviews warn you to treat them gently as they are prone to breaking if you try to torque on the handle. For the money, if you baby them a bit, it looks like they'd be a nice deal. I've also read reviews from guys using them to hang upper cabinets, ceiling drywall and other heavy stuff without issue. Even the people that had them break seemed pretty chill about just ordering some new ones since they weren't expensive to begin with.
Side note: Apparently they go on sale for $10 a piece sometimes.
I had them, used them a few times and tossed them in favor of Zip Wall.
My advice is to make the poles more non slip. The hard rubber they use allows the poles to slip out easy, Kids can knock them over in no time.
Also, when you extend the pole out, it clicks into a detent and then you tighten down a knob. After that you start using the caulk gun type lever/rod to extend it the rest of the way and "lock it down". But that first extention has a tendency to pop out of detent, again causing the pole to fall. You can fix this by extending it and then driving a small sheel metal screw into it.
Overall for $140, you can get a Zip Wall set-up that blows the doors off HF. I now have 2 sets of Zip-Wall
http://www.amazon.com/ZipWall-ZipPol...words=Zip+wall
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
Old 09-08-2013, 11:57 AM   #203
kubie's Avatar
Trade: general contractor
Rewards Points: 278
http://www.harborfreight.com/8-inch-...tor-97762.html
so how would you hook up a filter to this?
kubie is offline
Old 11-20-2013, 02:26 PM   #204
Pat789's Avatar
With or without kids i would never use marble! i agree 1000% . Quartz is so good - and the new patterns they are coming out with are fantastic. Not sure about the pricing or quality of the new brands that are coming out. anyone ever try them? i always use ceasar stone or cambria
Pat789 is offline
Old 11-20-2013, 06:55 PM   #205
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Build a box to hold a furnace filter (whatever size you want. I made mine to hold a 16x20.)
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
Old 02-10-2014, 06:15 PM   #206
contractorgal's Avatar
Trade: finishes
Rewards Points: 12
I was very concerned about lead dust when renovating a customers' older home that had traces of lead paint. In addition to the much discussed and suggested zipwall system, I would highly recommend purchasing a lead ready kit from Builders Site Protection. http://buildsitepro.com Not only did it have a lead testing kit, but many items I needed to control dust and to protect me as well. I did have to purchase plastic, tape and the zipwall system separately but they carry everything and will match pricing. You should also use a negative air scrubber to keep dust from blowing outside your plastic enclosure. Purchase extra primary and secondary filters as they are cheap. The Hepa filters are pricey so you want to keep those clean as long as possible by regularly changing the less expensive filters! I found this out the hard way.
contractorgal is offline
Old 04-28-2014, 09:41 AM   #207
AmCraft Manufacturing
Roseann's Avatar
Trade: Industrial Curtains
Rewards Points: 146
You can use industrial dividers to section off areas. Floor sweep, anchor straps with d-rings, and custom grommets will allow you to attach to pretty much anything. Our company uses an industrial grade, fire retardant vinyl... and since it is pretty durable, you can re-use it in other areas and job sites.
Leader in Quality and Customer Service for Industrial Curtain Dividers
|AmCraft Industrial Curtain Dividers|
Roseann is offline
Old 08-24-2014, 09:07 AM   #208
smpcarpentry's Avatar
Rewards Points: 254
u know I am surprised that know one has mentioned the fast cap third hand it is like the harbor freight idea only 100 times better when I was looking for a dust barrier I looked at zip wall and the third hand and decided that zip wall seemed a little cheap? or flimsy? don't get me wrong I still see where I could and would use it just the third hand is also a bit more versatile and has a real nice door system for extended set up and use but for quick jobs zip wall would be fine
smpcarpentry is offline
Old 08-24-2014, 09:53 AM   #209
bbgcarpentry's Avatar
Trade: carpenter
do you have a photo of your set up.you place the ventilator in a box with a cut out for the filter ?
bbgcarpentry is offline
Old 09-12-2015, 01:30 PM   #210
AGullion's Avatar
Rewards Points: 1,422
Fast cap dust door..awesome
AGullion is offline
Old 09-12-2015, 05:06 PM   #211
EverVac's Avatar
Trade: Ex Carpentry contractor
Rewards Points: 4
I always Made a point to mask over Cold Air Returns as well.
EverVac is offline
Old 04-30-2016, 12:27 AM   #212
AGullion's Avatar
Dust Free remodeling? Ha. That's like too much fun. Ain't know such thing.
People will forgive some dust, but they won't forgive not caring or not trying.
And being clean matters, especially to women , who are normally clean, and have to clean the house you are ripping apart.
Zipwalls aren't a good value ...get the harbor freight blue poles, 3 mil 10x25 plastic from wal mart and take the savings and buy fastcaps ' dust door its really impressive and works.
My favorite trick is 1/8 hardboard , basically Masonite , from Home Depot ...it really , really protects floors and can be used over and over .
AGullion is offline
Old 04-30-2016, 12:27 AM   #213
AGullion's Avatar
Know such thing...lol
AGullion is offline
Old 04-30-2016, 12:30 AM   #214
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I "KNOW" lots of things...
and I know not to buy anything from Harbor Freight...
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 04-30-2016, 07:45 AM   #215
KAP's Avatar
Trade: Custom
Rewards Points: 36,964
The first one wasn't enough?...
You didn't even correct it on the second...
KAP is offline
Old 04-30-2016, 09:43 AM   #216
AGullion's Avatar
The blue poles from harbor freight crush the small diameter pokes from zip wall.
I found that at on this site, on the "harbor freight tools you actually use" thread.
The only better pole is fastcaps 3rd hand, and it's almost overkill it's so well made .
AGullion is offline
Old 04-30-2016, 09:47 AM   #217
AGullion's Avatar
I need some coffee and English lessons.
AGullion is offline
Old 04-30-2016, 10:00 AM   #218
tjbnwi's Avatar
Rewards Points: 1,834
I always supply the dust for free. People like getting things they're/there/their not charged for.
Truly the dust is free...
tjbnwi is offline
KAP (04-30-2016), Xtrememtnbiker (04-30-2016)
Old 04-30-2016, 10:02 AM   #219
AGullion's Avatar
This man is a genius. I have found my hero. I love it dude!
AGullion is offline
Old 04-30-2016, 10:15 AM   #220
AGullion's Avatar
I will say this....we all think we know a lot, and we do...and like to get on here and sound smart....but you can also get on here and learn, save time, and money.
Someone posted they buy blue poles at harbor freight , and I 've seen what happens to things that I set up and leave, like poles, so I went and took a look....and thought , wow, these are great ...harbor freight, hmmm, who would of thought?
I have no problem hauling a festool tracksaw, domino, of1400 ,an rotex in the same trailer with harbor freight blue poles.
Also, I want put a $20-25 hour finish carpenter on a $12 an hour demo. Make the cost fit the project, spend where it matters and save where you can.
AGullion is offline
Free Tacos for America - Tuesday the 30th JamesNLA Off Topic (Non Trade) 1 10-30-2007 10:52 AM
