Dust Control Setups? - Remodeling - Contractor Talk
Old 07-03-2017, 12:14 PM   #1
TSG_TX's Avatar
Trade: Concrete and Exavation
Rewards Points: 86
I figured this would be the best place to post my question...
Regarding a small commercial job. There will be some concrete cutting that needs to take place, and I'm looking for my best options in setting up a dust control system with negative air pressure.
The work will take place in a small medical facility.
TSG_TX is offline
Old 07-03-2017, 12:17 PM   #2
Dirtywhiteboy's Avatar
Rewards Points: 12,770
Re: Dust Control Setups?
Why not cut it wet and suck up the mess with the shop vac.
Dirtywhiteboy is online now
Old 07-03-2017, 12:20 PM   #3
tjbnwi's Avatar
Rewards Points: 1,160
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
https://www.amazon.com/Allegro-Indus...allegro+filter
tjbnwi is offline
Old 07-03-2017, 12:35 PM   #4
TSG_TX's Avatar
Rewards Points: 86
It's required to be contained. It's night-work in a day-operating facility.
TSG_TX is offline
Old 07-03-2017, 01:31 PM   #5
I suck it up as it's being cut and the mud is contained the the shop vac.
Old 07-03-2017, 01:35 PM   #6
TSG_TX's Avatar
Rewards Points: 86
Well, I normally do that as well.. but the project is requiring we provide a dust curtain and negative air pressure machine. I've never had to set up a dust control system, and not for a medical facility/clinic. So I am just getting ideas on how to proceed.
TSG_TX is offline
Old 07-03-2017, 01:41 PM   #7
Well there are the Zip Wall poles and the BuildClean Hepa filter and you would be logging. http://buildclean.com/
https://www.zipwall.com/xcart/
Old 07-03-2017, 02:09 PM   #8
Dan_Watson's Avatar
Rewards Points: 2,748
We run two Buildcleans. One recirculating and one on negative air. Plastic walls around with the area made as small as possible.
Hilti DCH 300, dust deputy Bosch dust extractor. just be careful on entry and exit of the cut, seems to spit out a little extra.
I'll look for photos or a vid.
Dan_Watson is offline
Old 07-03-2017, 02:10 PM   #9
TSG_TX's Avatar
Rewards Points: 86
What is your process like for wall/floor/ceiling setup?
TSG_TX is offline
Old 07-03-2017, 02:26 PM   #10
Dan_Watson's Avatar
Poles and plastic for walls, you can put a plastic ceiling up if needed. Floors get ram board, carpet shield, drops, whatever is needed.
What are you cutting? Walls, floor? How thick?
Old 07-03-2017, 02:36 PM   #11
TSG_TX's Avatar
Rewards Points: 86
Cutting 4" concrete slab. They're moving some rooms and freezers around. Two separate areas, about 16'x32' each, in different phases of the project.
TSG_TX is offline
floor sanders and dust extraction Erikfsn Tools & Equipment 10 12-27-2010 04:12 PM
Where/what to buy for dust collector filter? Greenbuggy Sandblasting 2 09-04-2010 09:49 PM
Table saw dust extraction roadweiry Tools & Equipment 15 05-23-2010 10:44 PM
dust in clear coat Traditions2 Painting & Finish Work 7 02-25-2010 09:36 AM
possible problem with the USG with dust control wolffhomerepair Drywall 2 02-25-2006 09:35 PM
