Drilling Holes Into Floor Joists For Plumbing ? - Remodeling - Contractor Talk
Old 04-30-2019, 12:23 AM   #1
Kmbarnin's Avatar
I’m putting in a half bathroom and I’m having a problem with toilet draining. To get the right flow there’s no way around it we have to drill through the floor joists for the toilet drain pipe. The pipes are 3 inch pvc. We have to drill through 6 or 7 of the joists. The floor joists are a weird 3 inch thick by 6 inches wide. They are roughly 20-22 inches apart and they run 8 ft long to the center giant IBeam that looks like it was meant for a bridge. How can I reinforce these beams or add support so that I can put in the 3 inch holes? There has to be a way but 6 inch wide joists (5.75 inches) does not seem wide enough to accommodate a 3 inch hole. I mean they are 3 inches thick (2.75 actual)
I can attach pictures later if needed.
Kmbarnin is offline
Old 04-30-2019, 07:59 AM   #2
hdavis's Avatar
Rewards Points: 1,976
Re: Drilling Holes Into Floor Joists For Plumbing ?
Hire an engineer.
hdavis is online now
greg24k (06-28-2019)
Old 04-30-2019, 08:05 AM   #3
diplomat
Golden view's Avatar
Rewards Points: 690
With slope you'll have less than 1" of meat on the joists. You'll have to run under and soffit it in. Very likely no way around it.
Golden view is online now
Drywallchic (06-27-2019)
Old 04-30-2019, 08:13 AM   #4
Not a people person
Chris Doom's Avatar
Trade: Remodel/landscaping/irrigation
Rewards Points: 295
I know where I am there's no way I'm getting a permit to cut that much out of floor joists. With that being said, We did a job where we went through ten inch joists with three inch pipes and we had 1/4 inch steel plates fabbed up with all the holes predrilled for the pipe and bolts that we impacted on either side of the joists. IDK dude, that way too much wood out of a joist. Iirc my local code is no more than a 20 % or something like that.
Chris Doom is offline
Old 04-30-2019, 08:14 AM   #5
hdavis's Avatar
Engineered steel reinforcers if you have a lot of cash lying around to burn.
Old 04-30-2019, 08:30 AM   #6
hdavis's Avatar
It's a basic code question. Holes have to be a minimum of 2" from the top or bottom of the joist, and no more than 1/3 the depth.
Run it above the joists, below the joists, or get an engineered solution for running it through the joists.
Old 04-30-2019, 08:34 AM   #7
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 988
There's all kinds of options. You just need to find one.
Welcome to the world of remodeling.
You can run the pipe between the joists, and down a wall. (Usually the best way)
You can hire an engineer and then a fab shop to make some fancy pieces of steel, if you want to go the expensive route.
You can box it in, as was suggested.
You can drop the entire ceiling.
You can elevate the WC and install a tank and sewage ejector, and run it up through the attic.
You can relocate the bathroom.
Lots of options. But drilling those joists ain't one.
The Following 6 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
A&E Exteriors (06-27-2019), greg24k (06-28-2019), hdavis (04-30-2019), ScipioAfricanus (04-30-2019), tang (04-30-2019), TheConstruct (06-27-2019)
Old 04-30-2019, 10:22 AM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
You could use one of those janky Saniflo toilets.
Inner10 is offline
Old 04-30-2019, 07:39 PM   #9
diplomat
Rewards Points: 690
Or a rear outlet toilet.
Old 06-27-2019, 06:04 PM   #10
Drywallchic's Avatar
Trade: Home improvements
Rewards Points: 104
Above attached garage bathroom. what would you do? If Golden View could chime in i would like to hear your thoughts. well tried to insert photo but i guess url not working because its not showing
Drywallchic is offline
Old 06-27-2019, 06:06 PM   #11
Rewards Points: 104
trying to upload jpegDrilling holes into floor joists for plumbing ?-img_20190624_161922.jpg
Old 06-27-2019, 06:16 PM   #12
Rewards Points: 104
Maybe i should start another thread. i happen to see this one on the same subject so thought i would tag along. would appreciate input. This is how i found it and before putting up drywall it obviously needs addressing. was going to do a plumber type box but will not work as i see it but i can move shower drain an inch and with offset should clear but then there is the toilet drain that was also hacked out so within a 1/4 inch in spots. shocking
Old 06-27-2019, 07:42 PM   #13
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 190
F'n plumbers.
Andy.
ScipioAfricanus is offline
The Following 4 Users Say Thank You to ScipioAfricanus For This Useful Post:
Calidecks (06-27-2019), Drywallchic (06-28-2019), greg24k (06-28-2019), TheConstruct (06-27-2019)
Old 06-27-2019, 08:20 PM   #14
TheConstruct's Avatar
Rewards Points: 1,410
I think the answer to both is get a plumber in to have a look. The joists in the picture should be sistered with new ones to solid bearing on both ends ideally.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
Old 06-27-2019, 08:32 PM   #15
Trade: Highwayman
Rewards Points: 988
Framer should have boxed it.
Old 06-27-2019, 08:53 PM   #16
rselectric1's Avatar
Rewards Points: 878
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
rselectric1 is offline
The Following User Says Thank You to rselectric1 For This Useful Post:
Weep holes in a picture window. RiverBG Windows, Siding and Doors 7 01-23-2015 11:41 AM
Pre-finished stair tread nail holes heavy_d Flooring 16 12-02-2014 07:10 AM
Drilling holes in porcelain tile ralphandson Tiling 21 12-25-2012 05:43 PM
HOLES in the Roof dougger222 Roofing 13 10-20-2012 12:05 PM
Drilling question redwood Decks & Fencing 40 09-04-2012 06:46 PM
