Broken Tip - Remodeling - Contractor Talk
Broken Tip
Old 06-23-2020, 06:47 AM   #1
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 1,116
Broken Tip
I need to get a door hinge off. There is a Phillips tip broken in one of the Phillips screws. It is flush with the screw head. I tried chiseling it out. I tried drilling it out. I tried taking a piss on it.
No joy!
Any ideas?
For some reason, I can't upload pictures (here or to Fototime).
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 06-23-2020, 07:04 AM   #2
tjbnwi's Avatar
Rewards Points: 4,530
Re: Broken Tip
Dremel with a cutting wheel. Turn it into a slot head screw.
If that doesn’t work, burr or grinding stone in the Dremel, grind head off screw.
tjbnwi is online now
DaVinciRemodel (06-23-2020)
Old 06-23-2020, 07:25 AM   #3
MarkJames's Avatar
Rewards Points: 19,225
Re: Broken Tip
If you have a cut nail, take a few 45 degree hammer taps at the edge of the broken piece. Just a thought before locating the dremel.
MarkJames is offline
Old 06-23-2020, 07:41 AM   #4
rrk's Avatar
Rewards Points: 5,246
Re: Broken Tip
I use a really small nailset and tap the edges of the broken bit , it usually loosens up and falls out
rrk is online now
Old 06-23-2020, 08:12 AM   #5
hdavis's Avatar
Rewards Points: 1,702
Re: Broken Tip
Phillips bit metal is probably harder than the screw metal, so drilling would be a no go.
If all else fails, MIG a nut onto it.
hdavis is offline
Old 06-23-2020, 08:15 AM   #6
Kingcarpenter1's Avatar
Trade: GC carpenter
Rewards Points: 8
Re: Broken Tip
I’ve tapped at them more than once with a concrete nail until it falls out.
Kingcarpenter1 is offline
Old 06-23-2020, 08:19 AM   #7
Trade: GC carpenter
Rewards Points: 8
Re: Broken Tip
Last resort gently get behind it with sawzall & metal blade with spakyl & t/u paint handy
Old 06-23-2020, 08:22 AM   #8
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 392
Re: Broken Tip
Drilling it will eventually work.
Easy Gibson
Warren is online now
Old 06-23-2020, 08:13 PM   #9
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,465
Re: Broken Tip
If that doesnít work, burr or grinding stone in the Dremel, grind head off screw.
Dremel a slot and unscrew with a flat driver.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 06-23-2020, 10:13 PM   #10
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,492
Re: Broken Tip
Omt's make excellent microtappers.
Rattle the f out of it with the corner of the omt blade.
sparehair is offline
Old 06-24-2020, 04:28 PM   #11
MarkJames's Avatar
Re: Broken Tip
I need some closure. What happened?
Old Yesterday, 07:20 AM   #12
Re: Broken Tip
It's still there!
Multi Tool... Fail!
Concrete nail... Fail!
Don't own a Dremel, so I had to buy one yesterday. It should be here in a week... there must be a lot of broken bits in screws Prime delivery is the 28th.
Old Yesterday, 07:56 AM   #13
Lettusbee's Avatar
Rewards Points: 1,572
Re: Broken Tip
Little pick tools and a magnet will usually get the broken tip out of the screw.
Don't get a dremel. That is so 1998.
Get the Milwaukee M12 rotary tool.
Way more useful.
Sent from my SM-N960U using Tapatalk
Lettusbee is offline
Old Yesterday, 08:03 AM   #14
Re: Broken Tip
Way more useful.
I always wanted a Dremel (I bought the biggest set-up possible).
Didnít even think about the M12 rotary tool.
Now I gotta have both!
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
Lettusbee (Yesterday)
Old Yesterday, 09:34 AM   #15
tjbnwi's Avatar
Re: Broken Tip
If you want to borrow one, there are a couple of Dremels at the shop.
Old Yesterday, 01:21 PM   #16
Re: Broken Tip
Thanks, Tom. I've always wanted one. It's on its way.
Old Yesterday, 03:47 PM   #17
MarkJames's Avatar
Re: Broken Tip
How about epoxy a screw onto it, head to head? Then back that out.
Or maybe super glue.
Old Yesterday, 04:15 PM   #18
Hack
asevereid's Avatar
Rewards Points: 392
Re: Broken Tip
What's the jamb made out of? Maybe you can rip it out (pry behind the hinge and pull the whole thing out).
Sent from my SM-G903W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
The Following User Says Thank You to asevereid For This Useful Post:
Idothat (Yesterday)
Old Yesterday, 05:42 PM   #19
tgeb's Avatar
Rewards Points: 1,006
Re: Broken Tip
It's still there!
Multi Tool... Fail!
I would take a pointed punch set it up dead center of the screw, swing a good heavy hammer at it as hard as I can, then smash my thumb with the hammer.
Spend the next few weeks with a black thumbnail.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
DaVinciRemodel (Yesterday)
