Boxing Ceiling Vent/Support Column - Remodeling - Contractor Talk
Old 04-28-2019, 04:50 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,816
For appearance sake I'd like to frame and wallboard and finish smooth this box portion that runs along the entire length of the basement (about a fifty foot run, broken by a wall and utility room area).
From a maintenance standpoint, T-Bar is best for everything. Given the plumbing connections right above (and wiring). But every drop ceiling that I can ever recall noticing leaves the steel column raw, "as is" (like in pic - column featured is ours). I take it, for reasons of framing/attachment.
The box will extend roughly 5 ft wide to conceal the gas furnace exhaust pipes.
While we'd like to keep it high as possible...any ideas to a great looking drop section and column casing?
Rest of house/bordering is all basic colonial mould and 6 panel doors.
Boxing Ceiling Vent/Support Column-ceiling-n.jpg   Boxing Ceiling Vent/Support Column-bsmt-col.jpg
artinall is offline
Old 04-28-2019, 06:12 PM   #2
avenge's Avatar
Rewards Points: 684
Re: Boxing Ceiling Vent/Support Column
There's no reason why the support can't be covered just because it's drop ceiling.
avenge is online now
Old 04-28-2019, 06:20 PM   #3
tjbnwi's Avatar
Rewards Points: 4,314
https://www.lowes.com/pd/pole-wrap-1...kaAlikEALw_wcB
There are other options available.
I drywall the duct areas.
Make sure you string this to keep it straight.
tjbnwi is online now
Crack at Peak in vaulted Ceiling Milhaus Drywall 21 11-04-2013 09:44 AM
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 27 02-26-2012 11:01 PM
Ideas for lowering a ceiling 4-5" sbcontracting Framing 3 04-25-2011 11:47 PM
Radiant Ceiling Heat - Drywall Falling Again CliffHollen Drywall 7 04-05-2010 04:18 AM
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
