Best Way To Make A Radius - Remodeling - Contractor Talk
Old 10-19-2011, 07:18 AM   #1
Frankawitz's Avatar
Rewards Points: 1,196
Hey Guys,
I have a question I am doing a countertop laminate and we have extended the one end to create a place to sit, Now I have rounded out the corners, the thing is when appling the edge I have tried plywood and partical board, I have a piece that's 29 3/4" long and 1 5/8" wide 3/4" thick. I made cuts every half inch and about 3/8 deep well I used the plywood first, well some of the cuts the wood fell out, I did wet the wood so to bend after I cut my notches, well I lined it up with the partical board that I am using on the straight edges, well the 3/4" partical board is thicker then the 3/4" plywood, so I scraped that and tried the partical board made my cuts I didn't want to wet it cause I figured it would swell and come apart, but when I tried to apply it to the radius of the counter it popped.
So then I took a piece 32" x 6" x 3/4" partical board and shimed it out so it came up to the 1 5/8, I was just going to cut the radius. Is there a better way?
Thanks
Frankawitz is offline
Old 10-19-2011, 07:35 AM   #2
DavidC
DavidC's Avatar
Rewards Points: 2,006
Re: Best Way To Make A Radius
How about gluing up 1/4" thick strips to build out to your thickness.
Good Luck
www.CookContractingLLC.com
DavidC is offline
The Following User Says Thank You to DavidC For This Useful Post:
roomdanis (10-19-2011)
Old 10-19-2011, 07:43 AM   #3
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Good Luck
Took the words right out of my mouth! 1/4" Strips till you get the desired thickness.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 10-19-2011, 08:34 AM   #4
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
The edge will be laminate right? Just over build with PB, cut and shape...
Use a router/ guide for final shaping.
A rectangular guide tacked down to the surface, as the router walks around the square corner, it makes a nice radius...
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
DavidC (10-19-2011)
Old 10-19-2011, 08:45 AM   #5
WildWill's Avatar
Rewards Points: 504
Originally Posted by Frankawitz View Post
Hey Guys,
Thanks
First, to make sure I'm clear here, you are doing a laminate countertop, not a countertop laminate. The edge generally supposed to be layered/laminated to create the thickness which ends up being 1 1/2". I have seen people glue and edge on there vertically but as you are finding out it makes things difficult on the radius.
WildWill is offline
Old 10-19-2011, 08:52 AM   #6
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Rewards Points: 570
Why not cut your top (3/4 pb) to radius and size then add build up to bottom (more 3/4 pb) then use flush cut router bit to get radius. Laminate edge then stick your top.
Eric K is offline
The Following User Says Thank You to Eric K For This Useful Post:
WNYcarpenter (10-21-2011)
Old 10-20-2011, 02:56 AM   #7
Frankawitz's Avatar
Thanks Guys,
What I did was I used plywood I cut a strip 1 5/8" x 43" and I made cuts every half inch and 3/8" deep then I put it in water to soak for 20 minutes, well when I took it out of the water it was curved just right. I clamped it to the edge of the counter top. I will post some pictures. Thanks agian for your time and comments.
Old 10-21-2011, 04:04 PM   #8
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
I made a lot of tight radius, curved counters for our power company (Yeah, the tops too) and found that glued-up luan (sp?) door skins work well.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 10-21-2011, 04:15 PM   #9
DavidC
DavidC's Avatar
That sounds like a time saver.
Good Luck
DavidC is offline
Old 10-21-2011, 05:31 PM   #10
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
Glad to hear it worked out for you!
I did the exact same thing in my kitchen....I used the Lewin Router compass to shape the particle board. Like Eric described I added pieces to the bottom to get to 1 1/4 and used a flush cut bit. I even went a step farther and used 3/8x 1 1/4 strips of oak that I glued and tacked to the edge. Applied the laminate to the edge and top the ran a router with a 1/2" chamfer bit around so I have a profile that shows oak.
Nothing knew, but it was pretty easy and it turned out great!
http://ecx.images-amazon.com/images/I/31V-XPMXVNL.jpg
WNYcarpenter is offline
Old 11-06-2011, 03:01 PM   #11
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
Cut your radius in a piece of particle board, attach and use a router with a template bit to match your radius. Not sure what type of edge your making but we always put 3" strips o build up around the edges then laminate, no vertical edge is needed just a 3" strip of particle board under the edges of top Laid horiontal
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Old 12-22-2011, 01:43 PM   #12
Frankawitz's Avatar
I meant to post some pictures so here they are. Hey Nath I was wondering whatever happened to all the pictures I have posted over the years went to?
Best way to make a radius-36218-samoa-kitchen-cabinets-142.jpg   Best way to make a radius-36218-samoa-kitchen-cabinets-143.jpg   Best way to make a radius-36218-samoa-kitchen-cabinets-141.jpg
Old 12-22-2011, 06:23 PM   #13
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
Very carefully.
JWilliams is offline
What should i make FramingPro General Discussion 49 10-11-2012 06:56 PM
How to make a header? JBM Websites and SEO 7 10-19-2011 03:03 PM
Bending plywood on interior radius Kent Whitten Finish Carpentry 61 05-31-2011 10:07 PM
Does Remodeling make Economic Sense... bigbuckeye Remodeling 13 04-04-2011 08:35 PM
Anyone ever make an ad banner before? Aggie67 Marketing & Sales 5 06-26-2009 12:43 PM
