Basement Floor - Sleepers? - Remodeling - Contractor Talk
Old 02-28-2011, 10:14 AM   #1
Stanford Construction
stanfordconst's Avatar
Rewards Points: 12
I've got a concrete basement floor in a 70-year-old home that isn't quite level and not very flat... it has a some visible cracks and a bit of a hump in the middle. This is in Colorado, so cold temperatures and expansive soils.
I have options.... one would be to rip out the entire 4" thick slab and have it re-poured. The other, which I think I'm going to use, is to lay down sleepers and build a subfloor on top. Here is the proposed design:
- Pressure-treated 2x4 sleepers, 16" OC and around the perimeter of the basement. Shimmed to level. Glued and ramset into concrete.
- 1" rigid foam glued to concrete between sleepers - both for insulation, as well as keeping cold air from hitting the concrete, avoiding mold.
- 3/4" subfloor screwed/glued to sleepers.
Anyone have any tips or changes before I jump in??
Thanks!
Drew
stanfordconst is offline
Old 02-28-2011, 10:27 AM   #2
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Question
Re: Basement Floor - Sleepers?
what are you putting down as a floor,,? is the basement floor dry?
B,
PrestigeR&D is offline
Old 02-28-2011, 10:32 AM   #3
Rewards Points: 12
The basement floor seems dry. (We've only lived here since Christmas, but it has been a regular winter so far - cold with snow)
I haven't chosen a flooring type yet, but I'm hoping that whatever subfloor I create, it can handle anything from carpet to laminate to cork, etc. I don't want the type of subfloor to be a limiting factor.
Old 02-28-2011, 10:36 AM   #4
K2's Avatar
Trade: Colorado master electrician, EC, B-1 GC
Rewards Points: 2,000
If you are on expansive soil, which you probably are, it would probably be best not to play engineer and call a real one. First off expansive soils only react to moisture and lack of moisture. So you have to figure out if you have any water getting to the subsurface and where it might be comming from and how often and what conditions are causing it. I would say that itf the subsurface had been dry for 70 years you probably wouldn't have had any heaving. And if there is heaving, there is also very good chance that any underground cast iron plumbing is broken and leaking making a bad situation worse.
Then there is design and I've seen a number of ways over the years that engineers might design a solution.
Good luck.
K2 is offline
Old 02-28-2011, 10:38 AM   #5
Wood Craftsman
Arrow
honestly,,,
you may be going over a poor or deteriorating slab....you may want to consider tarring it out and going with a new slab..throwing good money at a bad slab (band aid) and you may have problems later and have to rip it out and do it all over again....
just my 2 cents...
B,
Old 02-28-2011, 10:48 AM   #6
K2's Avatar
The Colorado front range has very unique, (crappy), soil conditions. It would probably be best to stick with local advice on this one.
K2 is offline
Old 02-28-2011, 10:53 AM   #7
General Contractor
greg24k's Avatar
Rewards Points: 8,776
What customer is willing to pay for the job, that is the question? There is few ways of doing it, depends on the budget.
Doing sleepers it has been outdated practice with all the new material that is out there.
If you plan going over the concrete, install rigid insulation on the concrete floor, so there is continuous protection without any voids, then install sub-floor right on it glued and screwed with Tap-cons right into concrete.
Another way of doing is to install a floor system that is easy to install by using floating sub-floor system, its already insulated and moisture protected, it's T&G so its a quick install.
If budget allows, new concrete is the best way to go. Stone and Drainage can be updated and installed the correct way with perforated pipe, new 3/4 clean stone and tied into the pit, moisture and insulation installed under the slab, and you will always have a nice dry basement.
greg24k is offline
The Following 2 Users Say Thank You to greg24k For This Useful Post:
Mellissam (11-17-2012), PrestigeR&D (02-28-2011)
Old 02-28-2011, 11:09 AM   #8
Level 27 Contractor
Bastien1337's Avatar
Trade: Renovation
http://www.cosella-dorken.com/bvf-ca...roducts/fl.php
Sebastian
Check out my gallery here http://on.fb.me/I2XylV
Check out my blog here http://sebastianbethke1337.wordpress.com/
Bastien1337 is offline
Old 03-01-2011, 08:36 AM   #9
General Contractor
greg24k's Avatar
Nice stuff Bastien, been using this on the foundation. Basements are nice and dry, after all the snow, rain a few floods we had the past few years .
greg24k is offline
Basement footings/walls poured wrong, now basement leaks, no sump installed Utah Ryan General Discussion 11 09-20-2012 06:04 AM
Temporary Solution for Severe Basement Mold Problem denny888 General Discussion 1 09-07-2010 10:05 PM
removing LARGE corner of basement walls and first floor. ApgarNJ Framing 59 06-04-2010 09:13 AM
Few questions regarding basement footer drains and my current basement floor Little Excavation & Site Work 7 10-27-2009 07:53 AM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 08:01 PM
