36' LVL Ceiling Beam - Is It Possible? - Remodeling - Contractor Talk
Old 05-13-2020, 02:06 PM   #1
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
Home built in 1961. Rafter, hip roof. Looking to add a flush beam to span 36'.
Can someone help me better understand roof load and what type of LVL beam I would need to span 36'? I know I can do the work and I am confident in my job execution, but I don't know how to calculate what type of beam I need. I assumed that a few 2"x10"x36' LVLs sistered together, posts at opposite ends, concrete footers, and joist hangers would do the trick. But I'm stuck on engineering the beam!
My question:
How do I figure out what type of LVL beam can be used?
36' LVL Ceiling Beam - Is it possible?-img_0130.jpg   36' LVL Ceiling Beam - Is it possible?-img_0134.jpg
aar0nhurst is offline
Old 05-13-2020, 03:03 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,206
Re: 36' LVL Ceiling Beam - Is It Possible?
You need to hire an engineer...
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
aar0nhurst (05-13-2020), overanalyze (05-16-2020), Seven-Delta-FortyOne (05-13-2020), SouthonBeach (05-14-2020)
Old 05-13-2020, 06:44 PM   #3
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
Definitely will
Old 05-13-2020, 09:25 PM   #4
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,734
Not something builders size on their own.
Project like this is probably going to need to be permitted anyway, and the building dept is most likely gonna need to see the engineering.
Might be able to have the lumber size it for you, since it's going to be through a company like Boise Cascade or Weyerhouser. They do a lot of their own engineering.
However, the building dept might not accept that. They might want a site specific engineering report, talking local wind and seismic into consideration.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
aar0nhurst (05-14-2020), griz (05-13-2020), overanalyze (05-16-2020)
Old 05-13-2020, 09:57 PM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,815
Build a truss..... a 4-6' deep truss, especially if steel rods/ cables are used for tension members. You might have to push it above the roof line, and weatherproof the exposed portion, think suspension bridge.....Or hide the structure in a 'clerestory' which would allow natural light and no loss of head room.
Run cables under plywood deck between opposite rafter tails to reduce dead & live loads on ridge beam
Fouthgeneration is online now
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Old 05-14-2020, 07:59 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,750
If you want to span a beam 36' what is the beams carry span?
Also, are you trying to make living space up there or only for walk-up storage?
greg24k is offline
Old 05-14-2020, 09:45 AM   #7
hdavis's Avatar
Rewards Points: 1,652
You have more than the beam to worry about, you have to get that load down to correctly sized footers.
hdavis is online now
The Following 5 Users Say Thank You to hdavis For This Useful Post:
aar0nhurst (05-14-2020), greg24k (05-14-2020), overanalyze (05-16-2020), ScipioAfricanus (05-14-2020), Seven-Delta-FortyOne (05-14-2020)
Old 05-14-2020, 11:24 AM   #8
General Contractor
greg24k's Avatar
Most definitely he will have cut the wall bellow and install a post to carry point load continuously down to the foundation and in some cases being this a gable wall most likely the main house girder is resting on that wall and if there is no structural pier and the girder just cut into a block, in many cases the block would have to be cut and solid grouted down to the footing (depending on how old the house is and how many stories the house is)
greg24k is offline
The Following 2 Users Say Thank You to greg24k For This Useful Post:
aar0nhurst (05-14-2020), overanalyze (05-16-2020)
Old 05-14-2020, 11:57 AM   #9
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
Uhhh........I'm hoping this is sarcasm, lol.
Old 05-14-2020, 12:04 PM   #10
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
Originally Posted by greg24k View Post
...what is the beams carry span?
I was hoping someone on here could help me answer that.
Neither. I'm trying to open up the floor plan between the kitchen, living area, and dining room. Attic space won't be used.
Old 05-14-2020, 12:11 PM   #11
Trade: Highwayman
Not here.
That's where engineers come in. I never size those things.
I sketch out a floor plan, rafter size/spacing, dimensions, foundation details that I can ascertain, and take that info to my engineer.
And voila, like magic, he spits out an answer.
aar0nhurst (05-14-2020), hdavis (05-14-2020), overanalyze (05-16-2020)
Old 05-14-2020, 12:35 PM   #12
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
Man, yes. So I have a CMU block wall as the girder and I assume it's on top of a concrete footer (I haven't seen the footer). If I understand you correctly, it's possible that I would need a solid pier down to the footing cut through my block girder? And only then could I set the post for the beam?
FYI, I know there is fungus on the floor joists. I am getting them treated and a vapor barrier put in place. Luckily no rot or termite damage.
Old 05-14-2020, 02:02 PM   #13
General Contractor
greg24k's Avatar
The beam carry load is the with of the house perpendicular to the girder (the joist span on each side of the girder)
That said I'm not giving you structural advice here I'm just curious to know what size that beam would need to be.
As the foundation and the footing goes that is a different story and the integrity of it and if it can support the additional load, i.e that would depend on the footing width, depth, and the soil.
So as an example with basic calculation...If you plan on doing a habitable attic space to meet L/360 floor load criteria @30LB PFT design load...and if your building width is 24' you need a beam to support a total of 13,320LB load that 370LB per foot... so every bearing point on each side has to support an additional 6,660LB.
That said a 5 1/4" x 18" beam can support 391LB PFT which is only good for a 26' span and the weight of that beam is 578.8 LB so I don't know how you plan on getting that beam inside, because the beam to span 36' will be even more and a much larger beam.
You should consult with an engineer and see what would be a steel I-Beam option.
Good luck
greg24k is offline
The Following 3 Users Say Thank You to greg24k For This Useful Post:
aar0nhurst (05-14-2020), hdavis (05-14-2020), TheConstruct (05-15-2020)
Old 05-14-2020, 02:23 PM   #14
hdavis's Avatar
Keep in mind, for replacing a ridge board with a structural ridge on a hopped roof, you'll most likely have columns coming down through living space, not the exterior walls. There probably won't be foundation under them as it was built.
Old 05-14-2020, 02:34 PM   #15
Trade: Highwayman
Take this for what it's worth, and you're getting it for free, so it's probably worth exactly what you're paying for it.
You're a bit over your head on this one. We can't give you all the info you'll need to do this job. It's a serious structural remodel, and it takes a lot of experience to pull these off correctly and safely.
In fact, the Mod staff here usually shut these down right away. They must be feeling generous.
The questions you are asking are actually irrelevant if you were getting this job permitted, because the AHJ would require you to do what we've repeatedly told yo to do, which is "Go get it engineered".
I'm guessing you're going to skip the permit process on this one.
If you are in fact in the construction trade, this is too big of a project to tackle for a laborer. Why don't you have a co-worker or 2 over on a Saturday, put a 12 pack on ice, and see if they can give you some help.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Old 05-14-2020, 03:15 PM   #16
hdavis's Avatar
Personally I do as much structural calcs as possible before going to a SE just so I have an understanding of what the options are. Nothing worse than a structural design you don't want to build.
The Following 3 Users Say Thank You to hdavis For This Useful Post:
aar0nhurst (05-14-2020), greg24k (05-14-2020), Seven-Delta-FortyOne (05-14-2020)
Old 05-14-2020, 03:22 PM   #17
rrk's Avatar
Rewards Points: 5,204
I dont think he wants to replace ridge, just carry ceiling load to be able to remove interior walls
the one I did recently was 21 ft long 5 1/2 x 16 microlam, which means nothing in his case but may give him an idea of size
rrk is online now
The Following 4 Users Say Thank You to rrk For This Useful Post:
aar0nhurst (05-14-2020), greg24k (05-14-2020), hdavis (05-14-2020), TheConstruct (05-15-2020)
Old 05-14-2020, 04:52 PM   #18
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
I'll call the lumber yard tomorrow and get an engineer's information.
Good luck
Thank you, sounds like I'm going to need it!
Old 05-14-2020, 05:04 PM   #19
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
D'oh! Didn't realize that.
I'm going to call an SE on this one for sure. I wasn't planning on getting this permitted but after reading everyone's comments, I'd be a fool not to listen. And as far as "irrelevant questions" go... you're not wrong but a day ago I didn't know so much went into a beam! I figure better for me to ask and listen than to not ask and end up with a collapsed house.
Last edited by aar0nhurst; 05-14-2020 at 05:06 PM. Reason: too many exclamation marks
Old 05-14-2020, 05:05 PM   #20
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
Can't thank everyone enough for the help, info, and guidance on this one. I'm going to call my lumber yard tomorrow and get a couple SE numbers. I'll post an update once I have more info on my project.
