2nd Story Addition; In The Winter? - Page 3 - Remodeling - Contractor Talk
Old 01-17-2008, 08:52 PM   #41
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: 2nd Story Addition; In The Winter?
Originally Posted by Jason W View Post
It could be possible to build the header on the new double top plate were there are windows and openings below.
Threads like this are why I love this place!
-Steve
TimelessQuality is offline
Old 01-17-2008, 08:53 PM   #42
Preserving the Past
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Rewards Points: 2,060
I'll have to check the span strenth of the TJI's. I may have no choice but to build it above the existing ceiling and break up the TJI's with a double LVL.
Originally Posted by oldfrt View Post
I was speaking of a center bearing wall.With 10' engineered joists at 22'.some support is needed.
Originally Posted by cleveman
Surely the 2x6 ceiling joists aren't spanning 22'? There isn't a wall or beam in the middle?
Not one thing!
Correction: Every 3rd or forth joist there is a 2x4 hung from the rigde and nailed to the ceiling joist.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 01-17-2008, 08:57 PM   #43
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
go back a page and read my posts carefully again
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-17-2008, 09:00 PM   #44
Preserving the Past
I guess were on the same page anyway! Sorry this thing is cruising along pretty fast!
Facebook | Twitter
Old 01-17-2008, 09:12 PM   #45
oldfrt's Avatar
Rewards Points: 94
You could order clear span engineered roof trusses and put the entire ceiling load on the exterior walls
edit to add. scroll up
I answered all those balloon frame no header in existing wall questions.
I guess I missed that post!
Your right, roof trusses would be a good call here AW.
There's a lot going on here,hard to soak up all the approaches.like Jason said,cruising pretty fast.
I guess it will come down to is the building dept acceptance.Hopefully he'll only have to submit one set of detailed plans.
oldfrt is offline
Old 01-17-2008, 09:19 PM   #46
Preserving the Past
If the H/O can deal with the rough numbers I give them. The first stop will be the Codes Department so I don't waste to much time at the drawing board.
I do like the trusses very simple and very quick. Thanks all. I'll keep you posted.
Add: The best part about the trusses is they come with a stamp of approval from an engineer.
Facebook | Twitter
Old 01-17-2008, 09:23 PM   #47
Al Smith
A W Smith's Avatar
you can also order your trusses with the raised or hat ceiling already in them if you make the walls lower to match soffits and ridge with existing, that in itself will save labor and speed dry in.
Al Smith
Old 01-17-2008, 09:27 PM   #48
blueclawjr's Avatar
Exclamation
Hi I am new here but I first must agree with keeping the walls at 7' this as stated previously will give you the allowance needed to cut the ballon framing and build a new box and sister the existing 2x6 joists with 2x8 micro lams (or 2x8doug with a beam running the center of the kitchen flush with hardware).To keep the existing ridge line you are looking for. I also agree to do as much of the framing as possible prior to actually opening the roof up.Like was stated earlier(i am sorry for not using names but read all the threads and can't remember who said what)get it open and deck framed and sheathed then tarp off right. There should not be a drop of water.You should not have to disturb the ceiling below at all until the final phases of the rough wiring and plumbing are addressed then only minor patching will be needed.If you completely remove the existing ceiling joists then you will have to open walls to place supports to keep walls straight and plum.>As you will be remodeling the kitchen later I think you don't want to have to place nailers on the floor to tie your wall supports into.I guess you can do it from the outside but then you must nail,screw or lag into the existing siding.You can remove one at a time and replace with the larger lumber of your choice.I wish this job was in my neck of the woods as I love a challenge.Last but not least.You said they had 35k to spend.then you stated you think $100 per sq. ft....that is like 12k more than they have budjeted for the job.Just watch you don't get into a pinch and keep the final small.By the way we get around $135-$150 sq ft. here for that job.........Good luck
blueclawjr is offline
Old 01-17-2008, 09:31 PM   #49
Preserving the Past
I was thinking that too. Fly 18 pcs up with a crane and I'm done framing! Well worth the cost of a small crane for a day
Thanks again
Facebook | Twitter
An endless story par3144 Off Topic (Non Trade) 50 01-21-2008 10:36 PM
HVAC for 2nd Story Addition? watersda HVAC 8 09-28-2007 07:26 AM
Advice with room addition and blueprints A.W.Davis Remodeling 35 03-28-2007 06:32 PM
Winter Slowdown Paul Burns Painting & Finish Work 4 03-05-2006 01:26 PM
Addition Full Basement sady Specialty Trades Picture Post 4 12-29-2005 09:51 PM
