Wireless Router, Printer, Etc... - Technology - Contractor Talk
Old 05-04-2011, 09:40 PM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 7,650
I currently have my laptop configured with a Comcast modem and wireless router. Though the router is only feet away, I'm thinking I might have higher speeds and better performance if I wire the computer directly to the cable modem via a Cat 7 cable.
My question...I use a wireless printer in a different room.
Will I have to move the printer and connect it via a cable also?
Thanks.
Robie is offline
Old 05-04-2011, 09:46 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 949
Re: Wireless Router, Printer, Etc...
Shouldn't have to. The wired computer will transmit the signal to the wireless printer as long as it is configured correctly.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 05-04-2011, 09:52 PM   #3
Robie's Avatar
That's where my fun should begin...
Robie is offline
Old 05-04-2011, 09:57 PM   #4
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 949
Run the setup software and it should give you the option to reconfigure it.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Robie (05-04-2011)
Old 05-05-2011, 10:17 AM   #5
ziemer's Avatar
Trade: General & Design
Rewards Points: 27
I've got a similar setup at my house and it shouldn't matter if you're hard wired or wireless into your network. My laptop is using my WiFi whereas my desktop is hard wired and both print with no issues to my wireless printer.
ziemer is offline
Old 05-05-2011, 10:49 AM   #6
aptpupil's Avatar
Rewards Points: 1,894
Thanks.
wired connections are generally faster and more stable, so if it's easy then go for it.
as for the printer, the computer should still be able to see it whether it's hooked up to the router by a wire or not.
aptpupil is offline
Old 05-05-2011, 11:54 AM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
If you plug the computer directly into the MODEM you probably be on a different sub net and you won't even see your printer.
You want to plug your laptop directly into the router.
Your transfer rate will be wayyy higher when its plugged in, but web browsing and printing won't be all that noticeable.
Where are you getting Cat7 cable? I have yet to see it at a retail level.
Inner10 is offline
Old 05-05-2011, 03:22 PM   #8
Robie's Avatar
Got a 14' and 3' at Amazon...
http://www.amazon.com/gp/product/B0028B8D2Q
So, plug my laptop into the router and not the modem?
Seems like putting the connection through another piece of hardware would defeat the purpose...no?
Robie is offline
Old 05-05-2011, 03:42 PM   #9
General Contractor
greg24k's Avatar
Rewards Points: 8,478
Plug your Modem cable into the router jack which will be named wan, up-link or Internet... It will be separate from every other jacks you have there. After connecting the cable, be sure to power on and off the modem to make sure your router recognizes it.
Then use this "http://192.168.1.1" to get into router settings the box will popup leave the name blank and your password will be admin, be sure to change that and give a nice password, so you don't get jacked.
Then follow the setup instructions.
Then you will need to set up your network so your PC will communicate with laptop and your printer and vise versa.
greg24k is offline
Old 05-06-2011, 08:13 AM   #10
Inner10's Avatar
Do you have a Comcast Modem or Modem Router?
You have to have them on the same sub net if you want it to ever work.
Inner10 is offline
Old 05-06-2011, 04:53 PM   #11
Robie's Avatar
I have a Comcast modem and Comcast router. They are sitting right next to each other. The laptop is only a few feet away and the printer is two rooms away. I just thought I could better my connection with a good cable running directly from the modem to the laptop. Was concerned that I wouldn't be able to use wireless printing.
Robie is offline
Old 05-06-2011, 05:11 PM   #12
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
Windows 7 will most likely work out of the box and recognize the printer using the drivers already included and shipped with the OS.
JHC is offline
Old 05-06-2011, 07:07 PM   #13
Robie's Avatar
I'm still in the dark ages and using XP. Had it for a few years now...printer is 6 months old.
Robie is offline
Old 05-09-2011, 09:39 AM   #14
Inner10's Avatar
Plug the modem into the router and hook everything up to the router so its on the same subnet. Then everything will work.
If it doesn't throw that POS comcast router in the trash and get a real router.
Inner10 is offline
Old 05-10-2011, 07:00 AM   #15
Robie's Avatar
Cables came yesterday. Plugged the modem into the laptop and everything works fine. The printer works fine.
I did one of those speedtests and came up with 22mbps. I don't know if the test is reliable, but according to the site, that's pretty fast.
Thanks for the help.
Robie is offline
Old 05-10-2011, 07:23 AM   #16
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 949
And here you were all worried over nothing.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 05-10-2011, 07:28 AM   #17
Robie's Avatar
Yup. Back in the day, I'd stay up all night getting into the "brains" of the computer...change things around, etc. Technology has passed me and I tend to get a little nervous if I have to do too much technical stuff. Plug and play be me.
Robie is offline
Old 05-10-2011, 09:08 AM   #18
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 949
Plug and play is great!! Until it isn't. Then you are fighting the computer for control.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Woodpecker router lift and top ApgarNJ Tools & Equipment 3 07-13-2010 08:14 PM
Wireless internet antenna idea Cjeff Technology 0 02-20-2010 10:38 PM
Bosch router table w/ router mattsk8 Contractor Swap 0 01-01-2010 10:51 PM
Wireless networking......printer Teetorbilt Technology 9 09-04-2006 04:12 PM
Wireless router Big Dave Technology 7 08-17-2006 06:16 PM
