Windows 10 Crash - Technology - Contractor Talk
Windows 10 Crash
Old 12-27-2015, 07:59 PM   #1
Remodeling GC
kevjob's Avatar
Rewards Points: 412
Windows 10 Crash
Heads up for everyone.
I updated to windows 10 from 7 couple months back, everything was fine until today.
My computer tried to update and then something went haywire. I cannot get into windows 10 as it is stuck in Automatic Repair "Loop"
It shows blue screen and tries to fix itself to no avail and will not let me recover or restart to safe mode. There is a good possibility all my data is lost, small chance it may be recovered but back up everything NOW so you don't lose anything.
https://www.google.com/webhp?sourcei...c+repair+stuck
I took mine to a compute repair guy to try to recover data, Quickbooks, documents and photos. Won't know till a couple days whether or not it is a total loss.
Microsoft was less than helpful and basically said tough luck, sorry.
kevjob is offline
Old 12-27-2015, 08:44 PM   #2
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
Re: Windows 10 Crash
Chances are the data is fine just because windows crashes doesn't mean data is lost.
I'm sure somewhere in Microsoft EULA it says something about win 10 still being in testing.
If the repair guy says data is lost find yourself an actual data recovery guy. Really you could probably get it all back with a bootable Linux CD and an external HDD
SectorSecurity is offline
Old 12-27-2015, 08:51 PM   #3
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Looks like this isn't a new issue with Win10.
I would also add that not all PC's are equal.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 12-27-2015, 10:43 PM   #4
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
I'll be reserving my copy of Windows 11 when they figure out the bugs in 10.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 12-28-2015, 12:14 AM   #5
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,650
is Quick books pro 2013 Contractor edition compatible with 10?
Calidecks is online now
Old 12-28-2015, 12:42 AM   #6
The Sheriff
Jaws's Avatar
Trade: Builder
Rewards Points: 16,436
Just got Windows 10 with my Surface tablet. Hope it doesnt become a problem
"If I have wounds I have two choices, See myself as a victim or see myself as a warrior"
Cheif Joseph
Jaws is offline
Old 12-28-2015, 01:06 AM   #7
Hair Splitter
Trade: General
I was running 09 on it and then upgraded to 15...no issues with either one.
The Following User Says Thank You to TNTRenovate For This Useful Post:
Calidecks (12-28-2015)
Old 12-28-2015, 01:17 AM   #8
GC/carpenter
Calidecks's Avatar
Did you have to do a reinstall of all your programs?
Old 12-28-2015, 01:29 AM   #9
Hair Splitter
Trade: General
Nope. It upgraded the system around my old system.
Old 12-28-2015, 12:40 PM   #10
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,878
When I had my desk top worked on the other day the tech said 7 does not update to 10 very good like 8 does.
Sent from my HTC Desire 610 using Tapatalk
Randy Bush is offline
Old 12-28-2015, 01:40 PM   #11
I have never liked the in place upgrades , unless it was just upgrading fr win 7 HP to pro.
I much prefer to back up what I want and wipe the disk do a clean install, but that's just a personal preference I have
Old 12-28-2015, 01:56 PM   #12
Hair Splitter
Trade: General
All my stuff is on back up already. I figured it couldn't hurt to try. 6 months later, not a single issue.
Old 12-29-2015, 05:58 PM   #13
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
I agree but I got lazy on this one (7-10) on my desktop, 3 months later seems the HD died... maybe. I need to pull it and put it in an external case. Pretty much everything of value is backed up so I'm not too worried.
RobertCDF is offline
Old 12-29-2015, 06:15 PM   #14
GC/carpenter
Calidecks's Avatar
I installed 10 on my wife's pc and now it won't come out of hibernate without a reboot. Tried jacking with the power settings to no avail.
Old 12-29-2015, 06:23 PM   #15
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
I updated from 7 to 10 and ain't had one issue. I have found something I don't like though. When copying multiple files if they are the same file name it won't ask me anymore if I want to keep the originals and just rename the new ones with a (1) on the end. Stupidly annoying
www.bcconstructionllc.com
BCConstruction is offline
Old 12-29-2015, 07:23 PM   #16
Randy Bush's Avatar
That happened with mine going from 8 to 10 . Also only way it would power down was with the button. Sent it in for some repairs and when got it back things worked right then.
Sent from my LG-V410 using Tapatalk
The Following User Says Thank You to Randy Bush For This Useful Post:
Calidecks (12-29-2015)
Old 12-29-2015, 07:39 PM   #17
Remodeling GC
kevjob's Avatar
Rewards Points: 412
My computer guy saved all my data and rolled me back to windows 7. I bought an external hard drive and will be backing up every couple weeks or so.
He told me I had the luck of the irishman!!!
That was stressful......
kevjob is offline
The Following User Says Thank You to kevjob For This Useful Post:
aptpupil (12-29-2015)
Old 12-29-2015, 07:40 PM   #18
Radical Basement Dweller
Robie's Avatar
Rewards Points: 1,184
I'm sticking with 7 until I no longer can. The popup comes up every time I boot up...
Robie is offline
Old 12-29-2015, 07:46 PM   #19
Remodeling GC
kevjob's Avatar
Rewards Points: 412
Yes you should it will be supported till 2020.
kevjob is offline
Robie (12-29-2015)
Old 12-29-2015, 10:11 PM   #20
Recently rolled out carbonate backup solution for one of my customers. On the fly cloud backup and you pay for the amount of storage not per user.
They used to try and do the oh Bob in accounting will remember to back up to his external. Ya right, just like Bob will remember to update and run his antivirus.
Very seldom do I see a drive crash where data can't be recovered at all.
Running WIN 8.1 on a mac in Parallels..... wallmaxx Technology 23 05-29-2015 09:08 PM
Anyone Knows about Windows Company named Landmark Windows? richardkg General Discussion 1 12-10-2014 11:26 PM
Hurd Windows, where are the weep holes Lettusbee Windows, Siding and Doors 13 07-18-2014 08:25 AM
2012 IECC - Aluminum Vs. Vinyl Windows Glazier_David Windows, Siding and Doors 3 01-27-2013 02:42 AM
Anderson windows not installed properly world llc Windows, Siding and Doors 35 08-07-2012 09:50 PM
