Printer Problem - Technology - Contractor Talk
Printer Problem
Old 01-06-2010, 09:09 PM   #1
Teetorbilt's Avatar
Rewards Points: 2,000
Printer Problem
Hardware is a Compaq Presario S5200NX and an HP Deskjet 5150. OS is XP.
Everything is working fine until I get an HP w2338h monitor for christmas and installed the software.
I paid my phone bill, printed the reciept and I got the header, logo and a bunch of black lines where all of the info should have been.
Went to HP diagnostics and found that I needed a service pack. Downloaded and installed that. Now it makes all of the motions/sounds of printing and spits out white paper.
Tonight I called overseas, spit out info for 1/2 an hour and was told that it was a printer problem and I'd have to pay to fix it. BS! I repeatedly stated that the printer worked perfectly until I installed the new monitor software and the patch.
Any ideas would be helpful.
Albert Einstein
Teetorbilt is offline
Old 01-06-2010, 09:14 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Printer Problem
Just a shot in the dark.....
Unplug printer from puter and uninstall ALL software relating to printer.
Now, just plug printer in via USB and let Windows do what it wants. I have found in the past, Windows-based drivers are sometimes more friendly than the actual manufacturer drivers.
Good luck.
Angus
angus242 is offline
Old 01-07-2010, 07:01 AM   #3
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Re: Printer Problem
Uninstall all HP software for your printer and download from this page:
http://h10025.www1.hp.com/ewfrf/wc/s...product=304431
I'd only worry about the main driver if it were me. The full package has all the junk software 90% of us don't use anyway. Only get that if you use the software.
You can install the first two updates and the utility as well if you like. Nothing else should be necessary.
gideond is offline
Old 01-15-2010, 03:06 AM   #4
Teetorbilt's Avatar
Re: Printer Problem
Sorry for the delay, family problems abound.
Your suggestions worked like a charm! I just printed another invoice.
Albert Einstein
Duraspin deck screw problem HandyHails Decks & Fencing 9 06-04-2012 05:33 PM
Spray Knockdown Problem. Drivetech Drywall 22 07-02-2011 10:25 AM
Existing addition on slab drainage problem dberkey1 Construction 4 08-21-2009 05:41 AM
Problem in corners woodchuck2 Painting & Finish Work 28 08-01-2009 10:07 AM
Problem with Sub Patrick General Discussion 9 07-15-2009 12:41 PM
