Piecework Tracking - Technology - Contractor Talk
Piecework Tracking
Old 07-11-2019, 04:02 PM   #1
Windowguy75's Avatar
Trade: Windows and Doors
Rewards Points: 12
Unhappy
Piecework Tracking
I need some help!!
We have a small construction company and we specialize in window and door installations in new construction. We pay our guys based on what type of window or door they install and how many. Each one pays a different amount depending on size and type. Right now we are just using a Excel spread sheet which was fine in the beginning but we have since grown to 15 employees and it is very time consuming and a bit of a pain to keep track of everything as we are growing.
So my question is this, does anyone know of any type of software that is available that would work for this type piece work detail or does anyone else deal with this in your line of work or business? There has got to be an easier way!! Thank you in advance for your help.
Windowguy75 is offline
Old 07-11-2019, 05:18 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 430
Re: Piecework Tracking
I'd stick with the spreadsheet, or its kissing cousin, a database application. No matter what software you use, the choke point is data entry, and that's going to be there regardless.
You can make the data entry a bit less painful if you find a spreadsheet/database guru to customize the interface for you. Done well, you'd never suspect the backend was Excel, Access or whatever.
I'm not aware of a general-purpose product that would fit your situation well.
Tinstaafl is offline
hdavis (07-12-2019)
Old 07-12-2019, 08:41 AM   #3
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,108
Sounds like you are skating on the edge of illegal paying your men this way. If they are truly independent contractors then they need to set the price for their jobs, not you, and they need to carry all the appropriate insurances, licenses, etc.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
Defenestrate (07-12-2019)
Old 07-12-2019, 09:22 AM   #4
Rewards Points: 12
They are not independent contractors. They are actual employees of the company. As long as you keep track of the hours worked and make sure they meet the minimum wage requirements then it is perfectly legal.
The Following User Says Thank You to Windowguy75 For This Useful Post:
Calidecks (07-31-2019)
Old 07-12-2019, 10:50 AM   #5
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Rewards Points: 180
Are you saying the pay varies based on size? For instance a 30" door pays X, a 32" door pays Y, and a 36" door pays Z? I wouldn't think it would be worth trying to track that so specifically. Each size/pay has to be looked up, etc.
In excel, you can just have a cell/column for number of doors (of any size, all together) and a cell/column for number of windows (all together), and then multiply and add into one cell/column. Seems like it would be a lot less data entry. Granted some doors and windows are a bigger PITA to install than other types, but if you find a happy place and just use one window price and one door price, it seems like it would be better for everyone.
But maybe I'm misunderstanding how you pay.
Jim P.
jproffer is offline
Old 07-12-2019, 11:01 AM   #6
Rewards Points: 12
Yes to a certain extent it is like that. A single door pays X a double door pays X and so on. A single window pays X, A twin pays X ..... Basically the bigger and heavier the window or door is the more it pays. I have thought about just doing as your saying and have one price for a door and a window no matter the size but I cant really figure out a price that would be beneficial to our guys and for the company to make the profit it needs to. I don't know, maybe there is a middle ground somewhere. Just haven't really figured out where it is yet.
Old 07-12-2019, 07:56 PM   #7
VinylHanger's Avatar
Rewards Points: 11,654
IIRC, we always broke it at a 4 x 4 window, then it went to the next level. If it was a crazy 10x5 triple ***, it was more because of the hassle. Same for second story work, etc.
Single doors one price, sliders one and French doors another.
I think you are over thinking it.
VinylHanger is offline
Old 07-12-2019, 09:55 PM   #8
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 40
Have you looked at old numbers? I'd think you could take 3,456 installed windows, divide that by the money you've paid out and see if that would be an acceptable price for a basic window. Pay double for a complicated window and pay for that with time saved on paperwork.
Side question, if you don't mind... do you get adequate quality when you pay by the unit?
Defenestrate is offline
Old 07-31-2019, 10:15 AM   #9
carpenter uk's Avatar
Trade: carpentry
Rewards Points: 657
Set up each window in quickbooks as an item, create purchase order for the items fitted
carpenter uk is offline
Old 07-31-2019, 12:58 PM   #10
Dirtywhiteboy's Avatar
Rewards Points: 13,062
Unit price is the fastest hackest way you can get they tossed in. Shocked they are still done that way.
Dirtywhiteboy is online now
Old 07-31-2019, 07:12 PM   #11
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
Rewards Points: 748
Like Tin said, data entry is going to be the biggest pain. If you use quickbooks I don't see why you wouldn't be able to enter the piecework in per employee per job. Should allow you to track each person's work and job costs better
"Your problem does not constitute an emergency on my part"
CScalf is offline
Old 08-08-2019, 10:38 PM   #12
MichiganMan's Avatar
Trade: Low Voltage
This is an EASY fix. You get get rid of all the hassle and automate your system. You only have to enter each product into your system 1 time! Then attach a corresponding barcode to each product. The installer scans each product they install. The barcode automatically fills in the rest. It takes seconds to complete. There are many many ways to simplify the process your using already. I work in Data/Communications Networking. I install this stuff all the time. SAP is hands down the best inventory control software out there. We run a few cables, install a few handheld scanners, update your inventory and setup your billing, online ordering, work order printing, and anything else you can think of. So many companies today are held back by their lack of technology. I can automate a massive company or a single family home and make life so much easier. It’s worth every penny to take the next step. You’ll free up so much time you’ll be able to triple your workload and income. [email protected] is my email. When your ready to take things to the next level, let me know. It’s a hell of a lot cheaper to do then most people know. Small Business is the backbone of America and anything I can do to help reinforce it while taking down huge corporate competitors is just a bonus.
MichiganMan is offline
