PDF Editor On The Fence. - Technology - Contractor Talk
Old 05-21-2019, 01:22 PM   #1
VinylHanger's Avatar
Rewards Points: 11,662
I can't find the post I started a while back.
I've been using Adobe DC to edit PDFs. It works, but it is costing me 25 bucks a month. That is crazy for the few I do.
However, when I need it, it is a great tool and hard to not have it.
Is there another one that is cheaper or free that actually works or doesn't put a watermark on stuff. I thought there were some others.
The only reason I still have it is I forgot about it until I saw a charge. Hate the cost. It is outrageous.
VinylHanger is offline
Old 05-21-2019, 01:44 PM   #2
KAP's Avatar
Trade: Custom
Rewards Points: 36,930
Re: PDF Editor On The Fence.
It's a business expense... charge $5-$10 extra per customer as part of admin costs... covers the cost, makes you money on it instead and removes it as something to be even renting space in your head...
Think of it this way... you have consumables you use in every job that are a recurring cost and you need them to do your work (and cost more than $25/month)... you (hopefully) add a mark-up to materials to cover the intangibles... this is no different... it gets charged to the customer...
There's free versions of most anything out there... they're not always better, but here are some options... https://www.lifewire.com/best-free-pdf-editors-4147622
KAP is offline
Old 05-21-2019, 04:44 PM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 190
THIS is the one I like to use.
It is not as good as Adobe but it is free and it does work.
Andy.
ScipioAfricanus is offline
Old 05-21-2019, 05:52 PM   #4
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,350
Foxit pdf is what I use the reader is good enough for most things and is free.
I use it to add text highlight stuff etc
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
Old 05-21-2019, 07:00 PM   #5
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,814
It's not free, but I use this:
https://www.tracker-software.com/pro...xchange-editor
Home Designer Series Software
B.Johnson is offline
Old 05-21-2019, 07:16 PM   #6
Thanks for the info. I'll poke around tonight and see if those work for me.
The Adobe one isn't perfect, that's for sure. You'd think it would be, but it's a kludgy affair.
Arched-panel Grouped Baluster Fence basswood Decks & Fencing 40 10-02-2012 06:03 AM
cedar fence and small historic deck swartzj81 Decks & Fencing 2 09-02-2012 03:01 PM
Construction detail Q?, re: a RW fence w/ Horizontal boards / slats Will Johnson Decks & Fencing 16 07-08-2012 10:33 AM
Fence stain Rslstructures Construction 3 06-22-2012 11:13 PM
DW744 Fence Adjustments TBFGhost Tools & Equipment 3 05-30-2012 03:21 PM
