Flash Drives - Technology - Contractor Talk
Flash Drives
Old 06-02-2019, 02:48 PM   #1
Tom M's Avatar
Rewards Points: 8,066
Flash Drives
So these things are terrible. I don't know if the contacts wear out and can be bent back but they lose connection.
I just bought a newer one with higher capacity so if I regain contact I can transfer it but I can't.
Any tricks?
Tom M is online now
Old 06-02-2019, 03:56 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,316
Re: Flash Drives
Sometimes, the issue is your card reader, the cord for the reader, or the USB port itself.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 06-02-2019, 04:18 PM   #3
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Flash Drives
The actual port on my laptop got tired real quickly.
I've bent the rectangle on the flash drive slightly to create more pressure on the contacts. I've also used a short usb cable.
But best of all, I plugged the last thumb drive into a brand new laptop, and it read 100%.
SmallTownGuy is offline
Old 06-02-2019, 04:42 PM   #4
Tom M's Avatar
Re: Flash Drives
Well I did that too. Squeezing the rectangle on the thumb for better friction.
The new one is found right away in all of my devices so it can't be a reader or device
Tom M is online now
Old 06-02-2019, 05:42 PM   #5
John the Builder
Re: Flash Drives
On reflection, I did fix a thumb drive for the gal that worked at the Lapeer Building Dept. The places where the contacts soldered onto the circuit board had developed a couple of fractures. So I flowed some new solder on and she was good again.
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Tom M (06-02-2019)
Old 06-02-2019, 06:01 PM   #6
Tom M's Avatar
Re: Flash Drives
It's mostly contracts and job photos for the last 10yrs nothing financial or database.....but still I don't want to lose it.
Tom M is online now
Old 06-02-2019, 06:39 PM   #7
John the Builder
Re: Flash Drives
You can try a shop. The one that repaired my iphone does micro soldering.
Guys with that talent are the exception, but they are out there.
Old 06-02-2019, 08:01 PM   #8
hdavis's Avatar
Rewards Points: 2,074
Re: Flash Drives
#1 problem is junk gets jammed in them. First try would be gently blow it out, next is use electronic cleaner spray.
If it's actually loose plugged in, go straight for the bending.
hdavis is online now
