Excel Formula Help - Technology - Contractor Talk
Excel Formula Help
Old 07-07-2019, 04:07 PM   #1
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,316
Excel Formula Help
Need help with creating an Excel formula. It's 'cuz I don't even know if it can be done, and if so, what the name of the formula would be.
So I'll try to explain.
Let's say I have Rows 1-100, Column A, populated with a bunch of numbers. Let's say they're random, anywhere from 1-1000.
Somewhere else on the sheet I want to create a list of all the numbers (in list A1:A100) that are between 500 and 599. In other words, generate a 'short list' of all the values that start with 5nn.
I know I can simply 'sort' the column, then scroll down until I run into the 500s, but that's too time-consuming. In reality, I'm using tens of thousands of rows.
I tried creating a 'unique' list using
{=INDEX(list,MATCH(0,COUNTIF(uniques,list),0))}
but with no success.
Anyone? Help? Beuhler?
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
Old 07-07-2019, 08:57 PM   #2
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,717
Re: Excel Formula Help
Maybe a sum if formula???....there is a ton of info on ablebits.com
Jay hole is offline
Old 07-07-2019, 09:05 PM   #3
480sparky's Avatar
SUM only performs addition.
Old 07-08-2019, 05:59 AM   #4
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 26
=if(a1>499;(if(a1<600;a1;0));0)
goneelkn is offline
Old 07-08-2019, 08:16 AM   #5
480sparky's Avatar
Even after editing to make it work, it returns the results of only one cell. Copying the formula down thousands of rows would still require scrolling down through all the cells.
Old 07-08-2019, 08:46 AM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,011
Something like this. Probably have to modify it with greater than signs
https://exceljet.net/formula/create-array-of-numbers
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 07-08-2019, 08:49 AM   #7
LRG WoodCrafting
Leo G's Avatar
Another way to do it, the long way around. Is to assign a formula to each cell and if the number shows up in your selected range it shows. It won't give you a nice short compact list in a small area. But it will be easy for you to find the numbers because they show up and all the numbers above or below show a null cell.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-08-2019, 09:33 AM   #8
480sparky's Avatar
That's the issue. I can easily create a formula that will show the desired results in Column B with a simple IF statement, but it's just as long as Column A. Endless scrolling, and the results are stretched down the sheet.
I end up with
501
579
588
517
545
560
571
522
594
563
501
583
577
541
516
588
554
503
511
539
594
539
528
593
530
Old 07-08-2019, 10:08 AM   #9
LRG WoodCrafting
Leo G's Avatar
Yep, I know. It's not an elegant work around.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-08-2019, 10:15 AM   #10
LRG WoodCrafting
Leo G's Avatar
https://www.get-digital-help.com/200...lumn-in-excel/
This is interesting.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-08-2019, 10:23 AM   #11
LRG WoodCrafting
Leo G's Avatar
Ya, that's the ticket. Here's the video that goes along with the page
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Fouthgeneration (07-08-2019)
Old 07-08-2019, 10:49 AM   #12
480sparky's Avatar
That's the ticket.
I had the formula basics, I just didn't have the cell references right. I needed to change my reference from relative to absolute cell references with $'s.
Old 07-08-2019, 11:53 AM   #13
LRG WoodCrafting
Leo G's Avatar
You're welcome
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-08-2019, 04:06 PM   #14
rselectric1's Avatar
Rewards Points: 880
You're welcome
Does this cancel out or increase the debt from about 10 years ago? I lost track.
rselectric1 is offline
Old 07-08-2019, 04:12 PM   #15
LRG WoodCrafting
Leo G's Avatar
Interest free.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-08-2019, 04:47 PM   #16
480sparky's Avatar
It just negates the carrying charges.
FWIW: Here's the formula I ended up with:
{=INDEX($T$2:$T$5000,MATCH(0,COUNTIF($V$1:V1,$T$2: $T$5000),0))}
The range of cells I'm extracting the data from is T2:T5000. The list of matches is populated starting at cell V1.
The {} brackets are very important.
