Work Warranty, Repair - Business - Contractor Talk
Old 06-24-2015, 09:49 AM   #1
AngryHammer's Avatar
Trade: General Contractor / Project Manager
Rewards Points: 14
Hello everyone, nice to have someone to talk to about construction issues and business. I was on while back but have not been on in while.
I have a question about warrantying your work as a contractor. Usually I put a 1 year warranty on all craftsmanship of our work. We do all types of renovations both residential and commercial. This, however, is a residential issue with a deck we built. First off, in almost 10 years I have never gotten called back for anything wrong with the work we do. So we have good track record.
This deck was built over 6 years ago and the homeowner, who has never called us to do anything else in the 6 years, has called my because they are selling the house. Their inspector had dug up one of the 2 footings and noticed it was only 24" deep when it should be 36" min. Now, I know what it should had been, and I assume all my help does as well. Turns out the helper I had working ont his job is back with me after not working with us for few years but I have always kept in touch. He does not recall the job, but I know I left him there with another helper to do the footings. When I was "SWINGING A HAMMER", I always dug to 40" to be safe with every footing we did...and I told all my guys the same. Well obviously they did not listen and thought they could get away with it.
I went to check and they are right it was 24". Now the repair will be pretty involved because the inspector does not want an under pin, he wants new footing next to old. And it will be a challenge to get to one of them because of the pavers going up to the deck. Needless to say it will be decent amount in materials and labor for couple guys for a day.
What should I do? I obviously am going to do the repair but do I charge? it is out of my warranty period...which is actually not on this contract they signed.
AngryHammer is offline
Old 06-24-2015, 10:03 AM   #2
aptpupil's Avatar
Rewards Points: 1,894
Re: Work Warranty, Repair
Didn't do it right the first time so it seems you have eat the cost.
aptpupil is offline
The Following 2 Users Say Thank You to aptpupil For This Useful Post:
hdavis (06-24-2015), KAP (06-24-2015)
Old 06-24-2015, 10:39 AM   #3
Creter's Avatar
Rewards Points: 1,966
Fix it - period. Had the rules changed in the six years to him requesting new fasteners etc, different story. It wasn't built to code to begin with.
Appreciate the fact that it's just the one footing you have to deal with...
Creter is offline
Old 06-24-2015, 11:03 AM   #4
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
I would check see what the code was 6 years ago. If it called for 24" then you can argue that it was done appropriately. If you had a permit and an inspection you could put it back on the municipality for approving it. If either case has validity then you could probably get the issue grandfathered.
Now in the case where neither situation applies, I'd fix it at no cost simply because the owner paid for you in full to do it the way that you promised to do it.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 06-24-2015, 11:05 AM   #5
Anti-wingnut's Avatar
Rewards Points: 3,414
Is the inspector a home inspector? He has no right to demand a fix, nor can he say what the fix must be
Anti-wingnut is offline
The Following 3 Users Say Thank You to Anti-wingnut For This Useful Post:
hdavis (06-24-2015), tedanderson (06-24-2015), tgeb (06-24-2015)
Old 06-24-2015, 11:12 AM   #6
Creter's Avatar
I can't see New York being 24" for code when we've been 30" here in Missouri for as long as I know of...
Creter is offline
Old 06-24-2015, 11:30 AM   #7
The statute of limitations has probably expired in New York. I would do as you think best, including the possibilities of hiring an engineer, under pining, digging them up, or absolutely nothing.
What I would not do is involve the inspector in any way. He is completely out of his job scope and authority. Deal with the HO's only.
http://www.thsh.com/documents/Statut...ns11-10-10.pdf
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Old 06-24-2015, 11:40 AM   #8
The soil might be different between the two states. The last time I did a deck in Maryland, they called for making the hole 30" deep but the footing only had to be 24" because the height of the deck was less than 2 steps from the ground.
Old 06-24-2015, 12:12 PM   #9
KAP's Avatar
Trade: Custom
Rewards Points: 35,424
So what you're saying is the town inspector didn't do his job and passed it anyway...
Either way... fix it... less headaches... it's not a warranty issue, but a business practice issue... and the right thing to do...
KAP is offline
The Following 5 Users Say Thank You to KAP For This Useful Post:
AngryHammer (06-30-2015), aptpupil (06-24-2015), Creter (06-24-2015), Jaws (06-24-2015), SmallTownGuy (06-24-2015)
Old 06-24-2015, 12:19 PM   #10
Creter's Avatar
I would imagine the soil varies from the two states as it varies widely in our region.
30" deep is for FROST around here. I assumed New York was as cold or colder than Missouri...
Creter is offline
Old 06-24-2015, 05:11 PM   #11
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Two things I see wrong with this thread. Ten years building and not one call back ? Yea right and I'm a chinese fighter pilot. Footing specs being changed don't think so. Fix it and take it on the chin. Sounds like you need to watch the help a little closer and get out of the truck a little more often.
kingcarpenter is offline
The Following User Says Thank You to kingcarpenter For This Useful Post:
Jaws (06-30-2015)
Old 06-24-2015, 05:22 PM   #12
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
like everyone else said.
if you can't prove it not wrong, then it wasn't done correctly.
fix right the 2nd time. "what a catchy phrase"
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 06-24-2015, 05:40 PM   #13
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
What inspector digs a hole to find that out?
BamBamm5144 is offline
The Following 2 Users Say Thank You to BamBamm5144 For This Useful Post:
AustinDB (07-01-2015), MattK (06-24-2015)
Old 06-24-2015, 05:48 PM   #14
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,096
An inspector who had run out of things to find to justify his outsized fee?
SmallTownGuy is offline
Old 06-24-2015, 07:33 PM   #15
JBM's Avatar
Trade: Masonry
Rewards Points: 10,088
If its a home inspector then it doesnt mean anything that he doesnt want an underpin. If thats the better option due to pavers ect then thats what you do. I would even bring some updated fasteners with you and put them on. Always put the show on, graciously.
JBM is online now
The Following 2 Users Say Thank You to JBM For This Useful Post:
AngryHammer (06-30-2015), Pearce Services (06-28-2015)
Old 06-24-2015, 07:36 PM   #16
JBM's Avatar
Trade: Masonry
An inspector in December made someone dig a hole next to the pre cast deck footing things whatever they are called. Then he complained he couldnt see inside my chimney they way he wanted. Fun times.
JBM is online now
Old 06-24-2015, 08:02 PM   #17
MattK's Avatar
Trade: Framing, Roofing, Siding
Rewards Points: 1,096
As soon as I read that line I started to laugh. In the last 10 yrs, I've had call backs from little things here and there. Most of the time they're minor and a good opportunity to learn how to prevent moving forward...further adapting our skillset.
I was always told "A great carpenter isn't a man who makes mistakes, it's a man you knows how to fix them when they do happen."
--MATT
Add your Facebook Business Site to "THE LIST"
http://www.contractortalk.com/f12/if...-should-79504/
Page 77 has the updated, complete list.
MattK is offline
Old 06-24-2015, 08:06 PM   #18
MattK's Avatar
As for your situation, I would remind them that you ARE out of warranty but because the footing depth wasn't satisfactory in the first place, you'll handle the repair free of charge to guarantee their satisfaction. This will hopefully gain you some good will with the HOs, maybe they'll hire you on their next house.
--MATT
MattK is offline
The Following User Says Thank You to MattK For This Useful Post:
Old 06-24-2015, 08:28 PM   #19
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 7,082
When I did my deck had to be over 42" deep to pass ten years ago and I still had a little heaving
NYgutterguy is offline
Old 06-30-2015, 10:58 AM   #20
Rewards Points: 14
Thanks for all the input guys..even the wise a## remarks
I will be fixing it, underpin for an 8x13 deck should be more than sufficient. Otherwise I can move the girder out to the edge of deck and just add 2 new ones.
Warranty Work BamBamm5144 General Discussion 10 01-22-2015 11:37 PM
Scope of work CarpenterSFO General Discussion 20 11-03-2014 08:27 PM
Looking For Commercial Painting Crew for work in Highlands, NC rdr8887 Help Wanted or Looking For Work 2 03-23-2013 01:12 PM
