Skill Test - Business - Contractor Talk
Skill Test
Old 12-30-2016, 12:01 PM   #1
zennode's Avatar
Rewards Points: 14
Skill Test
Does anyone have a good basic carpentry skills test that they would be willing to share for new hires?
zennode is offline
Old 12-30-2016, 12:18 PM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,460
Re: Skill Test
Supply the 2x4's and the nails and ask them to build a pair of saw horses.
Robie is online now
The Following 3 Users Say Thank You to Robie For This Useful Post:
Calidecks (12-31-2016), Dirtywhiteboy (01-01-2017), wallmaxx (01-01-2017)
Old 12-30-2016, 12:35 PM   #3
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Re: Skill Test
If they get in their truck and come back with these, I will hire them on the spot:
EricBrancard is offline
The Following 5 Users Say Thank You to EricBrancard For This Useful Post:
Bull Trout (03-24-2017), greg24k (03-25-2017), JohnsonPlumbing (03-25-2017), mstrat (03-24-2017), slowsol (12-30-2016)
Old 12-30-2016, 12:39 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,962
Re: Skill Test
good test of skill, just not sure how relevant it is now days.
can't recall the last time i saw all wood horses on a job.
pretty much all i see now days is trojan or some variant.
griz is online now
Old 12-30-2016, 12:51 PM   #5
Robie's Avatar
Re: Skill Test
Just answering his question...about a skill's test.
Robie is online now
Old 12-30-2016, 01:11 PM   #6
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
Re: Skill Test
I think you should first better define the job tasks.
Knowing which side of a line to cut on for a task. How to mark a cut for tight or loose. How to cull and sort new lumber. Figuring a square without a "square". How to safely operate the equipment. How to set an extension ladder.
Another thought, ride with them in a vehicle for a couple hours for observation of their driving, way they treat and maintain the vehicle, etc. For labor laws pay them for the time spent doing so, if not already on the clock.
P42003 is offline
Old 12-30-2016, 01:16 PM   #7
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,721
Re: Skill Test
How about have them sharpen a carpenters pencil! It usually looks like a beaver chewed the end of there pencil.
Jay hole is offline
The Following User Says Thank You to Jay hole For This Useful Post:
Old 12-30-2016, 01:18 PM   #8
Business Owner
P42003's Avatar
Rewards Points: 158
Re: Skill Test
How to safely use a box cutter. How to set saw depth for various material types, and how to reduce tearout. How to measure from an origin point over several cuts and hold a factory edge. How to set drill speed and clutch for different tasks. How to cope and back miter.
P42003 is offline
Old 12-30-2016, 01:23 PM   #9
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 60
Re: Skill Test
Think about what you do a lot of... if it's doors all the time, have 'em hang a door. Stairs? Cut a stringer. Just set your quality expectations in advance. Observe some of the process if you want, but realize that some people aren't at their best when someone is gawking.
Or is this a pre-screen paper test? See here: http://www.woodweb.com/cgi-bin/forum...pl?read=784368
Defenestrate is offline
Old 12-30-2016, 01:40 PM   #10
Fire up the BBQ
griz's Avatar
Re: Skill Test
look at his tools. well kept?
give him a chunk of 4x and watch how he drives nails....
give him some 2x and call out some block measurements....
watch how he uses saw, check blocks for accuracy dimension & sq.
i also like the sharpen the pencil....
also have him roll up a long cord....
griz is online now
heavy_d (12-30-2016)
Old 12-30-2016, 03:22 PM   #11
Lazy Millennial
Youngin''s Avatar
Rewards Points: 748
Re: Skill Test
When I was 17 I worked for an asbestos abatement company. The boss had a VERY particular way he wanted the cords wrapped up. He told me to practice till he deemed it satisfactory. Took about 15 mins to get it just right.
Also had to draw a straight origin line on the ground (polished concrete) then draw a 90 degree perpendicular line off the origin line without the use of a square or tape measure.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is offline
Old 12-30-2016, 04:08 PM   #12
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
Re: Skill Test
I think an attitude test is more important than a skills test.
Lewis Carpentry
Spencer is offline
Old 12-30-2016, 04:27 PM   #13
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
Re: Skill Test
It depends on if they have a current job or not. Have him/her come out and try a day in the field first. The hardest skill for them NOT to do is be late, then be on the cell phone all day, then, did they bring water/lunch, opps I forgot did they have tools or a car/truck?? All things to consider in the world we all live in today!
Once that is complete, go from there! My dad always hired skilled carpenters by the way they could, or could not do stair lay-outs. Said if they can do it, they can do most things needed!
Dave in Pa is offline
Old 12-30-2016, 06:10 PM   #14
Learn-Build-Enjoy
ASidhu's Avatar
Trade: Carpentry and Landscaping
Rewards Points: 142
Re: Skill Test
For me skills do not matter as much their willingness to work and improve because as long as you have a solid hard working individual you can start them off with a basic wage and slowly increase it as they get better which is like positive reinforcement and helps motivates them.
Some things I look for:
-do they even show up on time with their tools
-do they run away from hard tasks such as shoveling, carrying heavy loads
-are they honest
-can you trust them with your tools
-are they heavy drinkers or into drugs
Skills tests are not needed if you just put them to work and see how they perform at those specific tasks.
I have only seen big companies use skills tests for recruiting trades students
I have a certain criteria I use for my employees and if they do not meet those requirements I do not hire them.
ASidhu is offline
Old 12-30-2016, 09:25 PM   #15
Fire up the BBQ
griz's Avatar
Re: Skill Test
you'll never get a skills test or a try out if you don't pass the attitude test first....
griz is online now
Old 12-30-2016, 09:33 PM   #16
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 354
Re: Skill Test
These threads get started about once a year. Here has been my standard reply the last few years:
You guys and your tests...
Here is mine:
When was the last time you got high?
Are you high now?
How many beer cans are in your truck?
What year will you get your license back?
Easy Gibson
Warren is online now
The Following 2 Users Say Thank You to Warren For This Useful Post:
griz (12-30-2016), mstrat (03-24-2017)
Old 12-30-2016, 09:39 PM   #17
Fire up the BBQ
griz's Avatar
Re: Skill Test
Here is mine:
Are you high now?
I never gave a skills test. A few minutes of BSing told me what I needed.
Who have you worked for what projects you worked on?
What do you think your skill level is?
Are you on probation or work furlough?
Do you have any pending court dates?
Standard drill was to work until first break and we'll talk.
Some never made it to first break.
griz is online now
Old 12-30-2016, 09:41 PM   #18
FrankSmith's Avatar
Rewards Points: 5,124
Re: Skill Test
I will always try to ask a question that any professional would know and anyone else would not. For example if I need to hire a guy to work on my projects they need to know a lot about window and siding.
I will ask them to tell me how they get the water that goes in the j-channel around a window back out. Someone can't fake there way through the answer but if you install siding its easy.
FrankSmith is offline
Old 12-30-2016, 10:12 PM   #19
Mordekyle's Avatar
Rewards Points: 5,998
Re: Skill Test
-are they honest
Agreed.
Hire for character, train for skill.
New skills can be taught. It's A little harder to parent. If they don't have good character- ethics, punctuality, honesty etc., you'll pull your hair out till you fire them or they quit.
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
ASidhu (12-31-2016)
Old 12-30-2016, 10:17 PM   #20
antonioooooooo's Avatar
Trade: framing, finishing.
Rewards Points: 429
Re: Skill Test
New guy: I'm the best at that!
Actuality: I'm an idiot, that thinks everything is simple, but I constantly screw everything up.
Never fails.
antonioooooooo is offline
The Following User Says Thank You to antonioooooooo For This Useful Post:
FrankSmith (12-30-2016)
need advice on master plumber test sully123 Plumbing 1 02-24-2011 03:43 PM
ICC Test Prep Suggestions ebivremodel Business 1 01-04-2011 09:09 PM
New Lead Test Kit hiteams Lead RRP Discussion 3 09-02-2010 02:32 PM
New Employee Skill Assessment Test!!! Harmoney Const Carpentry 68 08-19-2008 12:35 AM
