Keeping Books/Accounting/Newbie - Business - Contractor Talk
Old 01-24-2005, 10:05 PM   #1
nova's Avatar
Hi everyone, I'm in the process of starting a small remodeling business in the nyc area, I am really new to the accounting side of things. Has anyone heard of a payroll program called PayCycle(if so is it recommended) or "quickbooks for contractors"(does this handle the accounting needs from a to z). I appreciate any help on this subject.
Ed.
nova is offline
Old 01-24-2005, 11:51 PM   #2
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Re: Keeping Books/Accounting/Newbie
Quickbooks is by a landslide the industry standard for not just contracting but just about all small businesses, you start to see some other products when talking to more substantial companies, but for the couple of million dollar a year and below its probably used by something like 9 out of 10 companies. As far as the contractor version, you will hear some people use and while others see little benefit over the standard version. You should get some other responses but I will be surprised to hear much different.
Mike Finley is offline
Old 01-25-2005, 12:11 AM   #3
Grumpy's Avatar
Accounting sucks ass. I could not tell you how much easier my life would be if I didn't have to track every penny in and every penny out. It is a tremendous burden on me for my time. This is the first duty I give my offie manager once I hire one.
By far uick books is the industry standard but that's nott o say it's the only solution out there. I personally use Quickbooks Pro. I didn't think the extra $ was worth the upgrade to premier.
What I did was set my company up with a trial version of the contractor edition. That set up all the accounts and contractor specific goodies. Then I purchased the pro edition and transfered the data over and all the account and most of the contractor specific goodies remained. You can fight the man!
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 01-25-2005, 08:27 AM   #4
TimWieneke's Avatar
Rewards Points: 250
We like the accountant edition because we are in total sync with our off-site accountant and can send him data, then receive our monthly reports.
Mike's right - the contractor edition just really doesn't have enough to entive us to it. I almost have the feeling they read contracting books then made it, rather than hiring contractors as consultants when making it.
Tim
TimWieneke is offline
Old 01-25-2005, 09:28 AM   #5
Teetorbilt's Avatar
Quickbooks Pro and my bookeeper can access it from her office so she may have upgraded to accountant. I'm like Grumpy about the number details, just tell me that I made a lot at the end of the month.
Teetorbilt is offline
Old 01-25-2005, 09:54 AM   #6
TRC
TRC's Avatar
Trade: Windows and Doors
Rewards Points: 87
I'm using quickbooks pro but I wish i did a little more research on how to set up my company before I started using it. I would reccommend purchasing the Quickbooks for Contractors book, you can get it at amazon. They provide you with an estimating program and a sample file that gets you up and running with all the items and accounts you'll need. It's good because you can just follow they're reccomendations instead of learning the hard way like I did. Now i'm having loads of fun trying to straighten out my books.
TRC is offline
Old 01-30-2005, 11:13 PM   #7
Business Consulting
Sarah9910's Avatar
Trade: Business Consulting for Contractors
Rewards Points: 250
I agree, use QB Pro Accountants Edition. If you need custom chart of accounts and cost codes etc, for home builders go to infoplusacct.com and check out the accounting pro product, it's a database that works with Quickbooks for home builders. If you need help setting up, I can help you remotely.
Sarah9910 is offline
Old 02-16-2005, 08:35 PM   #8
C.Davis's Avatar
We use a three prong approach to our office/accounting needs.
1. for figuring hourly rates www.yourcostcenter.com
2. For estimating we use a digitizer into a program by Vertigraph.
3. For general accounting we use MYOB.
Although if I was to start a new I would use a web hosted program called Netsuite which handles all your accounting plus CRM plus email marketing.
But it's expensive.
Good luck.
C.Davis is offline
Old 02-22-2005, 08:23 AM   #9
JAT's Avatar
I use QuickBooks Premier Contractor's Edition - but it is NOT necessary to go that route. In fact, it may be beneficial if you start with a smaller version - even Quicken, which is more user-firendly and you and adapt the accounts to suit your needs.
Talk to your accountant first. See what he/she recommends. Most accountants will adapt to any bookeeping system you draw up.
It's probably easier for you to start on a 'cash' basis, instead of accrual. That just means you record money-in and money-out and do not record your accounts payable and receivable.
Payroll, at this point, can be done on paper and you can record your transactions each time you actually pay out. Contact your state offices for the proper forms you will need to file. They will send you the current withholding rate booklets.
Don't rush into buying a top-of-the-line program. Get a handle on what it means to track your expenditures first and then decide based on your specific needs.
A business accounting class, perhaps from your local community college, would be a super idea.
Good luck.
JAT is offline
Old 02-22-2005, 09:34 AM   #10
Don Benham's Avatar
Rewards Points: 150
another voice for Quickbooks.
Don
Don Benham is offline
Keeping my rollers clean. metomeya Painting & Finish Work 11 06-12-2007 12:09 AM
Cost tracking and record keeping Tom M Business 11 05-21-2007 06:37 AM
Record Keeping for Taxes DoubleJ Business 8 04-30-2007 06:00 PM
tips on keeping products from freezing in truck AustinDB Construction 2 02-11-2007 08:31 PM
Keeping It Simple Stupid CNLPAR Construction 2 11-07-2006 03:48 AM
