UV Sealant - Roofing - Contractor Talk
UV Sealant
Old 04-12-2020, 12:43 PM   #1
misterkel's Avatar
Rewards Points: 2
UV Sealant
I am trying to seal a sun-roof with clear poly panels - ongoing problem. I used FLEX rubber membrane, but then noticed it was not UV resistant. Any suggestions on what to do to topcoat it?
thanks (primarily a paint contractor, so roofing is a bit outside my normal area!)
misterkel is offline
Old 04-12-2020, 06:03 PM   #2
VinylHanger's Avatar
Rewards Points: 13,786
Re: UV Sealant
You most likely can't. Is this a polycarbonate panel?
Only thing I have found that is compatible is silicone.
Are you just sealing the leaking holes or trying to coat the whole thing?
The problem is that most sealants will burn the polycarbonate and it will fail sooner.
Sent from my SM-N975U using Tapatalk
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
johnHRoof (04-13-2020)
