Trimming Metal Roof Back With No Rusting - Roofing - Contractor Talk
Old 11-30-2016, 05:12 AM   #1
MSgutter's Avatar
Trade: seamless gutter
Rewards Points: 40
What's the most efficient way/tool for trimming back a metal roof without making the edge rust? Someone told me the best way was just by hand with some basic strait metal cutters...
MSgutter is offline
Old 11-30-2016, 07:28 AM   #2
CharlieDelta's Avatar
Trade: Carpentry/Building/Remodeling
Rewards Points: 1,794
Re: Trimming Metal Roof Back With No Rusting
Any unpainted/exposed metal will rust regardless of how it's cut.
CharlieDelta is offline
Old 11-30-2016, 08:18 AM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,674
Not entirely true. Cutting with a shear or snips will seal the edge with the galvanized coating of the metal. Where as cutting with a saw tears the metal leaving it prone to rusting.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
CharlieDelta (11-30-2016)
Old 11-30-2016, 08:38 AM   #4
MSgutter's Avatar
Rewards Points: 40
So could I buy a good electric shear and be fine? I've got a pretty good bit if metal to cut. Almost 3 entire homes. Or even a good nibbler?
MSgutter is offline
Old 11-30-2016, 09:04 AM   #5
rustyjames's Avatar
Rewards Points: 1,818
You should be ok with shears or nibblers, although the profile of the panel will dictate which will work better.
rustyjames is online now
Old 11-30-2016, 09:29 AM   #6
madmax718's Avatar
Trade: General
Rewards Points: 3,276
This sounds like a disaster for trying to prevent rust.
There is no way it is sealing squat. Galvanizing material doesn't move. A clean edge (or polished edge) will have less surface area to rust, and the existing galvanizing material on the metal will prevent the rust creep.
A sheer or nibbler will be cleaner, and not have hot metal sparks that can in-bead into surrounding surfaces which will rust and appear to be as if its the base metal. Thats the reason to choose a sheer or nibbler/cutter,etc.,
If you want to restore some protection to the edge, after cutting, wipe down with denatured alcohol, then apply a cold galvanizing compound. Easiest applied with a roller just on the edge, then top coat the edge with a roller with matching paint, or clear coat.
If you dont, the existing zinc will eventually be used up close to the edge, and rust will start spreading.
madmax718 is offline
The Following User Says Thank You to madmax718 For This Useful Post:
Old 11-30-2016, 09:48 AM   #7
MSgutter's Avatar
Rewards Points: 40
The profile will be similar to this. Which would be better for this profile? Shears or nibbler?
MSgutter is offline
Old 11-30-2016, 10:00 AM   #8
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,236
I don't do metal as often as these other guys, but I use Malco turbo shears when cutting the Americana profile like that. Seems to work well.
It's a bit awkward, but faster than hand shears. I attach it upside down in the drill, makes it easier for me to get over the ribs
Philament is offline
Old 11-30-2016, 10:19 AM   #9
madmax718's Avatar
Trade: General
metal cutting blade in a circular saw.
rustyjames (11-30-2016)
Old 11-30-2016, 10:28 AM   #10
madmax718's Avatar
Trade: General
btw dewalt is supposed to have a sheer attachment.
https://www.amazon.com/DEWALT-DWASHR...ag=toolguyd-20
supposed to cut 18 ga
The problem with that profile is that a lot of shears will deform that profile. If it were me (and Im not a roof guy) but if I had to do more than 3 feet of cutting, I'd invest in a metal cutting blade.
Old 11-30-2016, 10:34 AM   #11
Good point
Old 11-30-2016, 10:41 AM   #12
diplomat
Golden view's Avatar
Rewards Points: 1,550
Those panels are common where I used to live, and I'm writing this under a 35 year old one in Alaska right now. The cut edges never seem to be an issue.
Golden view is offline
Old 11-30-2016, 02:09 PM   #13
Randy Bush's Avatar
All factory cut are done with a shear / guillotine. that do not have any extra treatment done to the cut edge and do not rust. Cutting with a shear or even snips sacrifices or rolls the edge as it is cut there by sealing that edge.
Where as with a blade you are tearing the edge as you cut leaving a very raw edge that is prone to rust. In over 20 years I have never used a blade to cut my roofing or steel siding. Most of my steel siding says right on the box "Do not cut with saw"
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
Golden view (11-30-2016), Philament (11-30-2016)
Old 11-30-2016, 02:14 PM   #14
MSgutter's Avatar
Rewards Points: 40
I ended up buying a malco shear that connect onto a drill.
MSgutter is offline
The Following User Says Thank You to MSgutter For This Useful Post:
Randy Bush (11-30-2016)
Old 11-30-2016, 02:34 PM   #15
madmax718's Avatar
Trade: General
Id understand that more with the large guillotine types, as it literally squeezes the two pieces apart- but Im not certain that happens with snips. Either way, if thats what the box says, and you have 20 years in doing it, I'll take your word for it.
Flat roof - What roofing system should I use? acro Roofing 10 04-15-2013 04:47 PM
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Insulation under a metal roof Kevin75 Insulation 4 12-04-2008 06:00 PM
Valley flashing on a metal roof Quinn Roofing 0 11-07-2008 03:08 PM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 12:30 AM
