-   Roofing (https://www.contractortalk.com/f15/)
-   -   Trimming metal roof back with no rusting (https://www.contractortalk.com/f15/trimming-metal-roof-back-no-rusting-312090/)
MSgutter 11-30-2016 05:12 AM
What's the most efficient way/tool for trimming back a metal roof without making the edge rust? Someone told me the best way was just by hand with some basic strait metal cutters...
CharlieDelta 11-30-2016 07:28 AM
7 Attachment(s)
Any unpainted/exposed metal will rust regardless of how it's cut.
Randy Bush 11-30-2016 08:18 AM
Not entirely true. Cutting with a shear or snips will seal the edge with the galvanized coating of the metal. Where as cutting with a saw tears the metal leaving it prone to rusting.
MSgutter 11-30-2016 08:38 AM
So could I buy a good electric shear and be fine? I've got a pretty good bit if metal to cut. Almost 3 entire homes. Or even a good nibbler?
rustyjames 11-30-2016 09:04 AM
You should be ok with shears or nibblers, although the profile of the panel will dictate which will work better.
madmax718 11-30-2016 09:29 AM
This sounds like a disaster for trying to prevent rust.
There is no way it is sealing squat. Galvanizing material doesn't move. A clean edge (or polished edge) will have less surface area to rust, and the existing galvanizing material on the metal will prevent the rust creep.
A sheer or nibbler will be cleaner, and not have hot metal sparks that can in-bead into surrounding surfaces which will rust and appear to be as if its the base metal. Thats the reason to choose a sheer or nibbler/cutter,etc.,
If you want to restore some protection to the edge, after cutting, wipe down with denatured alcohol, then apply a cold galvanizing compound. Easiest applied with a roller just on the edge, then top coat the edge with a roller with matching paint, or clear coat.
If you dont, the existing zinc will eventually be used up close to the edge, and rust will start spreading.
MSgutter 11-30-2016 09:48 AM
The profile will be similar to this. Which would be better for this profile? Shears or nibbler?http://uploads.tapatalk-cdn.com/2016...d714fcc18f.jpg
Philament 11-30-2016 10:00 AM
I don't do metal as often as these other guys, but I use Malco turbo shears when cutting the Americana profile like that. Seems to work well.
It's a bit awkward, but faster than hand shears. I attach it upside down in the drill, makes it easier for me to get over the ribs
madmax718 11-30-2016 10:19 AM
metal cutting blade in a circular saw.
madmax718 11-30-2016 10:28 AM
btw dewalt is supposed to have a sheer attachment.
https://www.amazon.com/DEWALT-DWASHR...ag=toolguyd-20
supposed to cut 18 ga
The problem with that profile is that a lot of shears will deform that profile. If it were me (and Im not a roof guy) but if I had to do more than 3 feet of cutting, I'd invest in a metal cutting blade.
CharlieDelta 11-30-2016 10:34 AM
7 Attachment(s)
Good point
Golden view 11-30-2016 10:41 AM
Those panels are common where I used to live, and I'm writing this under a 35 year old one in Alaska right now. The cut edges never seem to be an issue.
Randy Bush 11-30-2016 02:09 PM
All factory cut are done with a shear / guillotine. that do not have any extra treatment done to the cut edge and do not rust. Cutting with a shear or even snips sacrifices or rolls the edge as it is cut there by sealing that edge.
Where as with a blade you are tearing the edge as you cut leaving a very raw edge that is prone to rust. In over 20 years I have never used a blade to cut my roofing or steel siding. Most of my steel siding says right on the box "Do not cut with saw"
MSgutter 11-30-2016 02:14 PM
I ended up buying a malco shear that connect onto a drill.
madmax718 11-30-2016 02:34 PM
Id understand that more with the large guillotine types, as it literally squeezes the two pieces apart- but Im not certain that happens with snips. Either way, if thats what the box says, and you have 20 years in doing it, I'll take your word for it. :thumbup:
