Software To Measure Roof? - Roofing - Contractor Talk
Old 05-05-2019, 02:33 PM   #1
mkb's Avatar
Trade: Gen B
Rewards Points: 128
Does anyone have an app or software you use to measure a roof?
mkb is offline
Old 05-05-2019, 04:37 PM   #2
Bull Trout's Avatar
Rewards Points: 446
Re: Software To Measure Roof?
Bull Trout is online now
The Following 2 Users Say Thank You to Bull Trout For This Useful Post:
greg24k (05-08-2019), mrcat (05-05-2019)
Old 05-05-2019, 08:56 PM   #3
Radical Basement Dweller
Robie's Avatar
Rewards Points: 1,652
The last shingle estimate I got, the chap used Google and an added download.
He had the approximate dimensions before he arrived on site then measured manually.
https://roofonline.com/how-to-use-go...area-of-a-roof
Immigration is not supposed to change the character of the nation.
Immigration is supposed to change the character of the immigrant.
Robie is online now
Old 05-05-2019, 09:18 PM   #4
hdavis's Avatar
Rewards Points: 7,608
Originally Posted by Bull Trout View Post
http://www.rolatape.com/us/en/produc...312/rt312.html
hdavis is online now
Old 05-05-2019, 09:31 PM   #5
hdavis's Avatar
BTW, the estimator that backed off a roof measuring with a tape would have had all his measurements faster and safer using a measuring wheel.
I've used Google satellite view to get measurements. They're pretty close.
On some old thread you'll find some of the service providers that have software for these measurements.
Old 05-08-2019, 06:35 AM   #6
builditguy's Avatar
Rewards Points: 1,250
Doesn't Exactimate do that? I don't have it, but I've seen adjusters measure the outside dimensions of the house, the over hang, and guess the pitch. Then they send back a claim with the roof dimensions and square footage.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
hdavis (05-08-2019)
Old 05-08-2019, 10:33 AM   #7
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 94
Eagle view is what many adjusters do if they don't like getting on the roof or simply measuring the house & adding on as others said
as for xactimate - yeah they have a button to import it, if not you sketch out manually
SLSTech is offline
Old 05-10-2019, 09:17 AM   #8
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,606
You can use google earth pro. It's probably still free. It has a square foot calculator that can be used based on your input. Take the satellite image and drag a perimeter on the building and it will give you square feet inside the polygon. You would then have to apply a pitch multiplier and any hidden overhangs and your choice of waste factor.
This is pretty accurate with a little practice. Getting familiar with views and controls on google earth gets you there. Of course, field verification is recommended.
Above all, a good roof
Mr Latone is offline
Do you judge a worker by his tape measure? Millworker Tools & Equipment 175 03-01-2016 10:54 AM
can I add a drip edge to this rubber roof edge? tersh Roofing 3 04-17-2013 02:58 PM
Flat roof - What roofing system should I use? acro Roofing 10 04-15-2013 04:47 PM
Roof Inspection Photo Software GPM Roofing 2 02-21-2011 02:30 PM
